Panasonic SC-AK20 Shelf System
Problem for Panasonic SC-AK20 Shelf System
Tape Deck
By Guest on Nov 17, 2005
Tape deck clicks off won't play. Slows down and stops when rewinding.
Same Problem
Jul 06, 2008
-   cassette deck always open can't closed and play or anything when starting power button or after did it -   s5150dul
Best Solution
posted on May 22, 2006
Helpful)
bmwrider
Rank: Wiz
Rating: 84%, 1893 votes
Really simple one this. You have a slipping belt. Don't try to use any more tapes in it, you end up chewing them up. I change all my belts in my decks every 2 years due to the extreme heat we have here. Unless you know how to strip the unit and can get hold of the correct belt I'm afraid it's a repair shop job.
BMW
To give you some idea of price I charge $50 for a complete service, alignment and belt change.
You rated this solution as "Helpful".
Solution #2
posted on Jul 06, 2008
Not Rated)
s5150dul
Rank: Apprentice
Rating: 0%, 0 votes
the deck of cassette always open when i push power button and then always cannot play the deck etc
Was this helpful?
Yes
No
Solution #3
posted on Aug 08, 2007
Not Rated)
CanDo
Rank: Wiz
Rating: 81%, 172 votes
Yes sounds like the belts are stretched out or worn out if it is belt driven. Direct drive would be the motor going bad. Sounds like it needs to go to the shop.Or a come to your home service.
Was this helpful?
Yes
No
Solution #4
posted on Jul 30, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
well the problem is a bit obvious u just have to open the fricken thing and take the belt off then put it bck on da
Popular Solutions for Panasonic SC-AK20 Shelf System
Questions and Unsolved Problems for Panasonic SC-AK20 Shelf System
Do you recommend Panasonic SC-AK20 Shelf System?
Answer
Answer
have audio sc303 serial no:- gm1303v3631640. do not have a security code. is it possible to get one.... (More)
Answer
When trying to play musicon Sony MP3 in USB mode on my new Hitachi AXM136i - only 1 album will play... (More)
Answer
I need a user manual for Grundig MASQ RRCD 9100PLL
Answer
how do i change the volume set up on my technics class h? i brought it from cash converters... (More)
Answer
lights on cd flashing, doesn't rotate to different cd spots and cd carsel won't open.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic SC-AK20 Shelf System:
Top Audio Shelf System Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Audio Shelf System Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
