Solution #1
posted on Nov 17, 2005
The way that cartridge works is by a fuse. When you first install it the printer calibrates itself to the new cartridge and blows the fuse.
look for a blown fuse in your fax. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace.
Anyway, if the printer senses an improper toner/developer balance it will default to XXXX copies and give you the message. You can to reset the machine - this might help.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for NEC Nefax 655E Plain Paper Laser Fax
Email this problem
Email this problem
Can you Help with these Fax Machines problems?
Repair Service
Find Fax Machine Repairman Near You:
