SOURCE: HDMI Malfunction
You may have to activate that imput through your menu.Alot of plasmas have the ability to mute imputs.
SOURCE: setting up tv sound to come thru stereo speakers
Offhand, your Philips 32PFL7422/98 do not have regular Audio Output RCA jacks (white and red), sorry. However, right before the antenna connector is an S/PDIF output connector. This should allow transfer of digital audio signals from the Philips 32PFL7422/98 to a S/PDIF capable receiver or amplifier. If you would look at the rear of your stereo and determine if it has such an input, then it would be a matter of getting the right cable/connector.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
SOURCE: 32 in Astar LCD won't recognize input signal
Hello, According what you saying not recognize any iput. Then your main board is defective.
The HDMI and the YPbPr are the same connection according the main board build. Any other question please call 323-767-6030.
SOURCE: HDMI Input only reads Digital TV and not PS3 or AV Receiver
Well, I won't take the credit of others. Many people have the same problem as you do.
In the search box on the top of this page, put in " PS3 HDMI ". The one that has the 10 solutions so far has the best answers for you.
Good Luck
SOURCE: Trying to find a port for sound input on Philips DVI LCD TV.
If it is two-channel sound, the 'line' inputs should be color-coded as red (right) and white (left).
You have several options for connecting your DVD player to your GV42L FHDTV10A - HDMI,
Component, S-Video and Composite (AV) inputs. Based on your home theater configuration, you can
decide which option is the right one for you.
connected to the HDMI input of the VIZIO GV42L FHDTV10A for optimal results.
To maintain the display quality, use a VIZIO certified HDMI cable available up to 10 meters or less.
1. Turn off the power to the LCD HDTV and DVD player.
2. Connect a HDMI cable to the HDMI output of your DVD player and the other end to the HDMI
Input (white color area) at the rear of the LCD HDTV.
3. Turn on the power to the LCD HDTV and your DVD player.
4. Select HDMI using the INPUT button on the remote or side of the LCD HDTV, or directly by
pressing the HDMI button on the Remote Control.
a) If you are already using the HDMI 1 input for another component, or you do not want to use
the HDMI 1 input for the DVD player, you can connect the DVD player to the HDMI 2
connection.
b) Refer to your DVD player user manual for more information about the video output
requirements of the product.
OK
