Question about Stoves 600SiDOm Gas Kitchen Range
Knobs don't turn
We have just purchased a one year old Stoves gas 61gdo, secondhand. When we got it home the knobs seem stuck fast. We don't want to turn them any harder in case they break. We telephoned the seller and asked her if she knew of any problem with them but she said it worked fine when she had it. It had no contact with anything whilst in travel so I can't make it out. Any ideas.
Try lifting the lid, this is a safety feature built in to the stove.
scooby runner
Posted on Oct 16, 2008
Manuel for stoves panache 600 SIDLm
Gas knobs are usually push-and-turn.
Feb 13, 2015 | Stoves Kitchen Ranges
Stoves 61gdo main oven not lighting
the thermocoupler is at fault it will need replacing if its stuck on pilot the thermocoupler heats up a small capilary tub that swiches the control to the temp regulator
Nov 23, 2011 | Kitchen Ranges
We have an old O'Keefe and Merritt stove in a
on most stoves where gas line connects around back should be a gas shut off valve if none put one on
Jun 06, 2017 | Kitchen Ranges
Replace seal on Stoves 61GDO, model no. 44444557- last digit has rubbed off with age
444445572 Gas double oven - stainless
http://www.espares.co.uk/parts/cookers-and-hobs/stoves/444445572/p/1092/630/0/914923
It has two different seals on that website, but I think It'll be obvious to you which one you'll need.
Mar 05, 2011 | Ovens
Gas range won't ignite. We had PGE and come over
This sounds like a failed burner igniter, also called a spark module. These are pretty easy to replace since the module itself is located at the back of the stove under an access panel. The price is around 40 to 60 dollars. Lately it seems that these newer stoves have weaker spark modules. I see dead modules on models less than 2 years old, where it used to be more like 5 or more years on the older ones.
Mar 24, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Pilot valve will not turn
Hi do not remove the screws it will be safer to change the gas valve
Jun 05, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
No gas getting to bbq
I switched to the new style 20# tank with the new turn-on knob.  I couldn't get enough gas pressure to the BBQ burners for all three burners to light or to keep a strong flame on even one burner.  The new style tanks have a safety valve on the inside of the tank that shuts the gas off if you turn the knob on too fast because the safety valve thinks there is leak.  Shut everything off and then try turning the knob on real slow, especially at first, before turning it all the way on.  If that doesn't work (it didn't for me), then replace the large plastic connection valve knob (female end) that attaches the regulator to the tank.  Mine was for the old style tank and was black (low pressure).  I went to a propane company and had them replace it with a green knob (higher pressure).  Took it home and WALA!  Everything works fine now.  But it was very frustrating trying to figure why I couldn't get any gas to the burners after buying a brand new tank.  I hope this helps solve your problems.
Sep 15, 2008 | BBQ Guys BBQ400C/G42 Grill
Stoves 600SiDOm Gas Kitchen Range Logo
485 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
marley mcelhinney
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
