Question about Electrical Supplies
Coleman powermate 6250 generator will not start
About a year or so ago, I purchased a Coleman Powermate 6250 premium pus 5000 watt generator from an individual. It has remained in the original unopend box until today. I added fresh fuel and SAE 30 oil and attempted to start it. Nothing -- seems as though it is not getting gas. I checked the shut off to ensure it was in the correct position and even pulled the hose to verify. I also loosened the fuel bowl and as I did gas poured out -- so there is gas at least there. I sprayed starter fluid into the carb and it will fire up for a few seconds and the shut off agin. The engine is a Briggs and Stratton 10 HP OVH. The manual is pretty much useless -- has no trouble shooting tips at all. Any help is appreciated!!
Harold
  • 1 more comment
  • htreblat1 Sep 05, 2008
    I took off the fuel bowl and it looks like the float is OK and not stuck. Is there a way to verify -- it seems to be moving freely? Also, The generator was stored without fuel or oil -- kept in the box straight from the manufacturer.
    I pulled the spark plug and reconnected it and then pulled the starter a few times -- there is no visible spark. It has a on/off switch andit is also equipped with an oil sensor that will not allow the engine to be started if the oil is low -- possibly this sensor is inop/stuck -- is there a way to by pass it?
  • Anonymous Mar 14, 2014
    i have a briggs 190cc on troy built push mower..cleaned carb twice..put new plug..its getting fuel to carb,but not getting fuel to cylinder. it will fire up with starting fluid or by pulling plug and putting a little gas in cylinder. any thoughts??
    Genius:
  • 2,028 Answers
I have one of these generators, and I can tell you that at least once a year, I have to pull the petcock type assembly off tank, and clean it. I also drain and clean the tank. It gets a sediment build up, and the petcock system isn't the greatest in the world. I'm going to say that you either have a problem in the petcock type assembly, or you have a stuck jet in the carb, either of these can happen with it sitting for the long period of time. Start by removing the fuel line to the carb and checking the fuel flow. Sounds like you may have already done this, I'm unclear on that. Then I would remove the carb, and soak it overnight in a penetrating oil. This will loosen up any rust or parts that may be sticking. One other thing you may consider, depending on where you live, you may have a mud dauber or wasp nest in the intake or other critical area of the engine. I still get amazed at where I find mud dauber nests occasionally, the little buggers seem to be able to get anywhere.
Posted on Sep 05, 2008
  • Ryan Rogers
    Ryan Rogers Sep 05, 2008
    If you didn't have any spark, then it wouldn't run when you primed the carb. If it's not getting a spark now, then it could be a ground wire, or the other two parts you mentioned (oil sensor, and kill switch) You can bypass the kill be removing it. It simply creates a connection and grounds out the spark. The oil sensor works a little differently, but with the same basic principle. I think it's a breaking switch, that uses the oil to create the continuous connection, when the oil is low it breaks the connection and grounds out the spark. With the sensor, you will have to jumper the leads in the connector to bypass it.
    Genius:
  • 1,269 Answers
If found an article with almost the same problem as yours. You don't have the same generator model but the troubleshooting tips I believe is really helpful since you said the manual has no troubleshooting tips at all. There troubleshooting information on the link will only make sense and will only guide you on identifying the main cause but doesn't necessarily apply exactly to your generator's model. Check it HERE
    President:
  • 1,263 Answers
Is there a kill switch? there should be. did you check to make sure you had spark?is there a primer pump for the carb?is it choking properly?is the coil wire hooked up as it should be? this includes not only the plug wire but the wire to ground and if applicable the kill switch? check the air gap with a feeler gauge the gap should be no more then .012 and no less than .010 these are a few options to check out. keep me posted.
    Brigadier General:
  • 5,158 Answers
Was it stored with fuel in it ?
Robert
almost sounds like a stuck float in the carb.
