Question about Jensen CD510K CD Player
How do I adjust the time?
I lost the manual awhile back and can't remember how to adjust the time and have it displayed. Can you provide me with the procedure?
    Novelist:
    Champion:
  • 277 Answers
Try this, it is from a very close model of Jensen: Press the DISP button to show the clock, and then press the DISP button again and hold for > 3 seconds until the clock flashes. Press the DOWN TUNING (<<-) button to change the minutes and UP TUNING (+>>) button to change the hour. Continue changing the hour to move between AM and PM. Hope it helps
Posted on Nov 20, 2005
SOURCE:
Clock is 2 hours ahead of actual cst time
If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
May 06, 2011 | Watches
The actual temperature (as measured by repairman's device) is 20 to 30 degrees lower than indicated on the control panel. Should the control panel be replaced in a 7 year old range or should the range be...
You can adjust the bake average temp +/- 35 degrees this is called calibration.
Here's How:
To Adjust: 1. Press the BAKE pad (upper or lower oven) and enter 550° F. 2. Press and hold the BAKE pad (upper or lower oven) for several seconds until TEMP ADJ is displayed. 3. Press the AUTO SET pad - each press changes the temperature by 5° F. The control will accept changes from -35° to +35° F. 4. If the oven was previously adjusted, the change will be displayed. For example, if the oven temperature was reduced by 15° F, the display will show -15° F. 5. When you have made the adjustment, press the CANCEL pad and the time of day will reappear in the display. The oven will now bake at the adjusted temperature.
Do this first and you will be back to normal. If your using a oven temp. checker make sure you let the oven cycle for awhile. Preheat should take about around 10min. Remember 350deg is an average temp.
Have a great day!
Dec 07, 2010 | Maytag MER6772 Gemini Electric Kitchen...
How do i change the time setting from 24 hour to your average 12
For all those who lost their Casio watch manual. Follow this link, fill in the requested details and download manual. http://world.casio.com/wat/download/en/manual/
Nov 12, 2010 | Casio G-Shock GW500A-1V Wrist Watch
Hi there, I got the Citizen Projection Clock DX8200-B as a birthday present from a dear friend. At one point of time, I misplaced the manual. I do not know how to adjust the the time and the date on the...
I have the same clock and i went back to the shop to help me adjust the time today. I lost my manual and could not figure out how to adjust the time. First, push MODE until it displays the temperature. It will not work if the alarm time is being displayed. Then, hold MODE for a few seconds and the year, month, day will start to flash in sequence if you push MODE again. Push MODE again until the time starts to flash and there, you can adjust the time with + or -. Good Luck!
Nov 02, 2010 | Watches
How do you adjust the clock on a C50? I lost my owners manual.. Thanks, Ed.
From the handbook...button 5 is the left one if u are sitting on the bike and button 6 is the right one.
"push buttons 5 and 6 simultaneously until the hour display blinks.
"adlust the hour display by pushing button 6
NB when button 6 is held down the display advances continuously,
"Push button 5 to highlight the minuite display.
"adjust the minute display by pausing button 6
"when you hsave reached the correct time then push button 5
this will take you back to the time mode.
hope this helps.
oscargilpin
Sep 28, 2009 | 2005 Suzuki Boulevard C50
Need instructions for t436b night light
Here is a link to the manual.
http://www.timexaudio.com/pdf/T436_IB_(new)_v3b40949_96.pdf
From the manual here is how to set the time.
2. Press and hold the Time Set Button until the time display blinks.
3. Press the << or >> Button to adjust to the correct time. Press and hold the button for faster forward or backward
adjustment.
4. Remember to set the correct AM or PM. The PM Indicator is located on the upper right side of the display;
there is no AM indicator
5. Press the Time Set Button again. The year display will blink.
6. Press the << or >> Button to adjust to the correct year. Press and hold the button for faster forward or backward
adjustment.
7. Press the Time Set Button again. The date display will blink.
8. Press the << or >> Button to adjust to the correct date. Press and hold the button for faster forward or backward
adjustment
9. Press the Time Set Button again or wait for about 10 seconds to exit the time setting process. Two beeps
will confirm time setting mode is complete.
Sep 08, 2009 | Timex T311T Clock Radio
Lost my user guide, cant remember how to adjust analogue time.
Try this:
Rate, please.
Mar 30, 2009 | Casio DB360G-9A 30 Pages Telememo Watch
HOW TO ADJUST TIME ON G 9000 MC
I have A Casio G- Shock, Can't remember how to set the time!!
Mar 08, 2009 | Casio G 9000MC 3DR G-Shock Mudman watch
Adjusting info display after battery disconnect
The instruments you talk of don't have a memory that retains info if the battery power is lost, the technician has a little back up power supply that goes in the cigar lighter to avoid this loss of memory.
Sep 25, 2008 | 2001 Mitsubishi Montero
Lost the manual for my Casio AW-80-1AVEF, cannot work out how to adjust the time, i have used 'adjust' and mode but that just changes the lcd display not the clock face...
Go to http://www.casio.com/support/
Click on watches. That should open up a popup. Select manuals and enter the 4 digit module number from the back of your watch. If they have that model, then you should be able to download the manual.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 03, 2008 | Casio Casual Sports Watch HDC6007BVCF
Jensen CD510K CD Player Logo
83 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
