Question about Canon BubleJet i965 InkJet Printer
Canon i965 printer
My i965 recently had print head problems. Only yellow and green were printed when using glossy paper. Several deep cleanings later problem still there. New inks, no better. Took it back to dealer. Now prints ok but ink tanks allways show half full. Only time I know when to install new is when one colour fails. Canon help desk is a waste of time, the call centre in bucharest is clueless. Replies from them do not materialise. Anyone out there know the answer please. Thanks John Dobson ============== Posted through [url=http://www.HowToFixComputers.com/bb]www.HowToFixComputers.com/bb[/url] - free access to hardware troubleshooting newsgroups. Sounds like same problem, unaffected when I updated to latest driver (4.8.3 for Mac).  Colours are OK on plain paper IF one tells PRINT one is using Standard or Plain paper, loses almost all blue if one tells it Matte paper (or I guess Gloss). On gloss paper, picture is lurid pink (i.e. no blue) if one tells PRINT paper is Standard (equivalent to autodetect?) or Gloss; if one tells it paper is Plain or Matte, blues appear but dark (nearly black) areas print as chocolate brown!
  • Canon Master
  • 19,396 Answers
First ensure it is not a cartridge problem, try a replacement.
It does not look like a print head problem, it can be a driver problem or a logic fault in the printer.
Posted on Sep 05, 2008
  • Ginko
    Ginko Sep 05, 2008
    A faulty cartridge can result in printing weird colors. Try a replacement cartridge, possibly original, to ensure it is not a faulty cartridge.
    When print heads are faulty you get bad results on all prints, I don't think it is the printhead.
    You can try cleaning the printhead from Windows, and cleaning the metal cartridge sensor on the ink carriage with cotton and isopropyl alcohol. This is regular maintenance.
    Test the printer on a different computer (even on a Windows system), using latest drivers, if printer does fine it is a driver problem.
    If printer still does the same, then it is probably a fault in printer logic board, that controls the ink management.
    Test on different computer first, can be a software issue.
Print head failure signal
Error 5 is an ink cartridge error. Cleaning the print head and electrical contacts on the cartridge does not fix this error. You need to get a new cartridge to fix the problem.
Feb 09, 2010 | Canon BubleJet i965 InkJet Printer
The printer prints fine on plain paper, but on
I'm not clear on your problem but you can try this<a href="http://www.richardsnotes.org/archives/2006/05/17/canon-i9900-printer-problem-and-solution/" >Link for simular problems.</a> You may find the solution there.
Nov 27, 2009 | Canon i9900 InkJet Photo Printer
Canon i965 prints blank pages
Yes those printheads do go bad, they burn out just like a light bulb. If you emptied cartridges then the purge/cleaning assembly is working properly, and the only other option is the expensive printhead.
Aug 20, 2009 | Office Equipment & Supplies
When printing my pictures they turn out green...
You will need to clean and/or deep clean the ink cartridges through the maintenance features either located on the menu of the printer or the printer options located in Windows. If that still does not correct the problem then you will need to remove the print head and clean it seperately. I have posted the procedure for that in earlier remedies.
Feb 27, 2009 | Canon Pixma MP500 All-In-One InkJet...
IP90 WONT PRINT BLACK
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head move to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head holder. Slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out of the tank.
5. Have several paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. My color and black and white print came right back!
Hope this helps.
Jan 30, 2009 | Canon PIXMA iP90 InkJet Printer
Colour on glossy paper
First thing, use original Canon cartridges. that could be the source of your issue, as these days, printer companies resort to these kinda tricks to ensure that the customer only buys their products.
Next, make sure that you have selected the proper paper type and output quality under printer properties.
Should this not work, please post back so that we can assist you further. But remember, try with the original inks first, and not refilled or generic cartridges.
Jul 02, 2008 | Canon BubleJet i965 InkJet Printer
Pixma IP4000 Printer
OK, Canon will hate me for posting this!!!!!
Remove cartridges.
Remove print head.
Go to sink or tub (stianless steel, not pastic type), pick up roll of paper towel on the way.
Fold several layers of paper towel and place on flat surface.
Run HOT water till HOT.
Turn hot water to dribble.
Run hot water through print head, careful not to wet contacts.
When water is clear coming through print head, place print head on paper towel.
Repeat process until no colour on paper towel.
DAB print head (DO NOT WIPE) inside and out to dry.
You may wish to let print head air dry overnight but I replace it after drying.
Replace print head in printer and replace cartridges.
Start printing again
I do this on all my Canon printrs every 6 months
Jun 30, 2008 | Office Equipment & Supplies
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
My canon i960 is printing only green
I had this problem. If I tried to print a black& white photo on to glossy paper, it would only print green. When I tried on to plain paper using the 'fast' option, it printed in black. The reason for this is, on plain paper it uses the black cartridge, but output to glossy photo paper using the 'high' option, uses the mix of colours in your colour cartridge. If one or more of your colours has run out, you will get a print with the ink left in the cartridge. Replace the cartridge or refill it & your problem is solved.
Dec 19, 2007 | Cannon Canon i960 Photo Printer
Canon BubleJet i965 InkJet Printer Logo
197 people viewed this question
old marine
old marine