  • 1 more comment
  • Roberta Smith
    Roberta Smith Sep 05, 2008
    a couple things... i presume you have already put it back together. but dirt in the fuel line will not allow fuel thru and that appears to be the problem.... the float controls a tiny valve... the theory is the float shuts off the fuel supply to avoid fuel spillage. that valve is i believe copper. if you can move it with something to insure it has free movement as well that may be the solution. it could possibly have become stuck. whatever you use to move it do NOT scratch it. if you have trouble locating it.
    look where the float bowl hinges. there will be a tab and it preses up or down (whichever way it moves) under that you will see a round pin shaped part. that has to be able to move freely to allow gas to go past it.
    ensure there is proper movement of the float up and down.
    if that appears fine... attempt to start it a few times.... afterward pull the spark plug... is it wet (fuel) ?
    Robert
  • Roberta Smith
    as someone mentioned before... kill switch is set in the right position to start. odd that it would run with spray thru the carb and suddenly it has no spark.
    Robert
  • Roberta Smith
    Roberta Smith Sep 06, 2008
    you have it fixed now ?
    Robert
  • 19,396 Answers
Evidently carb is not getting enough fuel or air.
  • Ginko
    Ginko Sep 05, 2008
    This generatior should have an air filter, check that the air intake is not obstructed, and if there is air filter check it.
    If the generator started by dropping fuel directly into the carb, then is a fuelling problem.
    Check that fuel is being pumped into the carb, if fuel is being pumped there may be not enough pressure, or there may be an obstruction cutting fuel occasionally.
    If fuel is not being pumped at all you will probably need to replace fuel pump.
    If fuel pump is pulled by belt, check that serpentine belt is in tension.
    If fuel is running check the fuel lines for obstructions.
    Check that hose coming from fuel tank is not obstructed with oxide and dirt, eventually blow it with a compressor.
    There should also be a plastic fuel filter on the fuel line, try removing it to test the lines, if it is obstructing the flow, replace it.
I cannot locate the owners manual for my Coleman PowerMate 6250 generator 10 hp? Any place I can find this online quickly thank you
Most PowerMate manuals are available here: http://www.powermate.com/productmanuals.php?cat_id=3 . However, describing it as the PowerMate 6250 10 HP generator is insufficient to find the correct manual. The Coleman PowerMate line has several models with 10 HP engines and a 6250 Starting Watt (5000 W running) capacity.
These include the Powermate PM0435005; the direct link for this manual is http://www.powermate.com/pdfs/2011/12/29/pm0435005.02.pdf .
Please add a comment with the actual model number of your generator if you need further assistance with finding the correct manual for your generator.
I hope this helps.
Sep 05, 2017 | Coleman Electrical Supplies
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
How many watts is the Coleman Powemate Premium Plus 6250W portable genr
Hi, the constant delivery is about 5000 watts and the peak delivery is as the name says 6250 Watts. Hope this helps.
Nov 18, 2010 | Coleman Powermate Premium Plus 6250W...
I have a coleman powermate 6250-5000 running watts-generator. The generator starts and runs but does not produce current to outlets,the outlets are fine-they have continunity,I removrd the armature and...
You may have just lost residual magnetism in your rotor. Start genset then apply 12 vdc to 120 v outlet for less the 1 seconds. This will be enought to restore the residual magnetism to the rotor and the unit should be producing power now.
Nov 17, 2009 | Coleman Powermate Premium Plus 6250W...
I have a coleman powermate 6200 that puts out no elecietety
Here is a link to a general solution I posted some time ago.
If that doesn't solve the problem let me know.
Regards,
Carl
Feb 22, 2009 | Coleman Powermate Premium Plus 6250W...
How many gal tank is the Powermate 6250 10 KW
Nearly all of the Powermates have the same 5 gallon fuel tank.
I'm a little confused, the Powermate 6250s are all 5Kw generators with 6250 watt surge ratings. Is yours really a 10Kw or did I misunderstand which generator you have?
Carl
Dec 12, 2008 | Coleman Powermate Premium Plus 6250W...
Need to know about this generator. Coleman Powermate 6250 Gen power 305 5000 running watts Model PM0545008 Serial # E06601199B
To find a manual for this generator go to powermate.com and search your model and serial number. Good luck!
Dec 05, 2008 | Coleman Powermate Premium Plus 6250W...
Looking for a Pricesheet
google"coleman powermate". on the site look for manuals. the price list is the top manual. kinda small. you may have to increase magnification. mike
Nov 17, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
4,798 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
