Question about Teac P-A688 Turntable
Arm trouble I just took my Teac P-A688 out of storage for most of a year, and I'm having some issues. Firstly, it doesn't have a belt. I'm definitely getting a new one. But apart from that, the arm isn't lowering when I try to get it to do that. How to I fix this? Does it have to do with not having a belt?
  • 10,594 Answers
If its automatic unit, it need belt to complete its mechanical cycle of loading and unloading its arm. You can check arm movement by spinning its table by hand.
Posted on Sep 05, 2008
Need a diagram of the belt configuration
Check out YouTube there are some standard videos on belt replacement that might apply to your model.
Oct 14, 2015 | Teac P-A688 Turntable
Need a new belt
Measure the old belt, make certain you know how it fits before removing. You need the diameter and width in MM. You don't need to be spot on with these! Put the results with the words "Turntable belt XXmm by XXmm" into Google.
Aug 13, 2013 | Teac P-A688 Turntable
My teac p-595 turntable has a grounding wire that is looped at one end but I don't know where the loop goes. The wire on the other end is fastened to the receiver.
The ground wire should be attached to the metal chassis or the tone arm metal assembly, the other end should be attached to the metal chassis of the amplifier. If the ground wire is not used, you will get real loud hum through the amplifier.
Nov 23, 2010 | Teac P-A688 Turntable
REmoving needle from my P-A688 Teac Turntable
THe stylus should just pull forwards out of the cartridge, but with care.
Dec 23, 2008 | Teac P-A688 Turntable
Teac P-988 Everything sounds slow/warped
not passing the "wow and flutter" specs, eh?
The most common cause of this is a loose or defective belt. An inferior belt will have varying thicknesses along it's length. When it hits a skinny part, it will slow slightly. When it hits the thick part, it will speed slightly. Overall effect is that the record sounds warped.
needledoctor.com has got some good stuff.
Jun 12, 2008 | Teac P-988 Turntable
The belt on my turn table came lose
http://www.archive.org/details/Turntable_Belt_Installation
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things. if it keep coming off they can help you size a new one.
May 10, 2008 | Teac P-A688 Turntable
Too slow?
this can be caused be a new belt being too wide, you may need a narrower belt.
Dec 22, 2007 | Teac P-A688 Turntable
Teac turntable belt came off.. help!
Through the 2 holes on the platter, lift the platter up. Take the belt, flip the platter over, and stretch it around the center ring. Flip the platter back over and turn to so one of the holes is over the spinning motor. With your finger or with a blackstick, stretch it back onto the motor head.
Also check the belt for wear....that should do it.
Keep me posted.
Dec 05, 2007 | Teac P-A688 Turntable
Teac P-A688 Turntable Logo
191 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
