Question about Archos 604 Digital Media Player
604 - how does ribbon connect on the unit side
Mine's apart, from a fall, and connected to the HD but not the unit. Can't wuite see how it's supposed to go back, I know there is a black piece over a white piece, but....
The ribbon cable should slide into the connector but be careful since that latch can break.
Mine broke.
Posted on Sep 19, 2008
  • John Mills Jan 27, 2012
    Mine broke as well. Unfortunately, Archos says because its discontinued they can't repair it. Do you have any idea where I might be able to find that latch to secure the ribbon cable?
  • Edward Clark
    Edward Clark Oct 20, 2017
    No. Sorry. I used tape.
When switched on goes to a HDD Recovery option but when options tried a Media Failed message is received and 604 returns to the original screen
I have the same problem and I do not know how to fix it. The problem with mine is that I have replace the hard drive with a new one so it does not have the original files. Does it connect through the USB connection and does the computer detect it?
May 20, 2009 | Archos 604 Digital Media Player
Simmons model 229060 drop rail is falling out
There should be a couple of little plastic clips (curvy) on the bottom of the rail, last stop before the floor. If one or both are either missing or broken it will simply fall out. Call Simmons directly (www.simmonskids.com for the phone number) and they can sell you the pieces. Mine came in about 3 days and they're very easy to replace.
I hope this helps!
Mar 29, 2009 | Simmons Mattress Venetian 229060-52 Crib
A thin ribbon made from plastic fell out of printer, where does it go? Printer model:2400 all-in-one. part 1/4inch by 12 inches appr.
have a look at the ends of the ribbon to see if any of the connections are exposed, they will look like brass or gold, if they are you may possibly be able to put is back in place. the ribbon goes in the ink carrage at the right of the printer (the unit that slides up and down to print accross a page) and is also connected to the left or right hand side of the printer, this is all internal and you have to take the printer apart
If the plastic coating covers the whole ribbon cable, or just at one end, this means the ribbon cable has snapped and you will probably have to buy a new printer
good luck
regards
Nov 18, 2008 | Computers & Internet
Archos 604 hard drive problem
there is a nice pictorial dissasembly at this site:
http://archos.grimchuck.com/disassemble-tuto/EN/index.html
Sep 01, 2008 | Archos 604 Digital Media Player
SCSI vs. SATA vs. PCI Controllers
to use your external hard drive as boot drive you will need to set bios to boot from it if the bios allows you to
i do not know which section of the dell bios it is but it will have boot order or similar you will have to follow instruction to set it the main problem having extenal boot is windows will not install to USB devices
As for the hard drive from dell it could be a sata drive they sold you you need the standard one
Hope this helps your dilemma
Jul 31, 2008 | Adapters.com Video to Monitor HD-15...
PS2 Ribbon
There is but you must open the system and take it ALL apart then reconnect it!
UNLESS you pulled it from the shell.. There is the led lights which are connected to the shell if you actually tore the ribbon then get a new ribbon and shell on ebay 10$ ish!
If not tear it all apart and re-insert the ribbon to the bottom unit which holds the laser. If you need pictures of what I am talking about let me know as it is a complicated process which took me a full hr when the system first came out!
May 26, 2008 | Sony PlayStation 2 (PS2) Console
Archos 604, frustrating problem.
Ribbon on hard drive came loose, take out battery. remove 2 screws on inside of battery compartment (not the ones mounting the plastic frame) remove 2 screws on side of unit(not all four, tough to get back together if you do. take ribbon and reset it into hard drive first, then unit. slide battery back on and backcover, turn on, problem sould be sovled. If not, try again the ribbon is not seated. it took me 3 or 4 times, about half an hour, with jewlers phillips-head screwdriver. my Archoes was a 604 wi-fi but it shoud work pretty much the same on 404, 504, 604, 605, 705 605 wi-fi, and 705 wi-fi.
Mar 24, 2008 | Archos 604 Digital Media Player
No Image at the back screen
When I took mine apart and reassembled it, the same thing happened to me. So I reopened it and rechecked all of the connections. First of all, on all of the ribbon connections, there is a black and a beige part. First, stick your fingernail underneath the black part where the ribbon is supposed to be plugged in and then lift up. This will pop the black part open to allow you to plug the ribbon in well. Push the ribbon into the connection as far as you can, and then reclick the black section back down to ensure a good connection. Once I redid this, the screen worked again. I know thats a simple solution, but don't know if you tried it yet. If thats not the case, then it could probably be a number of things.
Dec 05, 2007 | Sony Cyber-Shot DSC-P41 Digital Camera
Media centre control panel not working
You may be having the same problem I have. There is a ribbon cable that connects the front panel to the main control board. Mine has pulled loose where it connects to the printed circuit board that the buttons "connect" to. I would not suggest taking it apart. I'm in the process of trying to find someone who can repair mine.
Aug 11, 2007 | Bose 3 2 1 GSX System
Display problems
The ribbon cable is a VERY common problem on these units. Mine went out and I picked up a replacement cable on ebay for under $20. If you are at all mechanically inclined, you can replace it yourself fairly easily. It is a little scary to look at your stereo in a bunch of pieces on the table, but is really an easy fix. Take the flip-face off of the main unit and you will see the ribbon that connects it to the main box. You will need to take the face place apart (it comes into 3 pieces, the front back and middle). When you see where the ribbon connects inside the face, pull back the little clips on the side and slide that end of the cable out. Mine did not look broken, but replacing it fixed the problem. Take the top off of the main unit, and unscrew the disk drive. Once unscrewed it will lift right out (it is plugged in on the bottom so just pull straight up until it comes free). Once you have that out of the way you will see the ribbon. This end is a little trickier. It is wound around a little spring that lets it in and out as the face moves. Look carefully at how it winds through the spring - you will need to put the new one in the same way. (it may help to take a pic of it to reference when you put the new one in) Unclip this end of the ribbon like you did the first. The new one needs to go into the main unit first. Install this the same way you removed the old one, around the spring, and through the slot that will connect it to the faceplate. Connect the other end to the face, then put the face back together and reconnect it to the unit. Replace the disk drive and the top of the unit, and you are done. Its pretty self explanitory when you are doing it, just take it apart till you see the ribbon, then put it back together the way it came apart. It's fairly easy, but be honest with yourself. If you are not good at mechanical issues, have someone help you. Good luck!
Jun 04, 2007 | Sony CDX-M800 CD Player
Archos 604 Digital Media Player Logo
116 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
