Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Print head installation on a cannon pixma ip190
How do i install print head for canon multipass mp390
Posted on Oct 29, 2008
ERROR MESSAGE U051
Print head not installed,
or not properly
installed.
[1401] U051 Print head is not installed. Install
the print head.
Install the print head properly.
It may be that print head is defective or main PCB assy
Jan 12, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Cannon MP510 printer has Error, - The type of print head
I solved this on mine by removing and reinstalling the print head.
1. Remove and set aside the ink cartidges (don't make a mess)
2. lift the gray print head lock lever that is to the left of where the ink cartridges go.
3. Lift out the print head out without touching the ink ports inside, the contacts on the back, or the print nozzles on the bottom. The print head is the grey thing with circular ink ports that seat the ink cartridges. there are good pictures in the PDF of the Easy Setup Instructions available on the Canon Printer website. Look under the printer, then support, then downloads: http://gdlp01.c-wss.com/gds/0900002776/mp510_esi_us_v2.pdf .
4. Put the print head back in, lock the lever, reinstall the cartridges in the roper positions. And voila!
If this doesn't work you may actually need a new print head.
Oct 08, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Error on printer Connon ip 1000
Error code: 5600
Description: Cartridge displaced error
Symptom: blink in orange 9 times,beep 10 times
try removing and replacing the cartridge
please rate our help to keep the service online
Aug 24, 2009 | Epson Stylus Photo® R2400 InkJet Printer
Cannon Pixma MP830 - smearing on front when printing
If you have taken it apart that far then you are way ahead of the game. My suggestion would be to clean the head or anything the ink touches in a vinegar/water solution. The vinegar dissolves any dried ink whereas the soap may actually gum things up. If that doesn't work or improve things I would say that your print head has a seal problem. The replacement print heads are worth more than a new printer so you can probably figure out whats cheaper to do.
Aug 21, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Cannon pixma ip1000
..ip1000 questions..
..it's cleaning time, a simple if messy operation. You will have to clean the print head and the waste ink pads, and whilst there might as well clean all the other gunk as well..
..so how to do this ?
..power on, open front, let carrier slide to middle front, pull power cable, pull computer cable.
..Remove cartridges
..by hand slide carrier to left to below the grooves in the upper case front. Clip the grey print head retainer, it pivots to the printer back, it must go up in the grooves, then remove print head, it comes forward..
Sep 09, 2008 | Canon PIXMA iP1600 Printer
Cannon mp830
Hi try to remove ink cartridge and put it back , push down the cartridge to engage will the micro chip.
Mar 09, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Blur colors
are you using new cannon ink cartridges?
if you are replace the print head if your not start.
Jan 06, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Cannon PIXMA MP170, printing problems
Maybe the USB cable was plugged before the driver has been installed : I noticed this advice in my manual.
Apr 16, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
116 people viewed this question
old marine
old marine
