I have an old Sony CRT TV. The Pictures are always redish in color.
  • 10,594 Answers
Let me know tv model number to suggest any help.
Posted on Sep 05, 2008
Color faded.like too much redish
Check the video output card. Look for any loose solder terminals at it. Re-solder all the suspected solder terminals, by applying a little more solder. This card can be located at the neck of the CRT, will be just plugged on to its back. Check the solder terminals of the CRT abse socket too. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 03, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture is redish pink
Absense of Green Color is the fault. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help.
Apr 01, 2013 | Sony KV-36FV16 36" TV
Tv plays but picture is orange redish like tried to ajust color and tint still the same
Tv have a problems known as a picture convergence problems,it is dead.If the tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,then the tv convergence board it is dead,the tv convergence board must have replaced like 2 STK convergence ICS and some or all of resistors replaced too.To fixed the tv convergence board to solved tv convergence pictures problems.The tvs Shops will cost u like $300-350 for parts and lobors.
Jul 27, 2011 | Samsung PCL542R 54" Rear Projection...
53 inch projection tv...seems like the color red and color blue have shifted giving me a picture with red and blue shadows
For CRT projection TV's, this indicates that the Green picture tube is burned (warn out). The less green that strikes the screen, the more redish the image will look. You will need to find an old school TV repair shop that knows how to replace picture tubes.
In the case of a DLP style TV, the color wheel needs replacing.
Dec 29, 2009 | Hitachi Televison & Video
I have a red ghost image on the screen
Projection TV sets have two common problems. The first is known as a convergence problem. Common symptoms are....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
The other common problem is cloudy CRT fluid in the lens.
Common Symptoms - you TV may have one or more of these...
  • Dull Video
  • Bright video - whiteish
  • Redish video
  • Halos around objects
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 27, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
My tv colors have started to fade.
Ya, I think your Tv has weak CRT problem. or the FBT need replacement. You consult the tech. of sony service center.
Jun 10, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV has color bloches at corners
Assuming this is a tube style TV (not lcd flatscreen) your degausing coil in your TV sounds like it is defective . The Degaussing coil on newer televisions / monitors surrounds the outside edge of the TV and turns on when the TV is fired up. In the old days, their used to be no degaussing coil - when a child would take a magnet to a CRT television, magnetism would remain on the tube and cause discoloration and blotches as you describe (multi-colored blotches) To correct this a technician used to use a degausassing coil and perform a circular pattern on the screen to remove the improper magnetized area. Since the old days, newer tvs have degauss coils built into them, but if they go bad, or always on etc... they can cause the problem you describe.
Apr 11, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Color adjustment on Sony 36" Trinitron
Unfortunately, the CRT (Picture Tube) is reaching its very end. Your set is not feasible to service even if the CRT would still be available from Sony or any jobbers.
I would be seriously shopping for a new TV set!
Jerry G.
Oct 27, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Mitsubishi cs-40503 tint problem
internal codes are good, but when the is like what you post then a tech is what you need.it seems that one of the problem is the flyback transformer or the CRT cap.have a tech check you unit.
Sep 08, 2008 | Mitsubishi CS-40503 TV
After 5 minutes of good use screen goes redish color
It certainly sounds like the Red CRT (picture tube) has heater-cathode leakage and is not likely worth repairing, as all 3 tubes usually have to be replaced at the same time for best picture quality.
Feb 10, 2007 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
