Question about ViewSonic N3251w 32 in. LCD HDTV
Power lock enable
I cant turn off the power lock enable 2 my 32" veiwsonic i ave tried everything possible can u help me solve this problem
  • 3 more comments
  • standifo Sep 08, 2008
    Me too. Started yesterday afternoon while watching the Jags. Only way to turn it off is to unplug it.
  • andriesdan Nov 28, 2008
    My TV is not closing. The message is Power Lock Enable. I cannot turning off eather from the TV eather from the Remote Controle.
    Can you help me?
  • monashaw Feb 15, 2009
    Same problem. Any permanent fix for this?
  • lburns76 Apr 17, 2009
    monashaw - that only turns on/off the OCD lock but does not seem to fix the Power lock problem on my TV.
    Any other solutions?
  • andriesdan May 11, 2010
    I cannot turn off my TV. Not with the power button, and not on my tv remote control. pklease help me.
Okay, do this.
On the top of the t.v. itself, hold down the Volume+ (up) and the Menu button down at the same time. This will turn off the "power lock." This is also how you turn on the "power lock." (Though I can't think of a reason anyone would ever want to do this.)
Posted on Feb 15, 2009
  • rous3
    rous3 May 18, 2012
    THANK YOU VERY MUCH!!!!!!
Thanku so much , i had the same problem and i tried it VOL+ and Menu button on TV set and it works...
Posted on May 25, 2009
Please can anyone help done the solution you said holdin down buttons to enable me to unlock but nothin is happening have you any other ideas to help me
Posted on Sep 06, 2011
    Novelist:
  • 142 Answers
I have the same problem with mine. Walk up to your TV, press and hold the power button on the front of the set. While holding this button, press the power button on the remote.
Mine behaves this way on all functions. Even to change the channel, volume or input (among other things) I have to press and hold the power button on the set. Very annoying. I'd be interested in hearing from anyone who might have had this problem and found a solution for it. Viewsonic support isn't qualified to troubleshoot these kinds of technical issues.
Posted on Oct 24, 2008
When I turn my apple MacBook Pro on it goes to a system lock pin entry screen. I tried resetting the ram but then it goes to an administration password entry screen. What options do I have. I think the...
If you have a apple store account and wifi, you hold down the Option and the R buttons while booting until the apple symbol appears, follow menu from there to install proper OS
Sep 21, 2013 | Apple Genuine 13.3" Macbook Pro Unibody...
I have an inspiron 1526 with 2 flashing padlock icons and a black screen i cant turn it on what can i do?
Those are Diagnostic indicators that point you to the possible cause. The padlocks will have a number ( Turns on when the numeric keypad is enabled.) or capital letter(Turns on when the uppercase letter function is enabled.) or arrow key(Turns on when the scroll lock function is enabled.).
According to those indicators you either have a bad memory module or your CPU (processor) is bad.
May 08, 2011 | Dell Inspiron 1526 Notebook
I have a hp dv5000 multimedia notebook. Till yesterday, everything was working fine, but this morning before starting up the comp, I cleaned the keppad witha soft brush and then switched on the power...
Remove the power chord. Remove the battery. Remove all the external peripherals. Press and hold the power button for 15 seconds. Put the battery back in. Turn on the laptop.
It should work fine now.
if not turn the laptop upside down then slap it lightly 3-4 times
this will then surely fix the problem and if not then take it to the service center.
Sep 06, 2010 | Computers & Internet
LCD screen went blank
The Viewsonic VX2235WM has a known issue with the power supply going out. The flashing power light or not turning on is the classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Oct 22, 2009 | ViewSonic VX2235wm LCD Monitor
95 Buick Park ave makes a Knock noise while driving
possibly your ball joints, or a wheel bearing starting to go
Jul 27, 2009 | 1995 Buick Park Avenue
The light thats a lock with the letter a starts blinking and it wont boot up. how do i fix this
The blinking light is just a status for the caps light. If the unit does not power on or boot , you may have
A) a low or bad battery, Take the battery out and try to power up just by plugging the unit into the outlet.
B) If that does not work, You may have a loose DC connector on the system board. Unplug the plug from the outlet, then slightly wiggle the connector at the back of the laptopwhere the adapter plugs in. If it moves , the connector is loose on the MLB.
The blue lights located above the keyboard indicate the following:
Turns on when the uppercase letter (caps lock) function is enabled.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 16, 2009 | Dell Inspiron 1501 Notebook
Keys stuck
I just had the same problem, the battery went dead on my jimmy did not have enough juice to release the locking mechanism.you might try battery charger on high power or try jumping it if possible. a new battery solved my problem. hope this helps. mark
May 14, 2009 | 1999 GMC Jimmy
How to get engine to start?
IF IT DOESNT TURN OVER TRY AVEING YOUR STARTER TESTED THEY USELY WILL DO IT FOR FREE ,NEXT IGNITION SWICTH IS POSSIBLE , ARE YOUR BATTERY MAY HAVE A BAD SELL , IF THESE DONT WORK TRY TURNING YOUR ENGINE OVER BY HAND TO SEE IF ITS LOCK UP ?
Feb 13, 2009 | 1978 Chevrolet C1500
Internet wireless connectivity
This is a common and annoying problem. Your router is running and connected, but they are either not using the same encryption keys or else you have some other setting incorrect (encryption type is a common one).
Turn off the laptop's wireless connection and enable its cable (wired) connection. Connect the laptop to the back of the router physically with a network cable. In a browser type 192.168.1.1 (or other similar number - check your router's quick start guide). Log into the router and go to the WIRELESS SETTINGS. Write down everything you see (channel, station ID, encryption type and key, and whether MAC ADDRESS LOCKING is on (if it is turn it off for now)). Take these settings, reverse the process on your laptop and try to connect wirelessly with the new settings. They have to be exactly the same
If it all works, you need to go back into the router and enable MAC ADDRESS LOCKING after giving it your laptop's MAC ADDRESS, enable the highest standard encryption both the router and the laptop support, and turn off station ID broadcasting if possible.
If you still cannot connect wirelessly, connect again through the wire connection, and turn off encryption, turn off MAC ADDRESS LOCKING, and try again.
Good luck...
Nov 16, 2007 | Belkin (F5D6230-3) Wireless Router
ViewSonic N3251w 32 in. LCD HDTV Logo
1,676 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
