FixYa.com
Tags:
Emerson MS9700 CD Shelf System
MS9700 secondary voltage
posted by Guest on Nov 18, 2005
I need change the voltage transformer, it is burned, but i just don't know the outpout voltage
Best Solution
posted on Dec 08, 2005
Thanks for Trying (70)
PeteMI
Rank:Apprentice Apprentice
Rating: 70%, 1 votes
I am working on the same situation. DId you first check to see if it isn't the fuse that has blown? Radio Shack has a 4 pack of 2 amp fuses for $2.49 which I think will work. Their catalog number is 270-1064. These as 5x20mm in size (the 1-1/4 x 1/4 inch is way to large) and they are slow blow - designed for this type of household equipment to protect from short circuits and power surges.
If you are lucky maybe it is just the fuse. Since I can find no other information about this unit - especially the transformer - I'd check eBay for a working one. If you can get it cheal and it works test the power output with a VoltOhmMeter (VOM) and once armed with the info you can let me know too what the output is <smile>. You can then get a new transformer - have 2 working units - can keep or sell one to recoupe your eBay purchase. Just a thought. Hope it is only the fuse.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Nov 20, 2005
Not Rated (0)
Kimi
Rank:Wiz Wiz
Rating: 80%, 622 votes
This product is designed to operate on normal 120V 60Hz AC only.
Can you Help with these Audio Shelf Systems problems?
CD player
CD player will read the bottom... Answer This...
cd not playing
why would a copy (cd-rw) of a... Answer This...
How do I get to the broken...
How do I get to the spring... Answer This...
AM/FM Radio Section
The CD and Tape sections work... Answer This...
cd player not working
emerson home audio system with... Answer This...
Repair Service
Find Audio Shelf System Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
