Question about Dell 962 Photo All-In-One InkJet Printer
Scanning The printer works, the fax works and the copy works, but the scanning feature no longer works. The messenger asks me to unplug the printer and unplug the USB cable which doesn't help. Please help me with this problem!!! :(
  • 17 more comments
  • David Poteet Sep 05, 2008
    How or where can I check it my device manager. I don't now that a device manager is!
    Unpluging and reinstallation doesn't work!
    How do I know if printer is connected to a network?
    When I copy the lens move over the bed and make a good copy, wouldn't that be the same lens that the scanner would use?
    the problem lies in your optic lens of the scanner
    I am receiving solutions from different help lines but when I check on (Click Here to view this comment or you can find it in the problem) I always get the first answer to the question. What am I doing wrong.
    It is connected properly.
    Okay
    Device mgr shows printer is installed
    I believe it is software as well. I have reloaded several times and just removed Element 6 from Adobe. Still no success
  • David Poteet Sep 06, 2008
    Under Scanner and Camera Wizard
    An error occurred during preview. If the scanner is being used, please wait for it to complete the task, and then click Preview
    I press preview and nothing happens!
    Software updates don't seem to make a diffence
    I only have one scanner. I don't hook up my camera to the computer
    I'll try
    It just is not working
    Thanks
    I unzip the files and then get a Microsoft Visual C ++ Runtime error!
    What is fleepower?
    Good advise
    Thanks
    Good advise
    Thanks
    Master:
  • 638 Answers
The scanner is faulty.you have to replace scanner thats all.this same problem is faced by many of my clients and replacing the scanner is necessary for this problem.the near cost of replacement will be 50$.
thanks.
please rate the solution
Posted on Sep 06, 2008
    Sergeant:
  • 241 Answers
CAN YOU SEE MY COMMENT YES OR NO
  • 1 more comment
  • Jayson Brollini
    Jayson Brollini Sep 06, 2008
    Hi If you can see my solution
    It sounds like your printer is conflicting with a Virtual printer port
    If you have created a second printer in the past and or added on recently this is what happens.
    On your printer that you are using in the control panel Right Click
    *properties and select *ports
    From there scroll down and look at the USB and there should only be one listed for printers if there are more that one USB box make sure that you remove the check marks and only check the printer you are using.
    If there is a USB box and next to it you see "Virtual printer Port"
    we can move on to the next steps
    I will wait for a responce or you can click here on my
    name --->>>Kindofcheap
  • Jayson Brollini
    Can any one see my COMMENTS yes or NO
  • Jayson Brollini
    CAN ANYONE SEE MY COMMENTS (FixYa STAFF fix my profile)
  • 1,879 Answers
Windows can only handle one imaging device at a time - imaging devices example in case you don't know - scanner, camera
    Sergeant:
  • 264 Answers
Open the control panel. Open scanner and Faxes. There you will find the scanner listed. Scan fom there.
If you are able to scan from there that means the Dell software you are using is corrupted and needs to be uninstalled and reinstalled.
When we use the scanners option from the control panel we are using the windows default utility to scan, not the third party software.
I ma sure this will resolve the issue..
All the Best
Sammy
Posted on Sep 05, 2008
  • 1 more comment
  • Sameer Kashyap Sep 06, 2008
    Uninstalling and reinstalling the printer software looks easy however it is not.
    We need to follow three step uninstallation.
    1. Uninstall the software from Add and Remove Programs.
    2. Delete the software from Program Files under C drive.
    3. Remove the Entries from the Registry.
    Restart the computer and than install the software again.
    While installing the software make sure that the AIO in not plugged in till the software comes to the portion of detecting the AIO.
    If you are getting the error you mentioned. First do a Fleepower.
    Which is. Turn off the Computer and the AIO.
    Unplug the AIO From the Computer. Unplug the power of the AIO and the Computer.
    Press and hold the power button on both the computer and the AIO for 20 seconds(Nothing would show up)....Its a step to drain any static charges.
    Than turn on he computer and later plug the AIO back in and try the scan from the control panel again.
    Did you try the fleepower and used the scanner from the control panel again..
    Genius:
  • 2,028 Answers
The machine uses the same device (lens) to do both copy and scan, however the copy feature doesn't require the computer, the scan does. The copy feature can be use as a stand alone, and make copies without even being attached to the computer, the scan sends the copy (item being scanned) to the computer for viewing, editing, email, etc... I'm going to say that this is a simple software glitch, and removing and reinstalling the software will fix it.
  • 928 Answers
If the print copy and scan function works then that means there is nothing wrong with the hardware. Most likely the problem would be software. You can do one of 2 things. Update the driver for the multi or another option is to restore your system to the date when it was still working. If it has been more than just a few days DO NOT DO IT. Now as for the driver update you can go to www.dell.com and then just download the driver for it. Secondly goto the device manager.
Click start then run then type in devmgmt.msc
Click ok this will bring out the device manager.
After htat look at imaging devices check if you see your scanner there.
