Question about Maytag Washing Machines
My 5 week old Maytag Epic Z will flash an error code F-29 every time I try to get it to wash. The book says this is an electrical problem, but Lowe's hooked it up and the breaker doesn't throw----please help!
  • trevordylan Sep 05, 2008
    meaning of code F-29 on Maytag Epic Z
    I am glad to know it is the computer and that I do not have electrical problems in my home.
    Thank you for your help.
    Genius:
  • 1,269 Answers
Despite the error, does the machine still run, and can you still wash or not anymore due to the error? You can start checking the electrical circuit of the unit. Mainly, the fuse the first to be affected. Check also if there are any other burned electrical parts inside the unit. Re-soldering or replacing the burned part will fix the problem.
Posted on Sep 05, 2008
  • 6,487 Answers
This link will be helpful for you , it has the xplanation of the problem also some diagnostic that you can try to solve this problem http://www.assuredparts.com/MaytagBravosDryerFaultCodes.html
Hope that helps.........
  • 4,234 Answers
THe F-29 code is generated from the electronic controls. Since this unit is only 5 weeks old, you should not be spending any time on it other than calling for warranty service. In all probability, the control module will be exchanged and you will be back to doing laundry soon.
Dan
    Genius:
  • 1,847 Answers
The drum should be on center.
It sound like a damper pads issue. The damper pads are located beneath main support housing on base's machine.
Check that they are on place and not broken.
Good luck !
Mani have an error coming on my epic maytag washer it flashes the letter F and then the letters DL please help
Hello the error code F with a DL is usually a clogged or kink in the drain line.
Unplug washer and remove drain hose and clean it out.
Check area where Line connects to washer closley for any debris and remove it.
May 08, 2011 | Maytag EPIC MFW9700S Front Load Washer
F11 error code
The F11 code means there is an electrical with the Maytag Epic washer. This could involve wiring, fuses or a number of other issues.
Press the "Pause" button twice to stop the current cycle. Press the "Drain" button to remove any excess water. Try to run the washer again. If the F11 code repeats, shut the washer off and contact a service agent
The FH error code may be mistaken for the F11 code. The FH code signals a water supply issue and has nothing to do with electrical problems. Check the LCD screen to ensure you read the proper code
Dec 28, 2010 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Z with error codes F20 and F24
my epic will start & wash & then gets F 20 & won't drain until I hit start again
Oct 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic giving F11 error code!
ths.gardenweb.com/forums/load/.../msg1012004912002.html
Jun 22, 2009 | Maytag EPIC MFW9700S Front Load Washer
"Maytag Epic z washer flashes f 24 error code"
I have a maytag epic z dryer and it wont turn on. it worked fine the last load, now nothing? help.
Apr 25, 2009 | Maytag EPICz Electric Dryer
Error code "F".
The "F" code indicates an electrical problem, possibly a faulting part. Maytag does not offer any guidance on this. FYI - Could be a bad control board
Apr 18, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic-Z F-28 error code
F28 is a misc error,
most of the time it is because the washer is NOT LEVEL.
1. Unplug waher,
2. Relevel washer. (make sure all legs are equally distributing weight, so as to ensure no shaking). See owner's manual.
3. Plug in, and use.
Hope this helps.
Jay
Aug 26, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag Epic Z frontloader Error Code F20 Help Please!!!
i also have a magtag epic z &f 24 error code is on my washer. i don't know what to do.
Jul 01, 2008 | Maytag Washing Machines
Maytag Epic Z error code
I need a clear code for maytag epic z front load washer
code f-o1 is coming up
says intall new ccu, I did but still the same
do I need to clear the code if so how.
please tell me.
Jun 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic
the control board has loose solder connections around the relays.
see this
diff model same issue with new boards as they make them all.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
being it is in warranty its too early for you to fix it yourself.
you will have to wait for them to come out and say the parts are on backorder.
Feb 04, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
64 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
