Question about RCA TruFlat 27F520T 27" TV
My rca tv
Hi my name is Bobbi JO and I have a rca tv.I wanted to know if you could help me there is a cable box hooked up to it however it comes in snowy and so I thought if I changed the cable wire it would help but now the channel on the tv it's self wont change.please help me Im tired of my children taken over my tv.thank you in advance.
  • Ginny Hartman Jan 01, 2009
    I have cable, no box hooked up but all of a sudden the channels wont change on the tv. I tried changing batteries in remote and using the front buttons, the number changes in the corner but the picture stays on the same station! Help!
  • Anonymous Jan 04, 2009
    Hi my niece gave me a 27in rca flat 27f520t and the tv keeps turning off and searching for channels. I do have it hooked up to satelite.what could be the problem?
    Scholar:
  • 188 Answers
The remote control may only work for the cable box and you may have to manually put the TV on the correct input channel also you might double check that the cable to the TV is hooked to the antenna input. Here is the website for the manual TV if you think it might help.
http://tv.rca.com/RCATV/Assets/pdfs/27F520T_1641312E_IB_e-06.pdf
Posted on Sep 16, 2008
Dvd/vcr recorder magnavox model mwr20v6, i got probelm hooking up my dvd/vcr recorder to my cable converterbox an tv , because i broke the antenne/ out socket on the back of the unit, how can i get it to...
Hi,If I understood correctly you broke antenna out socket of Cable box..ok no problem,your TV and cable box should have other jacs/socket for this connection as well..
Take the A/V output of your cable box into TV possibly with RCA cables..than you can select the channel thru Cable box on TV ..(AV mode needs to be selected on TV )
** in order to listen and watch your
magnavox DVD 's "2xRCA audio" and "1x RCA Video" cables "OUT" should go to Tv or Cable box "IN" connections separately ..("IN" goes to "OUT" of other ..pls remember,Always reverse connected ) (audio will come thru Receiver and TV.)
Since you successfully connected your Receiver to play video on TV (one way only ) ,here is the second reverse action if you wish to listen or RECORD a program on your TV on
magnavox
** you need to connect "Audio Output " as can either be : RCA jacks or "Optic cable output" or "SCART "connector " of your TV or Cable box .( every TV -cable box has different type of Audio out jacks )
** to "iRCA nput or "Optic Cable input"
of your
magnavox (whichever you want ,based on the necessary cables on your hand )
There you go..Tv/Cable box video and sound are both on the
magnavox for recording..
Hope this helps!..if more help requires pls let me know.
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 15, 2011 | Televison & Video
I have an RCA rear Projection TV model # p60812BL manufactured in 1998, no sound is coming from the tv when watching cable TV via a digital box. When the mute button is pressed and unpressed you can hear...
Tries tv and cable box unplug,replug it back like about an hour.For the tv resetting itself and the cable box to upgraded it softwares.Go into the tv menu go to Audio SETUP.Go down to audio ressetting,these steps should solved ur problems,but not call ur cable companny replaced the reciever box,it have problems.
Mar 16, 2011 | RCA P52926 52" Rear Projection Television
I have an RCA converter box hooked up to an RCA TV and a Sanyo VCR. The TV and VCR are set on Channel 3. The converter box is set on Channel 4 and the TV is also switched to CH 4 when viewing digital...
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Feb 27, 2009 | RCA Televison & Video
DVD Hook up-Olevia 266-T11
From Cable Or Rca Out Of Your Dvd Player To Your T.v. Make Sure You Push The Tv/Video Button To View The Dvd If Its Hooked Into The Rca Jacks.
Jan 14, 2009 | Olevia LT32HVM 32 in. LCD Television
DTV hookup for an RCA XL-100 TV
Buy a box modulator which have RF input then have RCA output that's input to your TV or other option below.
Just click and choose whatever hooked up connection you want;
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ..
Plasma or Video Projector Wiring Guide
Blue-ray Surround Wiring
HP TVs - TV Cable and Connection Types
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Jan 07, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
Want to hook up Zenith converter box with RCA F25432 TV
Generally you just use either the F port (used often for cable or coaxial connections) or the RCA (composite) inputs.
Jan 05, 2009 | Zenith C27A24T 27" TV
Setting up Panasonic SC-HT930 to Cable Box & TV
I am glad to assist you fully. I need the complete model of the TV and i will be able to tell you exactly how to hook it up. What connection/cable are you using from the cable box?
Thanks,
Lee
Jul 04, 2008 | Panasonic SC-HT930 System
RCA Model # F36650 tuner.
if your tuner is already dead replace it.because the original tuner of your TV is very expensive. the solution of your TV is converting tuner, you buy a kit name AUDIO TV CONVERTER . simply conection and and not very expensive. just plug the unit to ac line and connect the cable line to rf of your Television and its OK. im just trying to suggest my solution to you JRANDY phillipines tech
Apr 19, 2008 | RCA F36650 36" TV
Rca vcr
there a a bunch of different ways. 1) if you don't have a cable box hooked up to this tv,plug the main cable wire into the vcr input then the vcr outout to the tv.2) if you do have a cable box, plug the main cable into the cable box input, then the output to the vcr input, then the vcr output to the tv. put both the tv & vcr on channel 3 for this connection. [ you must have the vcr on channel 3 to record from the cable box!] 3) if you have aux line/video or source inputs on the back of your tv,you can hook up rca cables [ red, white,& yellow ] from the rca outputs on the vcr to the tv inputs.
hope this helps
wg
Feb 04, 2008 | RCA VR637HF VHS VCR
Hooking up the PIP along with cable and a combo dvd/vcr recorder
From cable box,hook-up yellow,red and white to video input on TV ...Select that input, activate PIP...........Note:Split signal &
give 1/2 to cable box and 1/2 to Antenna A input on TV then hook RF out to tv to Antenna B................Let me know...T.
Dec 12, 2007 | RCA F35673MB 35" TV
RCA TruFlat  27F520T 27" TV Logo
144 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
