Defaulting I want to know how to default my laptop to original factory setting.
  • gblack32 Jan 03, 2009
    why wont my laptop allow me download abobe...its says im not connected when obviously im reading it on the web
  • olu4reap Jan 30, 2009
    my hard disk keep showing me 0200 disk failure and no opperating system is found please i want to know if ther is any remedy for my hard disc or if there is any possibility for my hard disc to work again?
    Problem Solver:
  • 8 Answers
IRONROD718 I suggest you to write all the information about your laptop,
The make,model, operating system.
Posted on Sep 06, 2008
  • Roberto Lopez
    Roberto Lopez Sep 06, 2008
    IRONROD718 I suggest you, to give more information about your laptop.
    Brand,model and operating system..
I want to change language on my ipTIME N104V router
Try defaulting to factory settings. Hopefully English is the default language. If not you will need an interpreter.
Feb 27, 2015 | Computers & Internet
Setting radio stations on 2009 clk350
every time after you find your station, press and hold the number button, a beep sound comes off and the station is set.
Mar 17, 2013 | 2009 Mercedes-Benz CLK 350
I want to reset my toshiba satellite L300D-13R latop to the originaal factory settings but i do not know how
To reset your laptop into factory default settings you need a installer CD with the Toshiba, Mostly that CD is coming with your Laptop during the time you purchase your laptop. if you have that CD just insert the Cd into DVD or CD drive of your laptop and Press hold F12 and boot from DVD ROM and follow the next instruction and thats it your ALptop is restored into his original Setting which is fatory settings.
Apr 08, 2011 | Computers & Internet
this is either the hdd failed for good..or it has something wrong plugged..or is just not seen cause it has some changes in bios...
just go to bios...restore to factory optimal defaults ...and try again sure that you change the boot order after defaulting bios settings such way to boot from cd first ...after that try again may be a sata hdd and it is not seen cause it is not set right in bios..
if this not working ..remove the hdd and have it checked in another computer ...even a desktop if you find and adapter see if it is still working ....
Mar 22, 2010 | HP Compaq nx7300 Notebook
When we have a power bump the unit reverts back to factory settings, Can a ups be added to the control board to eliminate this problem?
Not sure why your unit would reset to factory settings, it's usually the thermostat settings that control the unit and resets when you have a power failure. Most thermostats have a battery in then to power the thermostat during a power failure. They usually only maintain the power from 15 to 30 minutes to maintain your settings, before defaulting back to factory settings. After every power failure you usually have to replace the batteries.
Feb 26, 2010 | Samsung AP500PF Air Conditioner
How can I restore my computer to factory settings?thanks
Usually, every PC has a restore DVD. Try to boot from it and follow the instructions on the screen. Don´t forget to select "clean install" during the installation procedure.
Sep 19, 2009 | Dell Latitude D600 Notebook
GE airconditioner. Temperature setting goes up to 86 degrees by itself. Nothing can change it tried evrtything
Sounds like the stat is "defaulting" to factory setting, or, what are the programmed settings at? A programmable thermostat will revert to programmed settings unless placed in "hold". If all ok, time to get a new stat.
Aug 23, 2009 | Heating & Cooling
AC adapter clicking noise
I've never heard of a factory defaulting clicking ac adapter. I recommend replacing it, since it seems you might not know when you will get extra jolts of electricity going through the faulty adapter. Walmart / Bestbuy has some adapters you can buy. Just make sure its for HP dv1000 type.
Jun 11, 2009 | HP Pavilion dv1000 Notebook
No 'Status' light on the modem
First of all, who owns the modem? If the ISP provided it and charges a monthly fee as part of your service, have them replace it and set it up. Problem solved!
If it's yours however, the surge may have damaged the LAN port, turning it into a brick, and you'll need to find a replacement. There is the possibility though, that the settings have just gotten corrupted. If that is the case, defaulting the unit will allow you to access the modem's admin page and re-configure (you must know the default IP address). Defaulting to factory is usually a matter of disconnecting power for 30 seconds or so, holding the reset button, usually accessible through a small hole with a toothpick or paper clip, and plugging the power back in while holding the button.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 28, 2008 | Zhone 6211-I3-200 Router
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
