Question about Garden
Throttlc cable how to install throttle cable in ryobi trimmer 30000a
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello! could you look under the ryobi name and give me the proper model number. so i can tell you how to install throttle cable.thank you,MrFixIt.
  • 50 Answers
Disassemble the handle. Remove the cable and pay attention to the HOOK in the carb throttle. Install the new cable in the exact location, positioning it in the handle properly. Check for proper operation before you reinstall the handle.
Posted on Feb 14, 2009
Ryobi weedeater throttle not working
Check the throttle cable connection at the carburetor throttle linkage, it (cable) may be broken or the carburetor linkage is broke.
Jul 09, 2016 | Ryobi Garden
Ryobi grass ranger 22c whipper snipper. Wire has come off throttle adjustment so when I press the yellow trigger it doesn't rev. Just on idle. Still works, but takes longer and not so good on really...
The throttle cable can easily be replaced onto the throttle lever of the carburetor...if the end of it has not broken off. The end is dog-legged and quite thicker than the main cable. If you put it back on, make sure it is routed correctly, not binding anywhere, hanging up or interfering elsewhere.
Jan 08, 2011 | Ryobi Garden
Strimmer will not start got spark & fuel ryobi rbc30sbt
its probabley your throttle cable , try pulling the throttle full on when you starting up the trimmer word of warning though only do this on a very flat surface..
Nov 23, 2010 | Ryobi Garden
How do I adjust the throttle cable on a C430 String Trimmer? When I depress the throttle cable, the linkage on the carburetor only moves about 1/16 inch and will barely turn the cutting head.
The throttle cables aren't adjustable. Make sure the other end is on the trigger correctly and that it is routed through the handle and the engine cover correctly. Also, make sure the throttle shaft and throttle plate (inside carb) are free and easy in their movement with the throttle cable off. The engine idle speed adjusting screw may be in too far also. Back it all the way out and then back in with the throttle closed Once the speed screw touches the throttle lever (what you hook cable into) on the shaft, give it about 2 turns in. This is about all you can do. If the cable is stretched badly (rare), it would need to be replaced.
Oct 26, 2010 | Ryobi Garden
The cable broke in the lower section of my ryobi trimmer rendering it inoperable.. please help! I do have 2 lower attachments for the ryobi trimmer however both the top section and the lower sections are...
These inexpensive trimmers are designed to be "throw-aways". It usually isn't cost efficient to repair something like this. Do yourself a favor and buy higher quality such as Echo. It will pay for itself and you will have less headaches.
Oct 08, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Ryoby weedeater throttle housing. Replacing the throttle spring
From the limited information you have given I think your throttle wire is binding. It could just need lubricating or the throttle shaft or butterfly in the carburetor could be binding. Disconnect the throttle wire from the carburetor and see if the throttle wire is moving freely and check the throttle shaft in the carburetor to make sure it is moving freely. If both are free, then check to see if something is pinching or binding on the throttle cable.
Sep 12, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
394 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
