Question about Microwave Ovens
Floor standing fan
Why does my floor standing fan not send out cold air?
    Champion:
  • 225 Answers
Check fan motor or control relay.
Posted on Sep 06, 2008
How to change bulb
First you get a person to stand on a chair and hold onto the bulb, then you get another person to turn the chair with the person standing on it, after about 7 turns the bulb should come out. Be sure to turn clockwise when looking down at the floor. Cheers.
Jan 18, 2015 | Microwave Ovens
Panasonic steam convection microwave ceramic floor cracked and a hole melted into the ceramic field.
This was probably a manufacture defect right from the begining which would explain what happened. My guess there was a very small crack and quickly developed into serious problem.
May 18, 2012 | Panasonic NNCS596S Microwave Oven
Refigarator and freezer no longer cold enough. freezer is not freezing and refigarator is not cold enough, food is going bad. Unit is not yet 5 years old.
pull out the plug for the fridge and let it stand for 7 days then plug in after seven days.the problem is that the fan that circulates the air is cloged up with ice so you have to give time for the ice to melt off.
Mar 04, 2011 | Microwave Ovens
My refrigerator has a leak behind the drawers on the inside . I have since had to put a towel at the bottom of the drawers or it will start leaking down the front and onto the floor every couple of days....
Moisture condenses out of the cold air inside the fridge. Many refrigerators have a drain tube in the bottom to allow the condensate to run into a drip tray under the refrigerator (behind the trim panel on the bottom) where it evaporates. Over time this tube can get clogged by food particles and the water backs up, eventually running over the bottom edge onto the floor. You can use a straightened out coat hanger or other stiff wire to clear it out. This should get the water back into the tray where it belongs.
Jan 21, 2011 | Microwave Ovens
Our Spacemaster Microwave can make occasional loud grinding or vibratory noises--deep and low sounds. Solution?
If it has a turntable, the wheels are worn or dirty and are chattering. When I have this problem, I take out the turntable, clean up the floor of the oven, the bottom of the plate, and the wheels on the turntable ring. Then I push a small amount of paste wax (made by S. C. Johnson) onto the axles inside the wheels to lubricate them. (I've kept my worn-out turntable ring going for over 10 years by doing this.) If the turntable has a central post through the floor of the oven, the bearing may need cleaning and lubrication.
Other possible causes would be the bearings in the magnetron cooling fan or the microwave stirring fan in non-turntable models. Excessive dirt on fan blades can cause imbalanced running, which will also generate vibrations.
Dec 30, 2010 | Microwave Ovens
My micro oven is not working properly. I would like to know the service centre no. at kolkata. Please do the necessary action at your end please.
Dakshina Electronics
18/8D Parijat Apt.GRD.Floor, NR.Nutun Para Vidyabharti School, Birren ROY Road West, Behala, Kolkata - 700034 (33-66348350)
Techno Plus Services Pvt Ltd
17 L, East Road, Jadavpur University, Kolkata - 70003(66342335)
Sengupta Rlectronic Service Center
26, NR Bagalamukhi Mandir & 3A Bus Stand, Thakurpukur Road, Thakurpukur, Kolkata - 700063(66347532)
Perfect Enterprise
1, 1st Floor Room Number 113 Old Building, Beside Great Eastern Hotel, Abdul Hamid Street, Esplanade, Kolkata - 700069
Electric Doctors
3 Sector 1, B D Market, Salt Lake, Kolkata - 700064
Dec 16, 2010 | Sanyo Microwave Ovens
The freezer is working fine, I have removed the floor plate in the freezer to check if the drain was clogged and it was frozen but I removed it but the refrigerator is not cold. I checked the door switch...
Please reply with a model #, make, and what exactly is the problem?? the fridge part is warm?
do you hear the compressor running?
is the freezer the correct temp?
Thanks!!
Aug 14, 2009 | Microwave Ovens
Fan on left makes awful noise as if grating or knocking
Remove fan and check for loose debris or screw that is hitting the fan.
Dec 13, 2017 | Panasonic NN-H275 Microwave Oven
Microwave Ovens Logo
131 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
