Question about Lexmark OfficeCenter X3350 All-in-One Printer
Changing lexmarx x3350 cartridges
Had original cartridges filled and on alignment page prints, but slowly, and sign comes on printer and says remove tape. There is no tape. How can I pull up an instruction manual on how to change cartridges to see if I put them in correctly? Thanks.
My x3550 will not print
Posted on Sep 05, 2008
Printer will not print pages. Blank paper comes shooting out
clean heads and align clean cartridges,next time use original dell cartridges no refills or over filled ones
Apr 24, 2015 | Dell Photo 926 All-in-One Printer
Slow printing
Remove both cartridges, switch off printer and then on. After cartridge holder comes to the center install both the cartridges. Then it will print the Alignment page. After alignment page prints place the Alignment page on to the scanner and press SCAN button as mentioned in the Alignment page. After completing the scan try printing. It will print the usual speed.
Note: For the alignment process both cartridges should in good working state
Jan 24, 2013 | HP DeskJet F380 All-In-One Printer
When printing on x3350 with a new cartridge... get lines that are double and some with thick black ink on some letters.
Try to reseat the cartridges into the printer. If problem continues, then maybe the cartridge nozzles need cleaning. Follow the simple steps below on how to clean the cartridge nozzles on the Lexmark X3350:
  1. Go to Start, Programs (Windows XP: All Programs) > Lexmark 3300 Series > Lexmark Solution Center.
  2. Click the Maintenance tab.
  3. Click Clean to fix horizontal streaks.
  4. Click Print. A cleaning page prints, forcing ink through the clogged nozzles to clean them.
  5. Print the document again to verify that the print quality has improved.
Source: How to Clean the Print Cartridge Nozzles on the Lexmark X3350
Jul 13, 2011 | Lexmark X3350 All-In-One InkJet Printer
My x3350 double prints text. It will overlay each sentence on itself. When I print worksheets on excel every other vertical line will be double-printed. I've tried to uninstall and reinstall the...
This may be a cartridge misalignment issue. First try printing with the settings changed to black and white print only. If this does not work then print in fast or draft mode (this should print in a single pass with less ink. Normal or best quality is usually done by passing the cartridges over the line twice.
Run the cartridge alignment test and see if it can be correctly aligned.
It could also be that the belt that moves the cartridge holder is loose and so two passes of the print head are misaligned. This may not be repairable (at least not economically).
Feb 20, 2011 | Lexmark X3350 All-In-One InkJet Printer
How to refill hp deskjet 1560 black cartidge
Hi
check here
Pls vote us to keep us alive
Nov 09, 2010 | Office Equipment & Supplies
I just installed a new color cartridge in my 8650 Lexmark printer. The ink cartridge acts as if it is empty. Printer keeps telling me to align cargridge. Worked perfectly before the new ink installed. Not...
  1. On your computer, go to "Start," "Programs," "Lexmark Series." Click "Lexmark Control Program."
  2. Step 2 Select the "Cartridges" tab. Click "Change Cartridges." The Change Cartridges screen appears, displaying the animated instructions for installing or changing cartridges. When you have finished viewing the animation, click the "Finished" button.
  3. Step 3 Remove the tape covering the print head of the new print cartridge. Insert the new print cartridge as shown in the animation.
  4. Step 4 When the "Choose Cartridges" screen appears, select the cartridge(s) you installed in your printer from the list boxes. Click the appropriate box to reset the ink levels to full. Click "OK."
  5. Step 5 The Automatic Alignment screen appears. Click "Align" to align the print cartridges for best print quality. The printer prints a page with a bi-directional alignment pattern. On the printed test page, locate the number that comes closest to forming a straight line under the bi-directional alignment pattern. Enter that number as the bi-directional alignment setting in the Alignment Cartridge dialog box. Click "OK."
Nov 25, 2009 | Lexmark All-in-One Printer with PictBridge
Changed ink cartridges cannot print alignment page, out of ink
You need to reset the ink level before the printer can print further, to do these please follow the following step:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Then try again with printing alignment task.
Hope this help.
YBC (/\)
Feb 26, 2009 | Lexmark X2500 All-In-One Printer
How to change lexmark Cartridge
  1. Click Start, Programs, Lexmark Series.
  2. Click Lexmark Control Panel.
  3. Click Print Cartridge installation.
  4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
  5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
  6. Insert the print cartridge into the print cartridge carrier.
  7. Push the cartridge back until it clicks into place.
    • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
  8. Click the appropriate Cartridge Installed option in the printer software.
    • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
      1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
      2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
      3. Click OK.
  9. Close the front cover of the printer.
Dec 09, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark X3350 printing
i just fixed this problem.  first i bought a new (remanufactured 3rd party) cartridge off ebay and found it wasn't working either.
there are cartridge cleaning instructions in the troubleshooting help section that show you how to carefully wipe clean your cartridges.  follow that, it solved my problem.
Jan 29, 2008 | Lexmark X3350 All-In-One InkJet Printer
Very slow printing
Try to make a photocopy first from the printer itself, if it can print faster then the problem is on the computer,if not then follow the steps below:
Clean the printheads, clean the nozzles, if it still print slowly, remove the cartridges and clean the nozzles. If these steps does not resolved the problem then try changing the cartridges, maybe there's something wrong with the cartridges itself. After changing the cartridges, try to print again, and if its still the same then just post it here and ill try to find another solution for you.
Jan 01, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Lexmark OfficeCenter X3350 All-in-One Printer Logo
119 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
