Question about Minolta Office Equipment & Supplies
We have a CF5001 and it is giving an error code SC29-07 and will shut down. We need help ASAP, all the shops are closed and we need to know if there is anything we can do to fix this error.
  • pah1803 Oct 13, 2008
    Konica Milonlta Colorforce 8050 with same error code
  • Minolta Master
  • 6,168 Answers
Yellow drum remove it behind it (looking at as if you are on the left side . Having just taken out the drum look to your right toward the front you will see a small chrome /silver bar with a tiny little square, that is a sensor, dust it off, if code comes back try swapping drum and or sensor one for each drum see if code chagnges
Posted on Nov 22, 2015
2 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: Xerox Workcentre C2424 error code
That is a serious error code indicating hardware failure. Anything with a 07 is a major fault inside the machine. I am not seeing that exact error code referenced anywhere, but I can tell you that it is going to need service for certain. There is no simple thing you can do to get it back to functioning, unfortunately it will require a Xerox service person.
I am so sorry about that, if you really want to know what the error code is specifically referring to please reply here and I will continue to track it down for you, but thought I'd let you know right away that it is something major for sure.
Thanks
Tim
Posted on Oct 27, 2010
Error C500.
PROBABLE CAUSES:
1. Insufficient airflow during idle causing internal machine temperature to rise. Toner is backing up or solidifying in the cleaning unit box for the transfer belt causing the transfer belt drive motor (M18) to bind.
Replace the Belt Cleaning Unit (p/n 65LA R702 00) and install attached Special Printer Control firmware (version 51-PBF0 for the 8050/CF5001 and version 12-PBF0 for the bizhub PRO C500). This firmware keeps M11 (Transfer Belt Cooling Fan) ON for a period after the copy process has completed which helps keep the internal temperature at normal levels. The firmware can also be download from the Konica Minolta Download Selector. Access the Selector from SSD Web Support (CS Expert Support) by clicking on 'Download MSDS, Drivers, Firmware and more'.
Note: Firmware version 51-PBF0 is primarily for the 8050, but can be used for the CF5001. When using the ISW tool to download the firmware please select the 8050 from the drop down. If the CF5001 is selected the ISW tool will not see the file.
2. The paper exit fans (M61/M62/M63) DIPswitch is not turned ON.
Set software DIPSW 21-0 = 1 to enable the paper exit fans.
3. Dirty or failed transfer belt drive motor encoder disk sensor assembly.
Clean the transfer belt drive motor encoder disk and sensors. Replace the assembly (p/n 65AA -909 1E) as necessary.
4. Failed M18 transfer belt drive motor.
Replace M18 transfer belt drive motor (p/n 26WA 8001 3).
Jan 18, 2011 | Office Equipment & Supplies
The fan on my R52 has been getting noisier of late, and now when I turn on the laptop it makes a fan noise (as bad as it has been) and after about 4 seconds the laptop shuts down and Fan Error is displayed...
FAN is out...replace fan...else ur processor will die soon....dont use the machine....take it to a tech shop and replace fan ASAP....
pls revert back...kindly give a feedback and rating to this solution....it will help me move to the next level "Guru,,,,"
regards
Sep 29, 2010 | IBM ThinkPad R52 Notebook
I have a canon mx700 & have an error code 6A80 -need help
That error says there might be paper scraps stopping the purge assembly on the right where the printhead parks, or something fallen into the slot where paper goes stopping the paper feed assembly. You just have to inspect closely with a flashlight before taking to the shop.
Jan 05, 2010 | Canon MX700 Office All-In-One InkJet...
Boot Error Shutting Down Sony NWD-B103
down load teh latest firmware from following link & update your player...............cheers....!!!!!!!!!!!!!!
http://www.sony-asia.com/support/download/product/nwd-b103f/modelfirst
Sameera
Apr 23, 2009 | Sony Audio Players & Recorders
Furnace runs but won't ignite.
Error code 12 is blower on after power up. Meaning: after you turn on power to the furnace for aprox. 60-90 seconds the blower will run. The blower should then shut down and the furnace should go through the start up process, providing that the thermostat is set for and calling for heat. If the furnace fails to start after blower shut down there should be a new fault/error code. However if the blower continues to run longer then 90 seconds and continues with the same fault code more then likely the circuit board is bad. Please let me know if this was helpful and give me a rating. Good luck.
Feb 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Windows Explorer error after pressing Start -> Turn Off Computer!
Do you close down your applications first before shutting down? If not, give that a shot. If that fails try closing things down in the System Tray (icons by the clock). Try these things first and if that doesn't work, I have a few more things to try.
Jan 16, 2009 | Microsoft Windows XP Professional for PC
ASAP!!!/ D: Drive problems
what is the error message you get?
Dec 12, 2007 | Acer Aspire 3680 Laptop
69 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
