Question about RCA 32F530T 32" TV
TV turns on & off by itself
The TV, keeps turning on & off by itself.. I can hear a clicking inside.. Kind of sounds like 2 wires are hitting, so I took off the back, & had a look.. It kept doing it.. I tried to trace the sound.. Sounded like it cam off of the electronic board that attatches to the end of the tube.. But no 2 wires were touching each other.. The sound is like, if you touck +/- speaker wires together.. just a zap,or a click then the sound doesn't come out.. Any easy solutions?
    Novelist:
    Champion:
  • 277 Answers
You can check the board where the components are mounted and resolder any that look bad. a brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. all can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced.
Posted on Nov 17, 2005
Tv makes a clicking sound when i turn it on but wont turn on
if just only clicking sound that was mean the cause either the regulator in the power supply is bad or the horizontal output transistor get damaged.
Jul 18, 2012 | Televison & Video
Won't turn on
after hearing the clickin sound are u able to listen to any other asounds fromthe tv....
did try to open the cabinet and check for the wire connections
Jun 15, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
I turn on the fan in the bathroom and as the fan gains speed, I hear a clicking sound as it the fan blades were hitting something, and it sounded like it was solid. So I took off the grille and the light...
Are you tightening the grill to the point that it is pulling itself up to touch the fan or is it pulling something down to touch the fan? I would take the grill off and with the fan running, pull and push on the points that hold the grill in place and see if that action causes the fan to click. If it does, you need to trouble shoot from there. If not, an exorcisim might be in order.
Sep 12, 2010 | Home
TV KEEPS SHUTTING ITSELF OFF
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.The lamp you need is BP9600224B you can find it here: http://www.discount-merchant.com/Samsung-BP96-00224B-OEM-Replacement-LAMP-BULB-BP-p/samsung-bp96-00224b-oem.htm?Click=48173 .Have a blessed one!
Apr 29, 2010 | Samsung HLN5065W 50" Rear Projection...
Will not come on it only a clicking sound from part no. 0mron 0584H3
I had the same problem with my tv, same make and model. I first continuously turn on and off my tv manually until I could get some kind of picture. This procedure took maybe five minutes. I was able to get a fine picture and sound, as if it was brand new! Other things to keep in mind, try to eliminate dust build up as much as possible.. Hope this helps out...
May 21, 2009 | Philips Magnavox 27MS343S 27" TV
TV will not turn on.
hello..i think you have very big problems inside on you're TV you need a Electronics Technician to see inside the real problem.my tips is located in Power Supply Regulator..Can i know what kind TV Model???thanks
Apr 23, 2009 | Televison & Video
Startup Problem with my 42pf7321d/37 Phillips plasma TV
I need to know how long do you have the tv?In the other word,approx. how many hours you have put into it?
Secondly,did you wall mounted the tv or setting it close the the area which there is not much room for the back of your tv to breath?
solutiondoct
Nov 06, 2008 | Televison & Video
My tv will not turn on.
First of all, forget about the remote and see if the TV functions normally using the buttons on the front of the set itself. If the TV will not power on with the power button on the set itself, then something is wrong inside the TV. If the set works fine from the front buttons but no longer responds to that remote, then the remote has either gone bad or was accidently set to a different brand. In this case, look for the original book that came with the remote (or TV if it is the original remote) and follow the instructions for setting the remote back to Zenith. Try that and post your results here.
Aug 09, 2007 | Zenith C27A24T 27" TV
Tv turn off by itself.
I have been dealing with the same problem with the identical set. I'm pretty handy so rather than junk the set, I took off the rear panel and stuck a small fan in the back to cool down the inside of the cabinet. I love the picture on this TV so I'm doing all I can to save it. Sometimes it doesn't turn on so I have now taken off the front panel (speaker cover) and also the front access panel. I carefully reach inside and have to wrap on the part (with a long wooden spoon) that I hear clicking from when I hit the power button. I used to just give the cabinet a swift kick and it usually would turn on, sometimes after several kicks. Kick it, then hit the power button. So whatever the problem(s), it's not keeping me from watching a gerat picture. I have a feeling that if I took my air compressor and blew out all of the dust from all over the components, it'd probably solve the problem of it shutting itself off after an hour or so. Why it doesn't always turn on is anyone's guess, but a good tap or two with my wooden spoon here and there and it turns on eventually.
Nov 24, 2006 | Pioneer PRO-620HD 58" Rear Projection...
Open Questions:
RCA 32F530T 32" TV Logo
49 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
