Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
My Admiral side by side fridge freezer is not self defrosting. Hence the fridge freezer stops cooling. When I switch it off and defrost it and then switch it back on it works for about a month and then the same thing happens again. Do I need to call in an expert or can I replace the part myself? (Fairly handly female)
    Top Expert:
  • Admiral Master
  • 47,149 Answers
If your Admiral refrigerator is not equipped for automatic defrosting, your only alternative is to defrost it manually every month. There is a reason why automatic defrosting has become so popular.
Posted on Dec 08, 2017
peyton32034
  • 410 Answers
SOURCE: Frozen Fridge
the temperature controlis most likely bad since you cant control it. the control is the knob you turn to set the temp with. you should be able to replace it yourself fairly easily.
Posted on Dec 21, 2007
jumptrout51
  • 3361 Answers
SOURCE: Admiral side by side fridge defrosted and no longer cooling
Replace the compressor start relay.
If this does not solve the problem you most likely have a bad compressor.
Your fridge may be under a 5 year compressor warranty.
Posted on Feb 21, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GC2224gek admiral freezer keeps defrosting
I believe your defrost control board is defective part number 0165748 You can visit my site below and enter the part number or the model number GC2224GEK in the search feature. We also offer free help, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Mar 28, 2009
Testimonial: "Thank you for your response. It was the circuit board that was faulty just over a year old. It was replaced just before I saw your email. "
Maytag317
  • 1136 Answers
SOURCE: No self defrosting. Ice builds up clogging the
Hi. Are you having frost build up or is the drain icing up?
If it is frost, remove the rear panel inside the freezer and check the defrost heater and the bi-metal switch for continuity. If either switch shows no continuity, replace that switch. The bi-metal switch which is located on the top of the evaporator coil, needs to be tested while it is still cold.
If eithe part shows good, the you will need to replace the defrost timer.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 24, 2009
rylee_smith
  • 8619 Answers
SOURCE: defrost cycle not defrosting
Hi
Please check the defrost timer at the back of your refrigerator and also check the defrost thermostat. Defrost thermostat wiring(part #240) could be loose. You'll need to remove the back panel, held in place by 5 screws. Locate the defrost thermostat and disconnect it from the wire connection to another part. Due to the connection requirement, you may need to cut the wires from the original part and splice it with the connector with wires to the new part. After securing the spliced wires and covering in electrical tape, replace the panel and all the screws.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Posted on Jul 14, 2009
Admiral side by side, freezer working, fridge not getting cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Admiral 26 cu. ft. Side-By-Side...
I have an older admiral refridgerator, when you open freezer it sounds like water dripping on a hot skillet. I unpluged it, later pluged it back in and wont come on
The sound was water dripping on the defrost coil...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 25, 2010 | Admiral 26 cu. ft. Side-By-Side...
Freezer works fine, but fridge won't stay cool. I replaced the defrost timer.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
How about the fan at the condenser??? Is it running??? Is air being circulated from the freezer to the fridge...if not then find out what is stopping it...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 12, 2010 | Maytag Admiral Top-Freezer Refrigerator
Our Admiral side-by-side freezes fine, but our fridge has no cool air. The fridge runs all the time, too. Any ideas?
heatman101
Sep 03, 2010 | Admiral 26 cu. ft. Side-By-Side...
Admiral gs22a8d3 freezer freezes up fridge stops cooling need to unplug to defrost
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 18, 2010 | Admiral 26 cu. ft. Side-By-Side...
Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Feb 21, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral =my ice maker isnt making any ice and my fridge isnt cool
CHECK AND SEE IF FAN IN FREEZER IS RUNNING, SOMETIMES YOU MUST DEPRESS DOOR SWITCH TO CHECK , IF IT IS THEN THE DEFROST TIMER OR THE DEFROST HEATER IS MORE THAN LIKELY THE CULPRIT THESE WOULD BE WORTH REPLACING BUT WOULD POSSIBLY REQUIRE A TECH , ALL DEPENDS IF YOU WISH TO TACKLE ,
Feb 02, 2009 | Admiral 26 cu. ft. Side-By-Side...
Wards/Admiral refrig/freezer
I put the fridge in manual defrost by advancing the timer. The defrost heater worked so the problem was with the timer not advancing to defrost every 6 hours. The plastic gears wear out over time.
Apr 18, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
57 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
