Question about Radio Communications
Vertex headset I bought a headset made for a Vertex VX-150. My radio is a Vertex VXA-150 (aviation) and the PTT on the headset won't work.
  • 55 Answers
Why not just get a differant radio capable for beacons. 406mhz is what they've changed to.
You used a part that was not compatable with your radio. The VX-150 has a differant size plug than the VXA-150
You'll need to take the radio to repair or bend the jack back to the size for the appropiate headphones.
Posted on Nov 11, 2008
My Vertex Standard VX-2200 display blinks continuously and when i press the ptt button it say error
Not enough power. The radio requires a steady 12 VDC input, or in a vehicle, 13.2 VDC. You did not mention if this is a 25 or 50 watt radio. I guess 50 watt. This occurs often when the wire is too thin for the amperage required. Get thick wire or the harness may not provide enough amps and it will get really, really hot! The wiring harness from Vertex is the best one. If you have checked all your wiring AND the power connections, it is less likely a programming error. Let us know!
Jul 12, 2017 | Vertex Radio Communications
How to reset vertex 426
Maybe this will help: Vertex standard vx-426 owner manual Download Vertex standard vx-426 owner manual :
https://vwjqovoy.files.wordpress.com/2015/08/vertex-standard-vx-426-owner-manual.pdf
Jan 31, 2017 | Vertex Radio Communications
Problem: tamper system mode entry password
Password protection was installed by the dealer. You must take the radio to an authorized dealer for reprogramming.
Oct 08, 2014 | Vertex Yaesu Fnb-v57 Fnb-57 Vxa-120 Vx-180...
Vertex vx-3000l windows loading software
You need the Vertex radio programming software for that particular radio model and the programing cable. This is available on the web if you search for it.
May 26, 2014 | Vertex VX-3000L VHF Low Band Mobile Radio,...
Help with Vertex VX-3200 Programming
You may have to find a windows XP or earlier machine. That software doesn't always play well with WIN7
Mar 06, 2014 | Vertex Vx-3200 / Vx-2500 Series Programing...
Vertex 2200 transmits but makes no sound
You mean NO Audio Transmit?
If there is No Audio at PTT Bad MIc Cord.
Change the Mic cord.
Dec 01, 2013 | Vertex Cd Vx-2200 Vx-2100 Series...
I'am having some problems with vxa-100 getting verry hot
The walkie talkie is the heat sink. So on extended talk times, it will get hot. So will the battery. If you run full power, it is only worse. That said, some batteries will become abnormally hot with use. Usually OEM batteries are higher quality cells and seem to get a little less hot. Never buy the cheapest battery for a handheld radio. Some are pure junk.
Mar 25, 2013 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Hello I just bought a Motorola 53725 SLK Headset with Swivel Boom Mic (Black) for my Motorola FV200AA 5-Mile and I have a problem to hear. They can hear me but I cant
Two things to check. Make certain you are plugging in the headset with the radio shut OFF. Also be certain the headset is plugged in all the way. You should feel a slight click when it is seated properly.
If the headset has an in-line PTT, don't alternate between it and the one on the radio. If there is no in-line PTT, use the PTT on the radio unless you have your radio set for VOX.
If using VOX mode, do not touch the PTT at all once you turn the radio on. One thing to keep in mind if using VOX, the receiver will pick up any ambient noise around you and think it is voice and keep your radio locked into transmit. Vox only works well in a somewhat quiet environment.
I've probably given you more info than needed, but wanted to cover all the bases.
Sep 28, 2009 | Motorola FV200AA GMRS/FRS 2-Way Radio...
Vertex radio vx 10
Maybe with the drop the radio speake is out of place, did try to open the radio and find if the speaker is in its correct place? The speaker uses a spring connector and this can be out of place. Good luck
Jun 22, 2007 | Vertex Yaesu Radio FTH2009, FTH7009...
Radio Communications Logo
239 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
