"UNUSABLE SIGNAL" I keep getting "unusable signal" for every component I have connected to this TV. My DirecTV, DVD, and PS2 do not work. Any suggestions on how I can fix this problem? Mrlee408, i have a similar problem. i have an RCA HD65W40. mine says "weak signal", with the occasional audio coming through, for about 2 seconds, never any picture on ANY input i use. i have an rca tv my directv on the tv says unusable signal and can't use my dvd or viedo player to watch a movie what do i do? thanks
  • 168 Answers
SOURCE: Why won't my TV pick read my portable DVD player?
probably you need to change your input setting using the menu in your tv. use your remote control in finding that menu. good luck!
Posted on Feb 13, 2007
SOURCE: Samsung CXD2512 TV/VCR Combo...Cannot hook up DVD player
you have to hit the vcr/tv button on the remote. there is a separate line that works for games and dvd devices.
Posted on Feb 21, 2008
We also don't have a remote. We hooked a DVD/VCR combo to the Samsung combo by attaching the cable from the cable line to the DVD player and an additional cable from DVD to TV and it used to work but after we lost the control, the DVD can only be listened to but not seen. The VHS from the DVD player works perfectly though.
When we had the remote (before connecting the other combo) we used line-in to see a DVD or VHS using the yellow red and white cables from the Samsung to the other player.
Posted on May 03, 2008
l have a 42 in tv rca connected from a direct satellite and i have no picture or sound tryed different connecters only black screen with unsable signal
Posted on Jun 23, 2008
  • 9 Answers
SOURCE: RCA 20" TV/DVD Combo - DVD Player says discs not compatible?
Does it work on store bought DVD's?If it does it means it's not compatable with homemade dvd's on pc's or other recorders.If it dose not you have a dirty lens.If a lens cleaning cd doesn't work,the dvd deck has to be replaced,probably exspensive.
Posted on Jan 03, 2009
Unusable signal
This is a resolution mismatch problem. One of the devices will not accept the resolution of the other. Try another type of connection or try another input.
Apr 13, 2014 | Sony DVP-SR200P DVD Player
Rca entertainment series unusable signal
i think your rca cord is not functional. replace it with another one or fix the connections of your cord.
Jan 04, 2014 | Televison & Video
Rca model j27435 trying to use dvd player says unusable signal
Most DVD players and maybe the Wi are connected via rear audio and video input jacks so that may be your issue.
Jun 11, 2012 | RCA F27442 27" TV
Entivoe DVD player worked fine. The next day, the tray opens, closes and the power turns on and off but the screen says only "Unusable signal", either with or without a video disc in the player. If there...
check the connection cable to the tv, unplug this an replug it to see if this helps.
if you used a cheaper HDMI cable for example the connectors are very wobbly and often make poor contact....
Aug 31, 2010 | Televison & Video
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
May 21, 2010 | RCA TruFlat 27F520T 27" TV
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Unusable Signal
Hello Mike:
The issue that you are having is with your small signal board and it needs to be replaced, it sounds like the microprocessor on that board is getting locked up.
Aug 19, 2008 | RCA L42WD22 42 in. LCD Television
Jan 07, 2008 | RCA HD65W140 65" Rear Projection...
"UNUSABLE SIGNAL" have a bad dm3 module...lots of luck getting 1 right now, I got 3 on backorder!
Jan 07, 2008 | RCA HD50LPW42 50" Rear Projection HDTV
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
