Question about GE JBP68 CleanDesign Electric Kitchen Range
Burner on GE flatop not working
Has anyone any experience with changing the heating element on our flatop stove?
  • Aland Coons
    Aland Coons May 11, 2010
    I have a JBP68 model with a failed oven (probably computer). Would you like to buy the cook top for parts? It's never had a problem and still works even though the oven is faulty.
    Guru:
  • 60 Answers
We had the same problem with ours. This is likely caused by one of two things: The element could be bad, or the element controller could be bad. I hope this helps...
1. Get a screwdriver and multimeter.
2. Slide out the stove and unplug it.
3. Open the oven door and look along the front edge up under the cooking deck. You will see several screws. Remove them.
4. Pry up the top cooking deck, the deck is hinged on the back side of the stove.
5. Lift up the front end of deck and get something to prop it up with.
6. The heating elements are are mounted to sheet metal strips, which are attached to the bottom of the cooking deck with screws.
7. Plug the stove back in and set the bad element to high heat.
NOTE: THE EXPOSED WIRING UNDER THE DECK COULD BE ENERGIZED TO 220V, ENOUGH TO KILL IF TOUCHED! USE EXTREME CAUTION. NO CHILDREN, PETS OR CURIOUS ONLOOKERS NEED TO BE AROUND WHILE DOING THIS. ALSO, YOU DO NOT NEED TO BE DOING THIS IF YOU DO NOT KNOW WHAT YOU ARE DOING.
8. Take the multimeter probes and check the voltage going to the element. If the voltage is 220V, then the element is bad. If no voltage or very low voltage, then the controller is bad.
9. Unplug the stove.
10. If the controller is bad, then remove back cover from control panel. Remove controller and replace it.
11. If burner is bad, unplug burner and remove it...you will need to remove sheet metal strip that the burners are mounted on from deck before removing burner from the strip. NOTE: The burners are delicate, be careful.
11.a Mark the metal mounting strip where the burner tabs attach to it with a marker before removing burner because there are several locations on the strip where different burner sizes could be mounted.
12. The replacement burner is expensive. After careful inspection, I found the burner to be bad on ours, and the cause was a broken weld between the burner element foil where it is tack welded to the wire tab at the side of the burner. Looking at the quality of the welds, I would not be surprised if this is a common problem. One could take a piece of steel, say a paper clip or similar, and use a pair of needle nose pliers and fashion a small clip using the needle nose pliers to compress the break in the element foil back together. Otherwise, replace the element. I opted to repair the element and save the money.
13. Reinstall the element and plug the element in. Note, the element can be installed in several locations on the sheet metal mounting strip. Make sure to install back in the original locations that you marked with a marker. Carefully reinstall the mounting strip to the deck. Screw deck back down.
14. Plug stove back in.
15. Cook
Posted on Apr 25, 2010
  • mitch Apr 25, 2010
    One more thing about the instructions above...it should be obvious, but make sure when you prop up your cooking deck in step 5 above, that your prop does not touch any wiring and is not flimsy.
2 hobs on my electric cooker are not working
Fixing Electric Stove Burners that Don't Heat Up Properly ...
? 2:34
www.youtube.com/watch?v=GfqaPcha__o
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Electric Range Stove Repair: How To Repair Burner ...
? 6:52
www.youtube.com/watch?v=ndQU7RtqfRw
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
How to fix la germania burner?
Guess you mean a kitchen appliance not a cd/dvd burner! The only way to help you giving some advice about how to fix ut is if you tell us the problem you need to fix.
Describe your burner: is it a gas burner or an electric burner?
Had you repaired something similar before?
In any case, watch some youtube tutoriasl to repair a burner
Cooktop Range burner not heating burner light is on GE Hotpoint RCA...
GE Hotpoint RCA Gas Stove Repair Burner is not working JGSP44BEY3BB
Prego Project Fix GE Stove Burner
Stove Oven Range Burner Repair Diagnostic GE Hotpoint Kenmore Sears RCA...
Aug 19, 2015 | Computers & Internet
What does the heating element for a electric stove look like
It looks like the thumbnail illustration attached to your question.
Sep 30, 2014 | GE Universal Electric RanCooktop Stove 6"...
Spectra GE model JBP64W0B4WW stove top burner stopped working
Which element is it? Try to switch the infinite switch from another element. This will tell you if it is the element or the switch problem.
Apr 06, 2013 | GE Spectra JBP78 Electric Kitchen Range
Replace heating element in RB790 ge hotpoint. How remove glasstop to reach element
15. Cook
May 22, 2010 | GE Hotpoint 30" Self-Cleaning Freestanding...
GE Evolution stove/oven. My oven is not working,
remove heating element an check with ohm meter. pretty simple really.
Jun 12, 2009 | GE Ovens
Front Right Large Burner Wouldn't Boil, Now won't heat at all
The burner has a short now. The burner is a resistor and when it is shorted the burner will not heat to its full capability. You should be able to replace the burner element. Home Depot or Lowes may have the part you need or you can most likely get them from Amazon. They have everything.
Cheers
Nov 26, 2017 | General Electric Stove/Oven/Range Chrome...
My GE electric burner is not working.
The know that controls the burner is bad. Take off the front cover and replace the control knob. Be sure you unplug the stove. Let me know how it goes. ken
ps write down the wiring of the control there are 5 wires going to switch there will be little letters on the switch like l1 l2 P com on writing like that.
Dec 22, 2008 | GE JRS04 Electric Single Oven
Only high setting works on burner
Sounds like the Switch or the element are bad, try trouble shooting them. It's a stove top??
Eddie Rentas
Tupper LAke NY
Jul 17, 2008 | GE 30 in. JP340 Electric Cooktop
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
GE JBP68 CleanDesign Electric Kitchen Range Logo
339 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
