Question about Emerson Smartset Clock Radio
Bulb on apparatus that pojects time on ceiling burned out
Where can i purchase another bulb ?
    President:
  • 814 Answers
Sorry it took so long to give you a answer to your problem.You will have to remove the bulb and find the type of bulb and the voltage and current rating. This is usually marked on the bulbs metal casing.There may also be a brand name and a part number. Put these number into a search engine. If you have the correct number the search engine will find the part for you, if it is available. If this solution does not work for you, call the Emerson Customer Support. You can call them at this telephone number 1-800-909-1240 between the hour of 8am-4:30pm CT. Tell them the make and model number of your Clock/Radio and ask them for their assistance. I hope this information helps you solve your problem. Thank you for using FixYa and have a nice day!
Posted on Jun 14, 2009
Bulb burning out on projection .the bulb im useing is 21v 150w is this correct
Everything you say can be right. I don't know a Bell & Howell Digital Camera, with a 21v bulb.
why not make a picture from the lamp and post it here, or give a correct description of the apparatus the lamp is coming from?
Jan 20, 2014 | Bell & Howell Cameras
My hunter ceiling fan is not working and according to hunter technical support, I need to replace the remote control receiver (part # 8511204000) at a cost of 50.00 plus shipping.is there a way to by-pass...
If the product did not come with a manual control on it then yes you will have to use the remote. However, if the replacement remote will cost nearly as much as the ceiling fan itself you could simply purchase a new fan.
Feb 28, 2011 | Vacuums
My jvc model #hd-61z456 is working at too dark of a picture. I have replaced the light bulb twice and have reset the picture setting to factory setting and I don't know what else to do can you help me....
Both times bulbs was replaced it lasted 1 1/2 or 2 years right?Use tv on like 4 or 5 hours a day?That the avervage life span of a projection bulb.Try to buy an original JVC pojection bulb last little longer.
Sep 12, 2010 | JVC HD-61Z456 Television
Como Fan MInka Aire light bulb burned out
remove the cover and unscrew the bulb. get a replacement especially designed for a ceiling fan.
Sep 07, 2009 | Minka F603-WH Ceiling Fan
Hampton Bay Ceiling Fan Plastic Burning Smell
I think you have already figured out what the problem most likely is; 60 watt bulbs. Down-size the wattage or install 'energy saver' bulbs if they will fit the application. Instead of counting on these units for extra lighting, perhaps think about Track lighting to fill in those ares that need more but subtle light.
Good luck. :)
Apr 09, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
Light bulbs burn out
Use bulbs specifically designed for ceiling fans - they say "ceiling fan" on the package (Home Depot, Lowes both carry). The slightest regular vibration (like a fan rotating) causes normal incandescent elements to burn out within days or weeks.
If you wired black to black, white to white and green or bare to ground, you wired it right. Sometimes there are two blacks (hots) one for the light and one for the fan, but most of the time you hook the light wiring parallel to the fan wiring unless you install a remote switch.
Feb 18, 2009 | Aloha Housewares (93645) Ceiling Fan
Headlights
The same bulb in a lot of applications controls both the high and low beam. Generally the low beam portion will burn out and for a short time you will be able to use the high beam only. I can't be certain which headlight switch that you checked, but the most common solution is to replace the headlight bulb. The bulb is on the inside of the headlight lense and is accessible by opening the hood and peeling back the rubber cover that covers up all of the headlamp apparatus. Depending on the model of vehicle they are mounted in there differently. Make sure and change both at the same time. It is generally cheaper to purchase new headlight bulbs as a (2) pack and it never fails if you change one the other will burn out in a week. Hope this helps
Feb 15, 2009 | 1997 Chevrolet Cavalier
Bulbs burning out in Hampton Bay ceiling fan
I would suggest getting an electrician to check the current running through the wiring. I had installed a similar fan in my grandmother's house a couple of years ago and had the same problem. After a couple of months of constantly changing bulbs, I brought in an electrician to check the current and found that there was a short in the wire which kept causing just enough of a current surge to blow the bulbs.
Nov 29, 2008 | Hampton Bay 04345 Cruiser Ceiling Fan
Minka Aire Como F603 ceiling fan - light bulb replacement
Try Googling (Minka Aire)(F603)(manual) without parens for instructions.
Jul 28, 2017 | Minka F603-WH Ceiling Fan
This Hampton Bay light fan fixture eats Light Bulbs
Read the manual to find out which size bulbs (base size and wattage) you need.
If you did use the right type of bulb and it lasted only 2 weeks, take them back to the store where you boght them for a refund.
Mike
Jan 17, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Emerson Smartset Clock Radio Logo
135 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
