Question about Dryers
Simpson sirocco 350 clothes drier
I think I have overloaded it with a queensize light bed quilt and the safety switch has turned on can you help me locate it and turn it back on. Thanks Isabel.
  • paste Sep 06, 2008
    found safety switch on opening now working fine thank GOD.
    Problem Solver:
Yes fixed with prayers I found the restart safety switch and am now dring merrily,.Paste
Posted on Sep 06, 2008
Simpson clothes dryer sirocco 455 5kg the power shorts out when we turn it on ?
check the heating element.remove back panel to access it
May 31, 2015 | Dryers
Is it a big job to replace the heater element on the Simpson Sirocco 350 dryer?
It won't be the element unless a wire from it is grounding against the casing. You most likely have some sort of issue with the home breaker.
Mar 15, 2014 | Kenmore 500 6952 Dryer
Clothes dryer stopped working while it was working Simpson Sirocco 455, what could be wrong?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 26, 2011 | Dryers
Simpson sirocco clothes drier tumbles ok, but heater not working
Bad heating coils, or bad ignitor if gas.
Jun 21, 2010 | Dryers
My Simpson Sirocco 3500 clothes dryer emits burning smell!
1)check for something stuck between drum and dryer housing 2)check for stuck vent flapper at exhaust opening outside 3) check dryer lint screen
Nov 05, 2009 | Dryers
I have 2 simpson sirocco 350 dryers and neither will dry clothes as soon as a bit of heat happens they turn off is there something that I did'nt take out of them when Ifirst got them? Hoping you can help....
difficult one , but drier will typically switch off if the over temp. sensor activates. Suggest you move the drier away from the wall or any area that could block air flow into the air ducts and retest. Very unlikely both would do the same thing. Common denominator is its position..
Sep 14, 2009 | Siemens Dryers
When the dryer is on high or medium heat, it trips the power breaker of the house. it does not do this on air only/no heat", which makes me think of a short in heating unit.
the dryer is run by a universal motor, and these motors (while being very robust) can draw more current if the torque put on the drive train is overloaded. try running dryer with less clothes.
May 12, 2009 | Dryers
Simpson Sirocco 350 Dryer not heating
I repaired my broken fan belt with a drop of super glue - there is virtually no load on the belt and it now works perfectly again. A 30 sec quick fix.
Mar 21, 2009 | Dryers
Condensation is forming on the walls when I use my clothes dryer
Simpson may have a kit available for accomplishing this. Also, your dryer may have several optional ways of venting.
Mar 27, 2017 | Dryers
Dryers Logo
351 people viewed this question
Top Dryers Experts
