Question about HP Office Equipment & Supplies
I recently purchased an HP photosmar C7280 all-in-one printer,scanner .copier fax. When installing software get error 2738 and also MSI.HP software update. have tried reinstall three times. Help
  • 236 Answers
I would guess you are running windows Vista. This is a VBscript runtime error. To fix this,
goto Start > All Programs > Accessories > then right click on "command prompt" , choose run as administrator
in command prompt type in:
regsvr32 vbscript.dll
hit enter
Try installing now..
Hope this fixes your problem!
Posted on Sep 06, 2008
Windows installer error....?
You dont need to do much about this error "Windows installer Error"
There are 2 reasons why this error comes.
1. Your Microsoft Installer file is corrupted or not upto date2. the software you are loading is not updated. you should download the software from web and install.
First Step,
Click on the link and download the latest installer and install it.Windows Installer 4.5
from the website.. download the last file ( name : WindowsXP-KB942288-v3-x86.exe )
Once you have installed this, Click on Start button, Click on RunType " services.msc" and click ok ( without the "")from the list, look for Windows installer and double click on it and click on START button or STOP Button and then START and set the type to Automatically
Step 2
Clear the temporary folder1. Click on Start2. Click on RunIn the window type " %temp%" without the quotes ( just the %temp% ) and click ok.Delete all teh files from the window that comes on the screen. you might not be able to delete few files, so uncheck those files and delete the rest.
Step 3. Download the software for your Printer from the link belowHP Photosmart C7280 AIO Drivers
When you start the installation, uncheck for any HP updates that come up.
This should fix the issue
Regards,Suhail
May 10, 2012 | HP Photosmart C7280 All-in-One Printer
Photosmart C7250 All-in-One. Copier, fax and printer work. But I cannot find my scanner icon where it was on my previous computer.
Were you able to install the correct driver for your OS? Usually the scanner application can be found in the list of Programs >> HP Photosmar C7250. If what you are referring to is the icon on your System Tray (lower right corner), you can always add an icon there by right clicking the blank space in your system tray and choose properties. On the taskbar tab, click on Customize, look for the icon for your scanner, click for the behavior and from the drop down button, choose "Always show".
Try to scan also by pressing the scan button in your printer and press start to initiate a scan.
Jan 03, 2010 | HP Photosmart C7250 All-In-One Thermal...
Scanner failure-Hp c7280
make sure to go to hp.com and install all the correct drivers for that system
Jul 21, 2009 | HP Photosmart C7280 Printer
Where do i register my copy, printer, scanner, & fax
ritadraudt, You can register your HP products by visiting the following link:
http://register.hp.com/
Jul 07, 2009 | HP Photosmart C7280 Laser Printer
C7280-all in one printer-cannot install hp solutions center
see if the didgital imaging monitor is running on the system tray...you can check for the solution centre if it is installed frm c:/program files/HP/bin/hpqscnvw.exe.....see if it works....else you can download the full feature s/w and drivers for your printer from
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3204785&lc=en&cc=us&dlc=en&lang=en&cc=us
Apr 29, 2009 | HP Photosmart C7280 Printer
Windows vista installer msi errors and fatal error
it cood be the wrong type of photo paper try some other type
I HOPE THIS HELP
SHORTY
Jan 08, 2009 | HP OfficeJet 6310 All-in-One Printer...
Scanner failure error code
You can try a reset on the printer using the # and the number 6,holding them down
while plugging in the power cord at the back of the printer.if it still does not work
then you can try the same with the # and the number 9.If it still does not work,get
your printer serviced.
Jan 06, 2009 | HP Photosmart C7280 Printer
118 people viewed this question
Ben Johnson
