My Sharp Aquos TV Model LC-30HV4U (1) has a large black triangle in the middle of the TV screen, and (2) the letters of words that appear on the screen are in reverse order and so are illegible.
  • bkolbor Sep 06, 2008
    I have corrected the "upside down" picture. The remaining problem (the picture I get is from its reverse side - so that words and letters are reversed and there still is a large blacked rectangle in the middle of the picture might be corrected by "rotating" the screen, but I do not know how to do this. Please advise me how to do this. Please, no more so-called "solutions" that require scrutinizing or printing out a huge "troubleshooting" manual or the 86 page
    Sharp Aquos manual. Thank you.
    I have now corrected the problem of the picture being reversed by clicking on the "rotate" option. However the blackened large rectangle in the middle of the screen still pops up and remains. Is this a "parental control" issue? I have never activated or otherwise used "parental control". I have tried unplugging the TV from its main power source for 2 hours, but this does not cure this last problem. Please give me what advice/help you can about this remaining problem? Thank you.
    Genius:
  • 1,269 Answers
I think you need Pincushion Adjustment. There may be two controls - amplitude and phase. Pincushion amplitude as its name implies, controls the size of the correction. Pincushion phase affects where on the sides it is applied. You can use the remote and look for pincushion adjustment on the TV settings. If you can reset it to level value or equal value, try it. If the controls have no effect, there is probably a fault in the pincushion correction circuitry. Have it check by a pro TV technician.
Posted on Sep 06, 2008
  • 10,594 Answers
I think its Menu box appearing on screen of tv and can be disappear by pressing Menu or Display button on its remote.
    Master:
  • 638 Answers
This is the rare problem faced by the sharp Aquos TV Model users ,as its the problem of the settings in the main board of the tv , if its under warranty get it replaced, if its not then call the technician of only sharp to make it clear as the local technician will not be able to do this properly.the charges for this reparing will be bit costly.
as it is the problem of wrong settings adjusted and should be cleared by the company by making it deleted and creating new setting again.
thanks.
please rate the solution
  • 185 Answers
Please contact Sharp at 1-800-BE-SHARP (237-4277) and report the problem, Sharp will give you a Case # that you will need if any service is to be needed or done
    Master:
  • 505 Answers
Unplug From power point for 30 to 45 minutes then plug back in. should go away
    President:
  • 1,257 Answers
Use the link below to troubleshoot the issue -
http://www.repairfaq.org/sam/tvfaq.htm
also download the manual for your television from the link below
http://www.sharp.ca/manuals/
Posted on Sep 05, 2008
  • 983 Answers
If you the reset option once you try resetting ...
if you still persist the problem i think there will be some problem in the tube in that area ...
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Sep 05, 2008
    i think the electron are not getting emmited in that area from the tube so it is appearing black in that area
    once you take a magnet and rub it against the screen where it appears black ...
Sharp aquos LC-30HV4U red light on , does not power up , any ideas ?
I have not had that exact problem, I'm sure you have tried powering off for more than 10 minutes, for some reason that has alway fixed my issues with the same model you have. Good luck!
May 27, 2014 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
I get a large black rectangle covering 1/3 of my
I have a similar problem using an older 20" flat screen standard definition TV. (not High Def). I can see a little of the picture but more than 2/3 is covered by the black. My model is LC-20SH7U.
I used sharpusa.com "contact us" section.
Hopefully I get some kind of reply to report what they say.
May 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Can I use the AVC system of a Sharp LC 30HV4U on a LC 37HV4U TV
i have the sharp lc-30hv4u but i dont have tha avc box i need buy the box if do you have i can buy call me 702 3280184 thanks
Oct 15, 2009 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
Feb 28, 2009 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Sharp Aquos LC 37HV4U - problems with AVC
I have a fully functioning lc37hv4u box & cable that I will sell for 200$ my lcd got cracked. let me know psxpirate25@hotmail.com
Jul 05, 2008 | Televison & Video
replace the supply board
or repair it *** there's problem with supply
Jun 13, 2008 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
