Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Bulb replacement I have an Hitachi LCD 42" with burned out bulb. Model # 42V515 - I have a new bulb but cannot figure out where it goes. The manual I have is incorect. I called the Hitachi office and they have the same manual as I do, so no help there. Thanks for any help you can provide.
  • 927 Answers
Good Day, technonot;
To replace LAMP remove Front Panel outwards until the quick snap disengages. There is small cover on the left hand side, using a philips screw driver; remove. Two more screws secure lamp, use handle to remove. ALWAYS, unplug TV from A/C power source first. Good Luck, big IRISH.
Posted on Sep 06, 2008
  • MICHAEL MULLINS Sep 06, 2008
    techknownot;
    I for got to tell you about retting the Lamp Hours, do the following:
    1. Please replace to new lamp
    2. To enter adjustment mode push "INPUT" button and "POWER" button more than 5 seconds
      at the same time.
    3. Please push the DOWN ARROW key on the remote, you can see number below "FLEX" menu.
      This number is lamp life time.
    4. Reset lamp life time by the following procedure.
    5. Select (Highlight) this number and push the RIGHT ARROW key .
    6. Then push the SELECT key more than 5 seconds, you can see lamp life time change to "0".
    7. After reset lamp life time, please escape adjustment mode by pushing EXIT key on the remote.
    8. Again Good Luck, big IRISH.
I have the same t.v. the front lower cover comes off with no screws. you will, however need a #2 screwdriver to remove the cover the bulb is in. next remove the cage. the bulb is inside the cage.
Posted on Jul 05, 2009
Change lamp in hitachi 42v515
the lamp ,unit price is USD120
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Nov 09, 2013 | Hitachi 42V515 rear projection TV lamp...
42v515
OFF too the Eco Station ! :( Not worth fixing. Can by LCD or Plasma for $500.00 now.
Feb 09, 2013 | Hitachi Televison & Video
How to replace bulb
Things you will need: 1. Philips screwdriver. 2. Pair of pliers. 3. A new bulb. Note: The new bulb should be handled with care. It doesn't hurt to do a final wipe with a clean, non-abrasive, lent free cloth before the final installation of the bulb. Steps to replace bulb: 1. Turn off the main power to your TV. 2. Remove the front cover from the TV set. This is held by a snap on. Pull the front cover outwards until the quick snap on releases. 3. Remove the screw securing the lamp cover with a Phillips head screw driver and remove the lamp cover. sdulin.png 4. Remove the two screws that hold the lamp in place. Remove the lamp unit by holding the lamp handle, then pulling outwards.sdulin_0.png 5. Next remove the metal cage by pulling outwards and away from the plastic enclosure, the metal cage should come loose. In the picture below you can see a groove where you can place your thumb inside and pull .sdulin.jpg 6. Now unscrew the scew holding the connection plug in place as well as the two screws holding the bulb in place. sdulin_1.jpg sdulin_0.jpg 7. Now take out the bulb from the enclosure. 8. Next swap out the power plug from the old bulb onto the new bulb. Our pliers come into use here to remove the nut from the center of the lamp. sdulin_2.jpg sdulin_3.jpg
Note: Be careful when screwing in the side connector on to your new bulb. It's best to hand torque here as it is very sensitive and might break with too much torque. sdulin_4.jpg
9. Now assemble in reverse order and you're finished!
Mar 06, 2011 | Hitachi 42V515 rear projection TV lamp...
Picture has a red tint what is causung it replaced the blub 6 months ago
the lcd panel was broken, you need a new one , USD100
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
have a nice day!
Jerry Lampdeng Limited
Feb 14, 2011 | Hitachi 42V515 rear projection TV lamp...
Hitachi
You need a new light engine, its possible that you might get one for free from Hitachi (under a special warr.) you will have to pay the repair shop to install it and it doesnt come with a new bulb contact Hitachi and ask about the "engine program" good luck Julio at Millenium tv (702) 736-1091 milleniumtvsvc@gmail.com
Jul 19, 2009 | Hitachi 50VS69 50" Projection HDTV
TV turns on but produces no visual or audio. Screen just stays black
Your lamp is burned out . I have a 52" hitachi lcd as well, and i have hadd to replace the lamp once a year. its a mercury based bulb which emulates alot of heat and if your exhaust fans are not working properly it will cuase it to fail or burn out more frequently than it should. cost is @ $120.00 for replacement bulb
Apr 12, 2009 | Hitachi 50UX52B/53K 50" Rear Projection...
Hitachi replacement bul
Let me know exact model of your Hitachi TV to check bulb availability in parts stores.
Bulb replacement is easy process and mostly it is written on owner's manual of TV.
Please use "add a comment" button to intimate model number of TV.
Thank you.
Apr 06, 2009 | Hitachi REPLACEMENT LAMP, Projector Lamp...
Blue half moon shadow on top of screen
We had this same problem with our 60+ inch Hitachi. Except our tv had a red hue in the center of the tv before we replaced the bulb and then the blue hue joined the red one after the replacement. It ended up that our light engine was defective (which is an extremely common problem in Hitachi tvs). You should read through some of the forums on here to see if you can find your solution exactly (that is how I figured out my problem was our light engine). You might have the light engine problem also, but I am not sure since you don't have a red hue. Hitachi pays for the replacement light engine part (worth $1200). I just finished the process and now my tv is like new. If you want me to go more in-depth with the light engine repair process let me know.
-kdubb
Nov 20, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Lam replaced
you dont reset it the ballast for the bulb took a ****.. i paid 300 for a new bulb and wasnt the problem then paid 150 for new ballast now i think the light engine went bad geeze
Sep 23, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
159 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
