Question about Ovens
Gas ignition problems
When you turn on the gas on the oven the ignitions on all 4 hobs starts clicking this carrys on for a while untill it stops on its own?
  • robturner70 Sep 06, 2008
    thanks but it has not been like that for 2 years just started happening and it carrys on after the oven is light thanks anyway
If you provide the brand and model number perhaps I can assist in diagnosing the problem further.. When posted as generic, it is difficult to provide an accurate assessment and a solution...
Posted on Sep 06, 2008
  • 706 Answers
Many gas stoves are designed to switch all top igniters on at the same time.. that may be normal for yours.. many will continue to cycle several times and then stop.. You may not have a problem..
  • Rick Gelin
    Rick Gelin Sep 06, 2008
    I don't recall if you provided a specific brand and model number of your stove.. If that wasn't part of your description, please add that is so I can dig in a little deeper and assist in solving your problem.. Just trying to help..
Main oven works but the ignition keeps clicking while oven on
check the operators manual or with a servicing agent
being gas it may require the clicking to reignite the gas when the temp starts to cycle or there may be a problem in the control system for the gas operation
May 04, 2016 | Ovens
Oven wont turn on
I have a delongi oven and hob hob is working fine but the oven isnot im turning the nob on the front of the oven and ignition on lighting is fine after I release the knob on the front the supply turns striaght off no flame no gas nothing
Apr 04, 2011 | DeLonghi Ovens
Gas hob continually clicking, as though wanting to ignite gas rings, all 4 of them pleasr help its driving us mad, cant switch off at mains as i it switches others off.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
Jan 05, 2011 | Ovens
Oven slow at starting, there is smell of gas before oven turns on
If there is a smell of gas PLEASE STOP USING IT you risk fire or explosion or both. Please get a registered Gas-fitter to look at this. If you can Turn OFF the Gas at the Wall/Outlet. Until it can be looked at. If you smell gas it is very dangerous.
Feb 11, 2010 | Ovens
Eventhough oven is on and working o.k the ignition still carries on clicking
I would have this properly diagnosed by a gas technician. But I would have to guess it may be a problem with your spark module. It is a plastic and insulation type housing that carries the current to the burner heads to ignite the gas. When faulty it can cause this effect. Hope this helps
Thanks.
Jan 03, 2010 | Ovens
Igniters will not stop clicking.
Hi
Thanks for using FIxYa.The igniter doesn't stop clicking due to a short inside the igniter circuit or due to moisture present on the ignition switch.Turn off the gas supply immediately and also unplug it from the mains power. Now take a blower or your hair dryer and blow hot air over the igniter. Also check for the following troubleshooting steps---
1) The gap between the igniter and the burner base is too large. *Should be approximately the thickness of two dimes.
2) Soiled igniter or burner base.
The above can be tested by switching the suspected burner with a known operating burner.
3) Loose wiring connections at the igniter, the grounding strap, or spark module.
4) Broken or pinched igniter wire between the burner and module.
Both of the above are physical inspections under the main top.
5) The module may have a week coil, which is not providing sufficient voltage to ignite the gas.
Even after performing these steps the igniter doesn't stop clicking then you need to replace the spark module.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 26, 2009 | GE Profile JTP18 Electric Single Oven
Ignition switch on a gas hob/electric oven not sparking
Some have a AAA battery under the button - replace this, others use mains to create the spark, ensure you have the ignition wired up
Jun 01, 2009 | Ovens
Ignitor problem with gas oven
The spark ignition coil is failing. As this is an oven, it can be dangerous not to have a strong ignition spark. A gas buildup in the oven could cause an explosion.
You should replace the spark generator coil which is located at the back of the oven and is usually orange/black or blue in color. Ariston usually use ITW Ispracontrols ignition coils.
Mar 26, 2009 | Ovens
Hotpoint EG54P ignition sparking by itself
The reason it stopped was you need to push down to activate the switch and turn on the sparking be careful about getting water down in the unit ..Glad to Fix Ya plz rate my answer
Feb 23, 2008 | Ovens
Ovens Logo
160 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
