Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Bosch excell still wont fill?
My machine is baffling me. I am an engineer but not a dishwasher one. I cant understand the float switch arrangement. I have worked out that as the machine starts, water appears in the base and lifts the polystyrene disc tripping the floatswitch and have no idea as to where the water is coming from as I cant get to anything other than the side panel stuff. Fixing the leak will be easy I guess but finding it is impossible. To add I fool the machine by dropping the float but it still hangs and no water comes in, the solenoid is good. Is there another float switch somewhere else. I gotta beat this thing!
  • boriss4 Sep 05, 2008
    Thanks guru will have a look at the diagram.
    President:
  • 1,263 Answers
Without being hands on there is a web site than you can go to and it will give you the diagram for your particular model. however your float is connected to a micro switch if the switch is not set right you will continue to have this problem.. here is the link you can go to www.safemanuals.com the manuals are free to download. good luck and please rate this...thanks
Posted on Sep 05, 2008
  • Bosch Master
  • 19,396 Answers
The wterlevel switch may be faulty.
  • Ginko
    Ginko Sep 05, 2008
    There is a water level switch, that controls water level and stop the flow. If it is jammed or faulty the machine won't fill.
    Post here the model number for your appliance, so that I can find the part list and exploded view.
Dishwasher wont fill
The float is located just inside the door either on the left or right hand side, it's a simple float, if it's stuck in the fill position then try a gentle push to release it, and make sure nothing is under the float causing it to stick in the filled position.
Dec 08, 2013 | Dishwashers
Bosch dishwasher does not fill with water
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Jul 19, 2011 | Bosch Dishwashers
AQUA SENSOR BOSCH DISHWASHER NOT FILLING WITH WATER
Hi, if your dishwasher is not filling with water, check the Water-inlet Valve and Float Switch
The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Jun 21, 2011 | Bosch Dishwashers
Machine is not filling and making a hissing noise
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Feb 13, 2011 | Bosch 24 in. SHX46A05 Stainless Steel...
I have a Bosch Exxcel dishwasher which runs the drain pump constantly even with the door open and despite there being now water in the machine at the cycle wont start. I have checked the warer amtrix and...
I am not sure about this model but most models run a drain cycle for a set period at the start of a wash cycle and then move on to normal filling and cycle of machine provided the various switches are at the low level it will carry on to its set cycle,is the apartment or flood switch ok?
Jun 30, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Not getting water into machine although mains water is reaching hose intake. model number of bosch is sgs44e28eu05 type si1501b
There's no water entering the machine If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it. thanks.
Feb 17, 2010 | Bosch Dishwashers
My bosch excel dishwasher dose not seem to wash as it is not getting enough water. checked water pipe that was fine.
Water-inlet valve
Float switch
Aug 15, 2009 | Dishwashers
No fill - drain pump running - I assume stuck float switch
remove the bottom plate of the dishwasher and the bottom pan is revealed. reason the drain pump is running will be that this pan has water in it ie you have a leak. mop out the water and dishwasher will work - switch off mains when you do this
Sep 10, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
How to mend it .com - Bosch dishwasher SGS43A12GB-27 does not stop filling
possibly the inlet water valve stuck open tho this is rare.
disconnect the valve electrically and see if the fault is still present. if so, the valve is stuck open and needs replacing
Jun 24, 2008 | Bosch Dishwashers
Bosch Dishwasher not letting in water
The float switch may be stuck in the up position which shuts the fill solonoid valve off. you should be able to find the float switch under the lower dish basket.
Jan 14, 2008 | Dishwashers
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
90 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
