Sylvania L181 18.1 in. Flat Panel LCD Monitor
Problem for Sylvania L181 18.1 in. Flat Panel LCD Monitor
Monitor goes to white at cpu shutdown
By Chief on Nov 19, 2005
I need help on finding out why my monitor goes to white.
I shut down my windows XP system and the monitor started to go to a white screen, and stays that way until I unplug the monitor or restart the computer.
Turning the monitor off with the monitors on/off does not work, it stays white.
It is so bright at night I have to turn off the surge strip to cut the power to the monitor, so I can sleep.
Please help.
Thank you in advance, Kevin
Same Problem
Nov 30, 2008
-   When I shut down my cpu ( windows XP) the monitor
go's to white and stays that way even though I shut
the monitor off. It is so bright I have to cover the monitor
with a heavy towel so I can sleep. Other wise everything
is great with my Dell. I have a 17in flat monitor
Please can someone help me with this?-   Betty08
Solution #1
posted on Nov 20, 2005
Somewhat Helpful)
Kimi
Rank: Guru
Rating: 80%, 714 votes
The problem is in the "soft switch" technology:
On some of Sylvania's newer monitors they have incorporated what is called "soft switch" technology. This allows your ATX power supplied computer to turn your monitor on and off using it?s software controls. Therefore, your monitor?s light will always stay on blinking even when your computer is off.
The monitor in normal operation consumes about 80W of power; in the "OFF" state it will be reduced below 8W. The "OFF" mode of the monitor can be controlled by the PC input signal or by pushing the soft-power button to disable the PC signal control for manually turning off the monitor screen.
Thus, when the monitor is in soft-power "OFF" mode it still consumes a very small amount of power. For the purpose of making it noticeable to the user that the monitor is in soft-power "OFF" mode, we designed the power indicator to provide for a slow blinking signal (every 2 seconds). If you need to totally turn off the power, then the power cord would have to be unplugged. The same is true of the PC itself, but the PC does not provide for notification while in "OFF" mode.
Your monitor looks like it may be in need of repair, contact info:
PTI Technologies Inc.
7372 Doig Dr.
Garden Grove, Ca 92841
Phone: 714-799-3899
Fax: 714-379-6290
Hours: Mon - Fri 8:00am to 6:00pm PST
Was this helpful?
Yes
No
Popular Solutions for Sylvania L181 18.1 in. Flat
Questions and Unsolved Problems for Sylvania L181 18.1 in. Flat
Do you recommend Sylvania L181 18.1 in. Flat Panel LCD Monitor?
Answer
Answer
I have a HP Pavilion Dv9600 laptop. Laptop turns whitescreen when i shutdown, once it reboot there... (More)
Answer
what do I have to do - to fold up the base on this sylvania flat screen monitor - so I can put it... (More)
Answer
Out of no where my computer just stops (power stays on) and the monitor goes white..sometimes with... (More)
Answer
Screen goes black when room temperature is cool, if room is warm, no problem. What could be the... (More)
Answer
I saw an earlier post on this same problem, but I don't think the posted solution addressed the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
