Question about HP Office Equipment & Supplies
Slides from H.P scanjet
I have transfered my slides on H.P scanjet 4370 image zone, they in albums in the order I want them to remain on a CD However when I use H.P share to put onto CD the slides go totally random. I have numbered them and try all sorts What do I need to do?
  • 1 more comment
  • Grace 04 Sep 06, 2008
    Sorry but there are no names on the slides individually and even although I have right clicked and renamed to alter the file number on each slide so that one set can run in sequence it has no effect
    i HAVE JUST TAKEN A SMALL ALBUM OF 20 FILES(SLIDES) USED THE IDEA OF NUMBERING THEM ALAPHABETICALLY AND FINISHED UP WITH COMPLETE RANDOM AGAIN
  • Grace 04 Sep 07, 2008
    I have no problem burning CD using Nero but I still have to transfer slides to a C.D. IN AN ORDER BEFORE BURNING,unless there is a piece of computer skill I don't know about?? My problem is HOW do I move slides from H.P image zone using H.P Share AND keep the slides in the order that they are in their present albums.I feel this is a specific H.P problem I have used their electronic solution site, and it shows me how to do masses of things most of which I have mastered. HOW DO I STOP SLIDES CHANGING POSITION WHEN BEING PUT ONTO A C.D FROM THE H,P. IMAGE ZONE?Is there someone out there that has used a H.P scanner????
    Master:
  • 726 Answers
Try to do them in a to z order
Posted on Sep 07, 2008
  • 535 Answers
U hve to reinstall the driver of your printer
    Genius:
  • 1,269 Answers
On the HP Share settings, look for an option "Automatically straighten scanned images," its a checkbox make to check it.
You can also try to use a different software if that doesn't work.
ScanPDF
Reinstall just the printer driver and don't include the scanning utility or the HP Share. Then install the SanPDF software.
Posted on Sep 06, 2008
    President:
  • 2,712 Answers
Have you tried using Nero to burn them? It could also be that they are arranged by date.
    Genius:
  • 1,847 Answers
Name the file in alphabetic order and then try.
  • HP Master
  • 13,433 Answers
On the cds, they are most likely sorted out in alphabetical order of name. I suppose you will need to rename your albulms accordingly or if you could shead some more light on the issue that would be great.
Thanks,
E
  • Ekse Sep 06, 2008
    Slides.. as in scanned image files.. You could put the slides into a pdf file so they would stay in the right order - do clarify a little about the slides, im not completely sure what you have there.
I have connected the TMA to my hp scanjet and I have put a slide in it, but when I scan it, all I get is a scan of the whole glass and the slide is black.
When scanning slides and negatives the scanner lid lights up so light passes through the slides and negatives and the image is picked up by the sensor.
If the image of the whole glass is black then most likely the lamp in the lid is faulty.
Aug 19, 2011 | HP Scanjet 4570 Flatbed Scanner
I need the driver for scanjet 4370
www.opendrivers.com/driver/229088/hp-scanjet-4370-series-scanner-solution-center-software-v5.3-free-download.html
check out this link to get a driver u need
Jun 17, 2009 | HP Scanjet 4370
Will not scan the pictures off the 35 mm slides, it just copies the slides
As HP there helpfull you will have a web link on you setup CD-Rom if not phone them there helpfull.
Mar 05, 2009 | HP Scanjet 4370
HP Scanner 3570C-can not scan my slides
According to the manual, you should always scan from the HP scanning software to scan slides using Scanjet transparent material adapter. There is no button that you can set for default slide scanning properties. This is shown on page 8 of the manual for the 3500 series scanners. The manual is available here: https://www.manualslib.com/manual/72847/Hp-Scanjet-2300c-Series.html?page=13#manual .
Since the scanner works with pictures, make sure that the TMA adapter is plugged into the back of the scanner. Next open the software, HP Photo & Imaging Director. In most versions of Windows, press Start and look for the HP programs heading. Expand this to find the executable file. Alternatively, find the icon on the desktop or find the software in the file explorer (Program Files/HP/ on 32-bit versions, Program Files (x86)/HP) and then the appropriate sub-folder. Now try to scan the slides when they are loading in the adapter.
I hope this helps. Please add a comment with your OS if you are still having problems. Some newer OS versions may have installed generic drivers for the ScanJet 3570C. The generic driver might not communicate with the TMA properly.)
Jul 12, 2017 | HP ScanJet 3570cv Flatbed Scanner
I have recently purchased a HPScanjet G4000 scanner to scan slides. I have successfully scanned my slides into the computer but I don't know how to transfer them to a DVD
Hai...
I hopes that ur HP Scanjet's driver,
when ur scanned photo or other file just specfic path to save ur file.... Before must u have a CD-writer software like Roxio and Nero.,
and also insert ur Blank CD....
If solved ur problem by me and other person jsut inform me at mani@merittech.co.in
"Do not forgot to rank it"
Thanks and Regards.,
//anikandan
Dec 18, 2008 | HP Scanjet G4050 Flatbed Scanner
Scanning slides on scanjet 4370
I lost the owner's manual and I don't know how to scan slides! Please help me
Oct 03, 2008 | HP Scanjet 4370
Won't scan my image
Dear Sir,
I want a HP Scanjet 4370 Softwear Download my Computer. And pls confirm where is place of Delhi (India) & How Much the Price of HP Scanjet 4370 Adaptor?
Thanks
SAM
May 01, 2008 | HP Scanjet 4370
HP scanjet 4370 focus problem
adjust the brightness resolution or default settings for scanner while scaning. Also read the manual of the scanner.
Aug 25, 2007 | HP Scanjet 4370
Ben Johnson
