Question about JVC HD-52G786 52" Rear Projection HDTV
Blank screen on Digital In
I have a blank screen on my "digital in" input. Could it be that the HDMI input is bad? I've only had this TV for 3 months. Cable company came out and verified it was not the cable box by connecting another one and getting same results. I am able to use Video 1 as an alternative. Please advise.
  • bkranch Nov 01, 2007
    When I put set on Digital Input, then turn on the cable box, I get sound but the picture lasts for about 3 seconds then the screen goes all green. If I unplug the HDMI cable then plug it back in again, I get same same results.
  • Anonymous Mar 22, 2014
    When I am connected to a cable box with HDMI, the TV digital optical output does not output sound to my external amplifier
Go into the service menu using the remote (hit the sleep timer, then video status and display at the same time), go into the status menu #2, then power off the tv. This will reset the HDMI port. If your sitll experiencing the issue, probably a dead board.
Posted on Apr 25, 2007
  • 1,476 Answers
When you say that they hooked up another one and got the same results I'm assuming that you mean that they hooked up a new box to your set (HDMI input). If this is correct it does not prove anything except that they got the same results. How do you know if the output on their box is outputing anything or the correct signal? The better way to eliminate the box would be to hook it to another HDMI input on a known good set and see if there is a picture. Their box might have the output turned off or bad. Eliminate this variable first and then you can proceed to whether or not the HDMI input on your set is bad. Good luck.
Posted on Jun 22, 2006
Power indicator on, logo flashes briefly, but then no picture. What's wrong?
SEIKI Tv SC501TS has audio but no video, repair - YouTube
? 1:38
https://www.youtube.com/watch?v=cWpF4q_rBaw
Oct 19, 2014 - Uploaded by EurekaRecycler
SEIKI Tv SC501TS has audio but no video, repair ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test - How to Fix LCD ...
LED TV Repair Main Board Overview Blank Screen-TV Has ...
? 2:57
https://www.youtube.com/watch?v=-TU2KSuect4
Mar 4, 2014 - Uploaded by ShopJimmy.com
Learn why your screen is blank and you have audio - No image LED TV Repair Review Main Board Problems ...
LCD & LED TV Repair - No Image & Blank Black Screen ...
Dec 13, 2015 | SEIKI Digital Seiki SE32HY10 32 720p...
Chromecast is not working with jvc hd52g886
Don,
The HDMI is best..but you need the standard HDMI cable. BUT this JVC is in the new Noah movie? Seriously, it wont handle Roku. The digital in function is strictly 480 p.
I think you will have to upgrade to a newer tv for this source
Mar 23, 2014 | JVC HD-52G886 52" Rear Projection HDTV
LG 37LD320H Has a blank sceen only on Satelite input. The line is fine because i hook up a different tv and it works. Any ideas?
So the TV internal electronics for decoding the signal have failed. You could replace the TV. A cheaper alternative is to find a VCR or digital recorder that can take the satellite input in, and put the picture out on an HDMI cable to your TV.
Dec 20, 2013 | LG 42PC1D 42 in. Plasma Television
I have a Sharp Aquos LCD TV Model LC-32BX6M , when I try to connect a new generation Android TV Box HDMI Out to TV's HDMI input the Android Logo appears and after sometime the screen goes blank t
im not sure but could it be a comparability issue with the device and the wake up signal from the device to the tv? android systems use a Linux based file system, so the problem may be in the tv's input settings. hdmi input from the device to the tv. and then go to tv input mode and see if putting the device in another hdmi port doesn't work.
Oct 15, 2012 | Sharp Aquos Televison & Video
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
My ps3 wont work with my hd/mi cable, i get a blank screen, but it does work with the rca jacks?
What you need to do is connect it from both the red/white/yellow cable and your HDMI. Go to your video input on your TV to where you can see the display. Go to settings - Display settings, and switch your input display from composite to HDMI. Your screen will go blank. Once blank, turn your TV to your HDMI input and when you see the picture, save settings and completely unplug the composite cable. You should be good to go.
If this helps, please give me a 4thumbs up!
Respectfully,
Don
Jul 06, 2010 | Sony Playstation 3 (PS3) Console
My hdmi does not work
Respectfully,
Don
Mar 26, 2010 | Sony Playstation 3 (PS3) Console
Toshiba TV fails to recognize HDMI input
If the tv does all those symptoms but after some seconds the tv works and stays doing the job. THen the tv has a slow microprocessor to recognice the different resolutions or video inputs.
But if the tv cannot do anything and stay aout of signal forever. send the tv to the waranty. (no waranty? you have to use the component input instead to have digital signal reproduced
Apr 24, 2009 | Toshiba 40RV525U 40 in. LCD TV
Vertical red/green lines
This set has a bad digital board.and or signal board
The company is in California and is a china inport.
Digital and signal board could cost $130+
Nov 03, 2007 | Soyo Dymond DYLT032A Television
JVC HD-52G786 52" Rear Projection HDTV Logo
490 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
