Question about Air Tools & Compressors
Air conditionig I have a Carrier unit Model# FA4BNF048, that it turned off by it self; thermostat dysplay was completly blank,I don't know what I did but it came back on for about 10 minutes and then turned off again the unit has power ( 24 vlts) coming out of transformer,but no voltage to thermostat wirest Thank you John Reyes
  • 828 Answers
If it is a digital thermostat check the batteries and replace. If you remove the thermostat cover so you can see the wires, check between R & W and you should read a voltage differential. Same for R to Y and R to G. Your problem may be only related to the batteries.
Posted on Sep 09, 2008
Carrier thermostat blank lcd display
Like have a clogged drain and the float switch is tripped. Check the drain line near the indoor unit for a piece with two wires. Remove switch and check for water or look in emergency pan under unit for water. DO NOT LEAVE SWITCH OUT, must vacuum clog free or blow out with compressed air.
Aug 09, 2017 | Carrier Heating & Cooling
Need the tons for my unit. its really old and i cant read it on the side i have the model number it is 50ym042310 and it is a 230 volt unit. i know its a carrier because i amable to still see the brand...
The number you are referring to as your 'model number' is a number I don't recognize; maybe it's the SN or something - I don't know.
But that other number - "38CKC042" -------'is' --- your model number and the size of your AC is 42,000 Btu or 3.5 tons.
Aug 06, 2011 | Carrier 38CKC042 Air Conditioner
Hi All, I have a carrier reverse cycle airconditioning unit and about a week ago the digital thermostat blanked out. I spoke to an aircon repair tech and he suggested that the fuse is blown at the air...
It will be inside the unit main panel. Turn main power off and remove the main front panel. The fuse will be located on or near the fan control board. Typically they are a flat agc type fuse. 3-5 amps. The problem will be that if the fuse is blown -there is a reason for it. They don;t just wear out and blow. Look for frayed wires around the outside unit and in the thermostat to make sure you dont have a short. Otherwise, you will just blow the fuse you replace.
Jan 18, 2011 | Heating & Cooling
Blank thermostat
Check voltage at unit. Also check the 5 amp fuse in the unit. If this unit has a float switch in the drain line check that. Rus
Dec 03, 2009 | Carrier 36KCARMS Air Conditioner
Air Tools & Compressors Logo
165 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
