Question about Swatch Wildly
Swatch wildly the 1/10 second hand on my swatch wildly watch stops at various intervals by itself. Before it would only stop whn I pressed the second button
  • Anonymous Oct 06, 2008
    i have the swatch irony chromo, with the same problem, somone needs to upload a detailed labeled diagram and instruction manual
2 Suggested Answers
tbirdfan1
  • 3051 Answers
SOURCE: Swatch Irony Aluminium instruction manual needed
hELLO THERE
please go to www.swatch.com and look for you brand and type there will be a online manual that you can use and download and print if needed ok?
best regards mike
Posted on Aug 05, 2009
mcdevito75
  • 1970 Answers
SOURCE: Swatch Irony Battery replacement will not work
mcdevito75 here, I am thinking your watch ran fine before the battery change. It sounds like the new battery is not makeing good enough contact, you can try, removeing the battery and cleaning the contacts in the watch carefully with a Q tip, dip the Q tip in anything containing alcohol cologne, rubbing alcohol, perfume wet the Q tip good, then sqeeze most out of the Q tip as not too saturate the battery contacts, also clean the battery itself, the oil on your fingers could give it a poor contact on the watch. The stop watch section doesn"t take as much battery power as the second hand. You may also be able to jump start your watch also, You"ll need a needle and a magnifier glass, With the back off your watch, right in the middle of the movement, just below where the stem (winder) goes, you"ll just see part of a little gear, this is the hour hand gear, see if you can gently move that gear just a fraction, place the needle between the teeth of the gear and try to move it as gentle as possible then se if the gear will move on it"s own., be very carefull with the movement. Swatch watches are collectables. If you don"t feel comfortable doing the above, look for a small watch repair shop in your area for help.
Posted on Jul 17, 2010
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
Nov 06, 2012 | Swatch Diaphane Chronograph Blooded Silver...
Swatch, irony, men's watch, doesn't work
the second hand, the small one at about 6 o'clock is moving which indicates your watch is working. the other large hand is not the second hand but the chronograph hand or stopwatch hand. You start it in motion by pushing the button a 2 o'clock. You also stop it this way. The button a 4 o'clock is the button than resets it to zero (12 o'clock). You didn't say what wasn't working. Does this help?
Oct 31, 2012 | Watches
I have a swatch irony chrono, but when I stop the stop-watch and push the bottom button, the sweep hand ends up at the 11 o'clock and not the 12 position. My quartz Parnis does this, and its driving me...
Assuming the mechanics work ok (thay all do 360 degree turns) it's just a calibration issue: download from SWATCH support a PDf which describes how to zero the watch hands, it's simple as taking the crown out to 3rd step, the pushing the buttons repectively till they point 12 direction. Exact details in the PDF.
Dec 11, 2010 | Swatch Irony Chrono #YOS414G Watch for Men
Jul 17, 2010 | Swatch Irony watch
Guess Watch's stop watch is broken?
it's not broken.
let's call the top stopwatch button "a" and the bottom stopwatch button "b." eg, for normal stop watch function press "a" to start timing, press "a" to stop timing, and press "b" to reset.
to reset: press button "a" and "b" simultaneously and release (an easy way to do this is press and hold down "b" then press "a" and release both). this will send both hands spinning. next press "a" intermittently until the second-hand is back to it's desired reset location. then, likewise, press "b" intermittently until the minute hand is zeroed. now with both hands at the correct reset location, again press and release "a" and "b" simultaneously to save these resets and return the watch to normal function mode.
Aug 05, 2009 | Watches
I need to reset the hands
Assuming you want to reset the zero posistion of the chronometer (stop watch) hands...
On my watch I can adjust it by doing the following...
To reset the microseconds hand / top right
1) Pull the center knob full out (2 clicks)
2) Press the bottom push button to adjust the hand
To reset the seconds hand / middle
1) Pull the center knob a full out (2 clicks)
2) Press the top push button to adjust the hand
To reset the minutes hand / top left
1) Pull the center knob out half way (1 click)
2) Next press the bottom push button to adjust the hand.
Once all hands are reset, push the center knob back in fully...done
Mar 16, 2009 | Swatch Irony watch
Using the stop watch feature
Dennis,
"Chronograph" is watch terminology for 'stop-watch'.
There are 3 small dials on the watch.  The main dial has a minute hand and an hour hand.  The big second hand on the main dial is not for the main time of the watch.  It is for measuring seconds for the stopwatch.
The 2 small dials at 10 o'clock and 2 o'clock will give you minutes and 1/10 of a seconds.
There are 2 buttons on the side of the watch. Top Button:  Start/Stop Bottom Button: Reset
To set the chronograph to its default position, you would pull out the stem to the first position and push the buttons.  Also, pull the stem out further to the 2nd position and push the buttons.
Jan 13, 2009 | Swatch Chronograph Wach SVCK4035G Watch...
Ebel sportwave chrongraph
It;s probably a difective movement mechinism.
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Ebel 1087902 wristwatch
SECTOR CHRONOGRAPH 200 WATCH
That's easy. You need to calibrate it. In normal time mode, pull the crown out all the way and then use the pushers to step it back to the zero position. When finished, push the crown back in. You can also calibrate the sub-dails in a similar fashion.
Sep 19, 2007 | Watches
Chronograph hand not resetting to 12 o'clock
for my victorinox, the crown out one position and the reset button (lower chronograph button) changes the minute hand and the top (start/stop button) does the 10th's of a second...crown all the way out and top (start/stop button) does 30 second intervals for the minute counter.
Feb 23, 2007 | Kenneth Cole KC1232 Wrist Watch
Swatch Wildly Logo
Top Swatch Watches Experts
ray gallant
Jerry Kramer
Jerry Kramer
Are you a Swatch Watch Expert? Answer questions, earn points and help others
