Question about IBM NetVista PC Desktop
IBM NetVista8305-MU3 Received this refurbished and first try it started up. Plugged in monitor and keeps shutting it off; not communicating with monitor. What should we do?
  • Klutch Davis
    Klutch Davis May 11, 2010
    how many vga ports are on the back? is the one you're using on the mainboard or a card?
Thanks for the note back. It has one vga port on the back and it's on the main(mother)board.
Posted on Sep 08, 2008
Have refurbished Dell Optiplex gx280. Plugged Dynex VGA display cable in & got nothing. Still only seeing the Dell Digital Input Self Test Feature Check bounce around the screen, as if the computer is...
Hi!
If you are able to use a known good monitor with Dell Optiplex GX280, obviously the problem is with the monitor. If you only have one monitor, try to reseat the cable from the monitor going to the blue port if its analog (white port if its digital). if it does the same thing tried to open the chassis then reseat the video card (check this site for the instruction for the manual, http://support.dell.com/support/edocs/systems/opgx280/en/ug/index.htm)
if you still dont get anything on the screen, most likely the problem would be the video card.
If you tried to connect the monitor to a laptop make sure to toggle it using FN and F8. Toggle it three times and observe if you'll be able to see display either on one screen or both. if you're able to see something on the laptop and nothing on the monitor then its a problem with the monitor.
Hope this helps!
May 19, 2011 | Computers & Internet
IBM L190 LCD - the LED beside the power button corner cycles green for 1 second, off for 1 second as soon as it is plugged in. The unit won't power up, the LED just cycles green/off whenever it is plugged...
It's clear the problem is the display, but you can still try these 1. unplug and replug while the both is on 2. turn on, off couple of times 3. keep the LCD on for about one hour these are anyway temporary fixes :(
Jan 30, 2011 | IBM ThinkVision L190 19" LCD Monitor
Just purchased a refurbished IBM ThinkCentre S50 8183 about 5 weeks ago. Installed Microsoft 2010 a few weeks ago. Everything had been working good except for today. When i press the start button .......
so, you eman you power it up , get the OS in working mode and then the START button freezes up ? i dont quite understand.
if you are interetsed, send me your contact information (phone #) and i willc all you
or i strongly suggest you take it back to the seller and get them to figure out why this is occuring
good luck
Oct 15, 2010 | IBM ThinkCentre S50 8183 Intel Refurbished...
Monitor keeps shutting down . sometimes it shuts down very often like less than a minute, other times an hour or more. i need help, thank you.
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this help....
Jun 27, 2010 | LG 22" FLATRON LCD Monitor
I have an IBM P202 monitor and the color is wrong how can I fix it?
Your problem my friend is cable betwen pc and monitor, it is brocken! you must be fixed by an expert, but not at high price! If I,ve helped you rate me! Thanks!
Sep 14, 2009 | IBM P202 - Refurbished 21 inch CRT...
How can I reduce the text shown on a 15'' ibm g78 monitor
well you can try
control panel
accessibilty option
pick a task
configure window to work for you
next
pick one of those
Feb 17, 2009 | IBM G78 (Refurbished) (Black) 17 in.CRT...
My ibm think centre trys to turn on but doesnt completely....
Start your computer and press F8 key your computer will go to safe mode setup, select the VGA Mode and Press Enter your problem will be solved.
Jan 27, 2009 | IBM ThinkCentre A51 PC Desktop
Thinkpad T40
When starting laptop on first screen hit "Delete" or "F2" (not sure which one on thinkpads) go into the setup and check the power settings restore to default and save.
Feb 11, 2008 | IBM ThinkPad T40 Notebook
IBM NetVista PC Desktop Logo
88 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
