Question about Garden
Lawn mower I was wondering if I could use transmission or power steering fluid in my lawn mower or is there a special oil for it?
  • mike kyle
    mike kyle May 11, 2010
    ... depends what you need to do? as for the actual oil for the mower id reccomend using oil bought at a lawn and garden store.
Definitely do Not use these oils in your engine! Any good motor oil of the right viscosity will work, such as 10/30 or 10/40.
Posted on Sep 10, 2008
Left hand drive handle hard to move forward
drain and replace your hydraulic steering system oil and replace the hydraulic filter then refill system
Jan 26, 2016 | Toro TimeCutter Zero Turn Lawn Mower...
Model 917.203900 22 HP lawn tractor. Shifts consistently into forward but frequently won't shift into reverse. What's wrong?
  1. Craftsman Hydrostatic Transmission Fluid Change - YouTube
    ? 40:15
    www.youtube.com/watch?v=vd1EqFtTYgk
    May 10, 2012 - Uploaded by Smokeasammie
    I change the gear oil and hydrostatic transmission fluid on my Craftsman Lawn Tractor. Fluid per Peerless ...
Jul 20, 2015 | Craftsman Garden
I put a new drive belt on my la 175 jonh ddeere mower but its still when it get hot
hydraulic transmission is going out. you may get some additional life out of it by changing the tranny oil.
The NOT SERVICEABLE UN-TRUTH.
The Huskvarna YTH150 uses Hydrogear transmission 319-0650, drive model 150071. One place to find parts and diagrams for most Huskvarnas is here: http://www.m-and-d.com/Hydro-Gear_parts.html
MTDs use Hydrogear trannys also. Go to the site and enter 618-0319 in the search box. It will bring up a selection of MTD transmissions.
Sears Craftsmen mowers also have trannys from Hydro-Gear.
The best lawn tractor Hydrostatic Transmission Fluid is actually 10W-50 synthetic motor oil (like Mobil 1). Do not use hydraulic fluid or transmission fluid.
Hydro static transmissions on most lawn tractors are very similar. Most of them are made by one or two manufacturers. Tuff Torq makes a lot of them, but not the Huskvarnas. They do make all the John Deere lawn tractor hydro drives. The lawn tractor manufacturers (like JD) often say they are sealed and not serviceable. That is flat out, an untruth. All of the JD hydros, and most all others, are serviceable. A complete line of rebuild/replacement parts can be found at Tuff Torq. Info and instructions can be found there. They have a lot of good general info for anyone rebuilding their tranny.
Additionally, I have found that the mower manufacturers fill them (or spec them) with motor oil, 10W-30W. In the service manual, and at the hydro manufacturer, you are told if your tractor is used in extreme or heavy duty situations it's best to drain the oil and replace it with 10W-50 synthetic motor oil (like Mobil 1™). Truth is the tranny should have this oil from the get go. It will give you more power and extend the life of the tranny. The mower manufacturers are all just being cheap. They figure why not, you're the one who has to pay for the early failure. Oh yeah, one other minor detail, the tranny manufacturer also recommends regular oil changes, like every 100 hours.
Virtually all of these trannys have a black drain plug on the top, if they do not have the add on reservoir. You have to remove the tranny from the mower (not a difficult things to do, it takes about 30 min). Pull that black plug (I used a 1" putty knife to pry mine out) and turn the tranny upside down for about 30 min to completely drain. Most hold about 2 quarts. Flip it back, right side up, and refill. Install plug and reinstall tranny. Note: under the plug there is often a magnet which collects metal shavings. Lift this magnet out while you have the plug out; clean it and replace it. It may fall out while the tranny is upside down.If anything else falls out, you have a broken tranny and will have to take it apart.
When you refill the fluid just keep filling till it comes up within a quarter inch of the plug. You may have to go through a bleed process after reinstalling the tranny. The tuff torq site explains the bleed process.
http://tufftorq.com/products/lawn-garden/index.html
Tuff Torq Lawn Garden
May 21, 2015 | Garden
Transmission oil drain
it should be in the owners manual for the mower. I would say its gonna be a heavy gear oil. A local true-value or anywhere that works on lawn mowers should know about what kind
Sep 18, 2013 | Troy Garden
Husqvarna hydrostatic transmission
my transmission on the right side do not have the power the lifr side have what do i need to do to fix it
May 14, 2013 | Husqvarna Rz5424 Zero Turn Lawn Mower...
22hp.zero turn sometimes smokes then stops.
The smoke could be caused by blowby around the piston rings. Pour a small amount of transmission fluid in the spark plug hole and turn the engine over several times. Check the plug for fouling. Also check the coil wire for spark.
Apr 15, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
What is the fluid type in a murry auto drive transmission
I use 30w motor oil, plug ( either rubber or steel ) is on top.
Jul 07, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Toro recycler lawn mower
if old gas was left in the engine a good carb cleaning will need to be done
May 11, 2012 | Toro Power Lawn Mower
Steering wheel is hard to turn on cub cadet riding lawn mower seems locked up
Start buy checking from steering wheel down the shaft , to gear that does turning, to shaft underneath mower that goes to steering tierods , to tires. Oil and grease will do wonders on any parts that look rusty, or may be tight. Definately check air preasure in your tires. You should be fine.
GOOD LUCK.
Jun 16, 2011 | Cub Cadet Garden
Tool for oil change/plug
no special tool needed.Just use a 3/8 ratchet extension. Fits perfect
Apr 28, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
391 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
