Question about Audio Technica USB Turntable
Prolectris USB 3 speed turntable
I am having problems getting this turntable to play more than 20 seconds of a vinyl record before the pick up arm returns to its rest and the turntable stops - any ideas as to whats going wrong? is it soething im doing or is this unti just faulty?
If anyone can help would eb very grateful
Cheers
Colin
4 Suggested Answers
  • 42 Answers
SOURCE: I have a AT-PL50 turntable.
Your submission was incomplete. Please resubmit.
Posted on Jan 25, 2009
  • 8 Answers
SOURCE: AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Posted on Aug 18, 2009
Grubhead
  • 5342 Answers
SOURCE: I bought an Audio Technica USB AT LP 120 Turntable
Sorry it could be the cartridge! They can fail at anytime, only the stylus will wear with time. However it could be the amplifer's magnetic cartridge pre-amp. If you look inside your amp and trace back from the phono socket you should find the pre-amp. If it is distorting on both channels it's probably an IC that has failed.
Posted on Dec 05, 2010
Crosley Cruiser turntable vibration noise
How to Identify Damage in Your Record Player ' eBay
www.ebay.com > ... > Record Players/Home Turntables
They produce audible sound by reproducing sound vibrations from tiny grooves etched on the surface of vinyl records. Record players have three primary ...
Crosley Cruiser Turntable Review - YouTube
? 2:26
https://www.youtube.com/watch?v=w5KVANeimVU
Dec 8, 2013 - Uploaded by DTM
This is a review of the Crosley Cruiser turntable. ... cartridges (the mechanism that converts the vibrations of ...
Just getting into vinyl. Is there any way to improve a Cros
Dec 14, 2015 | Crosley CR8005A-TU Cruiser 3 Speed...
I have a LP60 USB and theres a burning smell coming from the platter?
You mean while playing a record?.... I shall tell you a secret, eveytime you needle plays a record, it melts the vinyl a bit , just like that you can ice skate and melt the ice through the pressure.
But if you smell your vinyl then your needle is installed very wrong.
And needs to be replaced.
Pls read this http://www.whathifi.com/how-to/how-to-set-turntable.
if you smell your platter, without playing a song , you have to watch if. it spins at normal speed without variation, then you can remove the platter and give your bearing one drup oil. But that ain't the problem.
you have to smell the motorunit, since it's a cheap turntable and ain't having good components, but start with following that link i gave you and you only have a motor with some electronics , a belt
and a bearing with a platter and in your case a builtin usb and phono-amplifier which are useless, because the quality is way too low. not much can go broke.
Mar 22, 2015 | Audio Technica USB Turntable
Needle jumps on all new vinyl, but plays old records fine. New vinyl plays on other turntables without a problem. Do you have any suggestions?
Adjust the balance force up. This is a counterweight on the back of the arm. For most needles it is 1-2 grams.
Jul 06, 2014 | Crosley Audio Players & Recorders
MY TURNTABLE START PLAYING ON THE SECOND SONG OF THE 33" VINYL, WHAT IS THE PROBLEM
Do you have a switch to select the size of the record as well? We had a record player that could play 7" singles at 33rpm (floppy vinyls given away by Sunday papers). We had to select 33rpm and also 7" on a separate lever for this to work.
May 23, 2014 | Marantz Audio Players & Recorders
ION Profile LP Vinyl-to-MP3 Turntable, tone arm won't drop
I've got the same problem. When you put therecord on, spin it from the centre, and it will release the mechanism inside,this is what I do, and it works fine. I think the problem is that there are twoplates under the turntable, and there was grease between them, after a few goesthe grease disappears, causing the problem.
May 22, 2012 | Audio Players & Recorders
Jensen JTA 450 turntable skips?
Try moving the arm up to the end of the vinyl, if it does go till the end of the vinyl then try adjusting your counter weights, a penny will do, if it doesn't go till the end of your vinyl then there's a mechanical problem check any obstruction at the botton of your arm.
Jun 09, 2010 | Audiovox Jensen JTA450 Turntable
Digitech turntable - skipping stylus and arm
You might need to apply more pressure to the stylus. There should be a weight on the end of the arm, it should have a control to move it up and down. The only other thing is the stylus damaged from transit?
Feb 02, 2010 | Audio Players & Recorders
My prolectrix usb turntable won't play properly
i also have the same problem, im sure its something to do with the tone arm, like at the start of playing a 12'inch you have to hold the arm at the end of the vinyl for 5 seconds, have i answered my own question, i'll let u know ......
Jan 06, 2009 | Audio Players & Recorders
Arm does not track properly but skips across records
Just guessing, but it sounds like you haven't counterbalanced your tone arm.  When a tone arm skips, it's usually because there's too much counter weight on the rear of the tone arm.  You want between 3-5 grams, but first you have to calibrate your tone arm (balance it so you know where zero is).  If you don't know how to do this, refer to the Ion directions called "Tonearm Setup" in the instructions.
Jan 03, 2009 | ION Audio iTTUSB Turntable
Audio Technica USB Turntable Logo
35 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Michial Gueffroy
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