If you do not look if you are able to see anything with a question mark or exclamation point.
    Sergeant:
  • 336 Answers
If you would be willing to setup a time this weekend I can arrange to work on your computer remotely, from my computer to see if we can get your scanner to work. If you would just like some chat support tell em and I will begin troubleshooting. Okay?
All The Best,
RCF
  • Dell Master
  • 1,800 Answers
Hi.
i am so sorry to tell u hat ur Scanner is wrecked/damaged.
as long as all the features working and u already reinstall the drivers and still cant work that only means that ur scanner will not work .
try the warrantly if u still under it because the its kinda a hard task replaceing the damaged part of ur scanner //the ignition panel//.
hope this helping plz do rate this post.
best regards.
  • 1 more comment
  • Jalal Sordo
    Jalal Sordo Sep 05, 2008
    The scanner uses a light source, typically a cold cathode lamp to illuminate the scanned object. The light is then reflected off the object and into Charged Coupled Device (CCD). The Charged Coupled Device collects the information, and through a series of electronic devices converts the analog signal into a series of digital signals which can then be read and processed by the internal electronics of the scanner and subsequently a computer.
    so its not a lens at all
  • Jalal Sordo
    and myabe if u click here u will got an idea about ur device and its troubleshooting.
  • Jalal Sordo
    Jalal Sordo Sep 06, 2008
    try to do what i told cuz its the only way i think i ve facved this prob before Sir
  • Dell Master
  • 19,396 Answers
The printer is fine, it copies.
Just unplug USB and reinstall drivers, either from printer disk or from download.
    President:
  • 1,263 Answers
The problem lies in your optic lens of the scanner. every other feature works except that so it is not the drivers or software issue. you need to have a service tech repair it.
    Genius:
  • 1,268 Answers
You can give this a try:
NOTE: Scanning cannot be done on printers connected to a network.
Using the Operator Panel
1. With the printer on, and make sure they are properly connected.
2. Load your original document.
3. Press the Mode Selector on the operator panel repeatedly until Scan is selected.
4. Press > to scroll through the list of possible programs to which you can scan.
5. Press Select when the program to which you want to scan appears.
6 From the Start area on the operator panel, press Black to begin a black and white scan or Color to being a color scan.
Using the Printer Software
NOTE: Some programs do not support multiple page scanning.
1. Turn on your computer and printer, and make sure they are properly connected.
3. Press Scan on the operator panel.
The Dell All-In-One Center appears on your computer screen.
4. Click Preview Now to see your scanned image.
NOTE: If the size of the scan (found in the lower right of the preview window) appears in red, you do
not have the system resources available to perform the scan at the resolution or size you have
selected. To correct this problem, either reduce your resolution or the size of your scan area. Or you can use editing applications like photoshop and the likes to lower the resolution of the image that you want to scan.
5. Adjust the dotted lines to fit around the part of the image you want to print.
6. From the Send scanned image to drop-down menu, select your scan destination.
7. To further customize your scan job, click See More Scan Settings.
8. When you are finished customizing your image, click Scan Now.
Hope that helps!
  • Michael Galve
    Michael Galve Sep 05, 2008
    If you are in an office, and the printer is like centralized, trace the USB cable at back of the printer if it is connected directly to the back of the computer or connected to another device. If the USB cable is connected directly to the back of the PC, it is not connected to a network, otherwise, it is connected to the network so the scanning wont work. That's a product limitation base from the printer's manual. It can only scan if the device is hooked directly to a computer.
    Genius:
  • 3,422 Answers
HI,
Please unplug all the cords from the back of your printer for 30min and then plug it back in.If you still face the problem then just go for a reinstallation of your printer drivers.
  • Dell Master
  • 6,487 Answers
Make sure the the scanner software is properly installed , you can check it under device manager, because if the scanner driver is not installed it wont really work..
Hope that helps........
  • 1 more comment
  • Mark Gil
    Mark Gil Sep 05, 2008
    Right click Mycomputer icon>Properties>Hardware tab>Device manager. when you're there already look for the scanner of the printer model and see if its installed properly...
  • Mark Gil
    You can download the latest software for this then reinstall it using the latest software and that should fix this concern...
  • Mark Gil
    Mark Gil Sep 06, 2008
    A software update should fix this problem , so go ahead downlaod the latest software then uninstall and reinstall using the downloaded software....
    Good luck..........
My HP6110xi All-In-One doesn't want to scan
First, scans and copies don't really use the computer. Can you print a document from your printer. If not, then your problem is within the computer.
If it does print then....
Try using the scan feature within the HP solution center. It works on mine but the scan button on the printer does. Also some art programs have and "ACQUIRE" feature under file to scan with. (Sometimes called TWAIN.)
Hope this helps, so you can start scanning.
good luck
Feb 21, 2010 | HP OfficeJet 6110xi All-In-One Thermal...
