Question about Dishwashers
I let my rowenta iron touch a nylon type tablecloth. It left a burnt mark in the tablecloth. How do I clean the iron?
    President:
  • 1,462 Answers
Fine emery paper or a plastic scourer sometimes works
Posted on Sep 06, 2008
The bottom of my rowenta focus has a burnt grainy film on it. How do I clean it and prevent it from happening again. I've only used it approx 4 times but it is over a year old.
Rowenta FOCUS STEAM IRON DZ5164 DZ5164U1 user manuals
will give their specific instructions.
Rowenta has a kit, including a paste cleaner for iron soleplates, available from Amazon.
Home made cleaners include a paste of baking soda and vinegar. Rub on, let sit, and wipe with a wet cloth. (Some add a drop or two of dawn dishwashing liquid)
Another home made cleaner is the Mr. Clean Magic eraser, thoroughly wet, and rubbed over the soleplate.
Make sure to wipe the soleplate with a clean wet cloth at the end to remove cleaning residue.
Clean your iron's soleplate while the iron is cold, and don't use something scratchy like a steel wool pad, to avoid scratching the surface.
Aug 11, 2017 | Rowenta Irons
Why does my rowenta iron leave iron marks on my clothes
It's not the iron it's the water in it. Try distilled water and use a commercial cleaner to clean it out
Dec 15, 2013 | Rowenta Irons
Cannot get black stains off with the cleaner kit from Rowenta that I bough at Bed Bath and Beyond. Used almost all of the cream and still not clean. adjina39@aol.com
Are you heating up the soleplate first to get it really hot, then put on an oven mitt to protect your hand, squirt cream onto a folded pad of clean cotton fabric, then apply to iron sole plate, rub over stained area gently, wait, then rub off. you may want to rub the whole iron sole onto a piece of waste fabric to remove the burnt bits. Itcan take a couple of goes to clean. The ironing press cleaning sticks work well too.
Nov 03, 2013 | Rowenta Irons
How can I clean a burnt mark on the stainless steel iron
I have used the following for various iron cleanings. None have damaged my irons. Baking soda
Dec 16, 2011 | Rowenta Irons
I have a rowenta iron, and began to iron a tablecloth with gold embossing. Now it is stuck on the plate. How do I clean it?
Turn the iron back on, get a sheet of wax paper, iron back and forth on the wax paper it cleans all of the gold and grime off. Then take a Magic Eraser and clean the plate after it has cooled. Won't scratch your plate. Hope this works for you. I have done it often.
Dec 31, 2009 | Rowenta Power Duo Iron
I have a rowenta iron that leaks a lot of water
Here's a solution . . . Do NOT buy ROWENTA! I've had 3 Rowenta irons. All of them have eventually began to dump water out of the base. . . heck, the Titanic didn't leak as much as a Rowenta iron!
Dec 31, 2009 | Rowenta Perfect Iron
Need to know how to clean a rowenta iron plate
As long as it's not a coated surface - plain steel - get 0000 steelwool to rub it with. It will take some elbow grease but it will work to clean and (almost) polish the surface.
Mar 26, 2009 | Rowenta DZ9080 Iron with Auto Shut-off
BRown water and stuff coming out of iron
Hi, two problems:
DIA' s problem - the brown water is due to poor water quality and debris in the boiler and iron sytem. Rowenta is clear that they do not want anyone to cleaning solutions - only clear filtered drinking water to rinse out the boiler (via the water inlet screw hole) and I have found running the system dry, letting it cool, rinsing and draining the boiler several times before putting unit away works fine.
Guest' problem with brown/black tar substance is likely caused by too hot and iron setting (steam setting may also be too high) for ironing man-made synthetics (like Nylon, Rayon, Polyester or blends are basically petroleum based fabrics) that breakdown or melt, leaving deposits on the iron's stainless steel soleplate. A secondary cause could be bad water or debris in the boiler/iron in which the solution for DIA's problem might provide relief. Cleaning the soleplate is tricky, I use nothing stronger than an old fashioned wooden orange stick to gently scrap of all traces of the "stuff" and dry "Dutch" cleanser w/ a terry cloth or old cotton sock to polish without scratching the soft stainless soleplate...
Apr 01, 2008 | Rowenta DG-980 Iron
Rowenta Iron
TO CLEAN THE BOTTOM OF THE IRON, MY NAN USED TO ALWAYS IRON BROWN PAPER, IF THIS DOES NOT WORK, USE A RAG DIPPED IN THINNERS, OR LIGHTER PETROL AND RUB GENTLY.
NORMALLY THE SELF CLEAN SYSTEM IS JUST A BUTTON NEAR OR ON THE TANK THAT YOU PRESS WHILE THE IRON IS ON AND HAS WATER IN, PRESSING THE BUTTON WILL FORCE WATER THROUGH THE STEAM JETS (SO KEEP IRON FACING DOWN) ALSO EMPTY THE IRON AFTER EVERY USE
Nov 27, 2007 | Rowenta DE-480 Iron
Dishwashers Logo
51 people viewed this question
Top Dishwashers Experts
