Question about Kitchen Ranges
Self cleaning ovens
The stove keeps beeping and F1 keeps flasing, while the bottom burner in the oven won't turn off. we turned the braker off and back on that didn't reset the oven.
I have the same problem. the burners work and f1 is flashing and the oven wont work. i turned the breakers off but it does not reset. i just want my oven back and i will clean it myself.
Posted on Sep 28, 2008
When turning oven on there is a beeping sound and error code F1
Most of the answers are correct, the EOC (Electronic Oven Control) is either damaged or shorted. I've also seen the F1 code come up on the version 2 and 3 units when the temperature probe was shorted. But most likely your EOC is damaged and needs to be replaced. Since you didn't give us a model number we can't give you any more info. Good luck
Mar 14, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
I have Model #JER8750AAB Serial#16776012WK When uising the self cleaning feature, oven stopped and F1 displayed on stove ??
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Dec 19, 2010 | Jenn-Air Microwave Ovens
Can't get my Kenmore Oven to Stop flashing/beeping F1 after using the self clean. We turn off the braker now, but now my oven is stuck on broil and I cant get it to stop Fl/BP F2. How can I fix this?
probably not. If this is a frigidaire made unit, you will probably have to replace the clock/oven control. That will set you back around $130.
Nov 15, 2009 | Kenmore Ovens
F1 llight on, oven locked, stove beeps every few seconds
My stove did the same thing after I cleaned it. I had to have the sensor replaced. That is what the F1 code is.
John
Oct 01, 2009 | Frigidaire Gallery GLEFM397DS Electric...
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
Kenmore Oven going crazy
The bang may have been an element arcing over.  Turn off the power and remove the element.  If it shows any form of damage, replace it.  If you're not sure, use a continuity checker to check it.  If you have two elements...do this for both.  You will likely find the problem.
Nov 13, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
MAYTAG STOVE PROBLEM...NEED HELP
the broiler came on automatically??? not a sensor issue. sounds as if you have a broken wire perhaps, or a faulty control panel energizing the broil element w/o being prompted to. does it say its broiling when element comes on??
Mar 05, 2008 | Kitchen Ranges
Kitchen Ranges Logo
422 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