Scanner
Try updating the drivers. Take this link to Hp and either enter model number and then operating system or let Hp detect your hardware and select drivers.
http://www.hp.com/#Support
Aug 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
Printer works fine, but when scanning to copy or scanning to fax a line appears right down the middle of the either the outgoing fax or the printed copy. This when using the feed from the top of the...
If it only happens when you copy or fax, as opposed to 'printing"...clean the scanner glass -both the main glass and the narrow **** glass on the left side.
Please rate me.
Mar 31, 2009 | Dell 1815dn All-In-One Laser Printer
Hp psc 1210v all-in-one printer, scanner, copier will not scan
CHECK BELOW OTHERWISE GO TO HP WEB SITE AND LOOK FOR THE DRIVER SUPPORT TO DOWNLOAD.
Scanning
Use one of the following three methods to scan a document. Method one: Scanning with Windows Photo Gallery
  1. Click the Windows (c01367376.gif ) icon.
  2. Click All Programs .
  3. Click Windows Photo Gallery .
  4. Click File , and then click Import From Scanner or Camera .
  5. Click Import .
  6. Click Scan .
Method two: Scanning with Windows Fax and Scanning
NOTE: This feature works only with Windows Vista Ultimate, Windows Vista Business, and Windows Vista Enterprise.
  3. Click Windows Fax and Scanning .
  4. Click New Scan .
  5. Click File , and then click Scan .
Method three: Scanning with Paint
  3. Click Accessories .
  4. Click Paint .
  5. Click File , and then click From Scanner or Camera .
  6. Click Scan .
Jan 13, 2009 | HP PSC 1210v All-In-One InkJet Printer
HP Printer
Try this :-
Installing the printer driver in Windows Vista
Verify that the printer is turned on.
Connect the Universal Serial Bus (USB) cable to the printer and to the computer.
A Your devices are ready to use window might display on the screen. If the window displays and does not close automatically, close the window.
Print a test page to verify that the printer is working correctly.
Using the basic printer functions
Printing: - Open the document to be printed in the software application in which it was created.
Click File and then click Print.
Scanning: - Scanning with Windows Photo Gallery
Click the Start (c5af1ed.gif) icon.
Click All Programs.
Click Windows Photo Gallery.
Click File and then click Import from Scanner or Camera.
Click Import.
Click Scan.
(NOTE: This feature works only with Windows Vista Ultimate, Windows Vista Business, and Windows Vista Enterprise)
Click the Start (9c4e39e.gif) icon.
Click All Programs.
Click Windows Fax and Scanning.
Click New Scan.
Click File and then click Scan.
Scanning with Paint
Click the Start (b95b750.gif) icon.
Click All Programs.
Click Accessories.
Click Paint.
Click File and then click From Scanner or Camera.
Click Scan.
Importing and viewing images on a memory card
Remove the memory card and then re-insert the memory card into the appropriate memory card slot on the printer.
(NOTE: See the User Guide that came with the printer for more information on how to insert the memory card in the printer)
On the Auto play screen that displays, click Import Pictures, View Pictures, or Open folder to view files.
Follow the instructions that display on the screen.
Using the advanced printer functions
(You might find that some of the advanced features are no longer available when using this basic driver. You can upgrade to an HP product that is fully compatible with Windows Vista if the advanced features are necessary.
To help you decide what product to upgrade to, click here for information on upgrading the product go to this link or copy and paste it into Browser :-
http://h30216.www3.hp.com/ASA/Controller?adi_hasScript=1&_AD_195R22=110&adi_scriptSID=DF57657645AF158516628FE76C76392C&sysid=84&appid=10251&_ad_stoken=sup&jumpid=re_r10602_advisors/adi/sd
Jul 22, 2008 | HP DeskJet 3940 InkJet Photo Printer
Scanned documents are very light
I have found that when scanning b/w documents, its helpful to start with a black and white copy, not a grayscale, pen written, or printed form a printer in grayscale mode copy, but a true black and white on the copier or fax copy. The scanner doesnt read shades of black so well and when scanning multiple page documents, my pixma tends to scan in lightly. I havent found a piece of software to do just this, batch darken what has been scanned (at least not for free). Copying before scanning is the work around. Hope this helps everyone who's had this problem. It also doesnt hurt to darken what your scanning down a notch when copying
Mar 21, 2008 | HP PSC1510 Printer/Scanner/Copier...
No Scan Options Error Message
Vista?
Pressing of scan button feature is no longer supported by hp drivers, if installed correctly one scans using scanners and fax
When the scan button is pressed on the printer, nothing happens. The scan button does not work correctly. Solution Scan documents using Windows Fax and Scanning or Paint. Scanning with Windows Fax and Scanning
  1. Click the Start (c00845897.gif ) icon.
  4. Click New Scan .
  5. Click File and then click Scan .
Scanning with Paint
  1. Click Windows .
  4. Click Paint .
  5. Click File and then click From Scanner or Camera .
  6. Click Scan .
Cause The drivers in the Windows Vista operating system do not support button press functionality on the printer. link to above info from HP
Dec 11, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Dell 962 Photo All-In-One InkJet Printer Logo
175 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
