Question about Ricoh Aficio SP C811DN-DL Printer
Standard Try Full
Our Ricoh says "Standard Tray Full Remove Paper". I don't have any paper in the standard tray. How do I fix this?
Pat K
    An expert whose answer gotĀ voted for 100 times.
  • 86 Answers
'Standard tray full, remove paper' is the output tray where the prints exit.
Check also the exit sensor/feeler condition.
Good luck and please rate me, thanks.
Posted on Feb 03, 2009
    New Friend:
    Problem Solver:
Where the paper EXITS just tap the black springs. Its a physical thing. All other answers are wrong.
Posted on Dec 15, 2014
My printer Lexmark T634 is showing "remove paper standard bin"
What your printer is telling you is that it thinks or knows that the top exit tray for the paper is full. This is the tray that is moulded into the top of the printer.
This caused by two things. It is actually full or the Bin Full Actuator is out of position and forcing the error condition.
Look at the standard bin. Over to the top at the top left corner there should be finger (almost the same as paper clip) hanging down. If it is not there, then it is more then likely that the finger is jammed up.
Nov 04, 2009 | Lexmark T634 Laser Printer
I get the same message coming up "remove paper standard tray"
Sounds like it is misfeeding from the Default tray (just not getting the paper into the machine). try removing the paper from the default tray, and use another one. If it works, then the paper feed rollers are the likely cause.
Jul 20, 2009 | Ricoh Aficio AP3800C Laser Printer
I get remove paper standard tray on a AFICIO AP3800C and it locks up the software. Then does not allow clearing the message. I have removed paper. Tried Aux feed. Always does same thing
On the face down exit tray (one on top) there should be a 3 or 4 inch long plastic part sticking straight out and pointed down. That is the tray full sensor arm. It could be knocked out of the holder and now working right.
Jun 09, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
Feb 27, 2009 | Ricoh Aficio AP3800C Laser Printer
Standard top bin full remove paper
Firstly, is the exit bin full of paper? If it is, just remove it.
If not, then it's going to be a sensor that recognizes the paper amounts in the exit tray. Check for broken plastics and possibly stuck plastic flaps in the exit tray.
If it's neither of those, try turn it off, unplug, then reverse.
Other than that, if no go, then it's an internal sensor issue. At that point, probably the best bet is to replace as repair costs would outweight a new unit cost most likely.
Feb 26, 2009 | HP LaserJet P3005 Printer
Problem Ricoh cl 5000
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Ricoh Aficio CL5000 Laser Printer
Hp 3800dtn standard top bin full remove paper error
top bin full error is hte lever sensor where you see the paper coming out, the lever is stuck in the up position.
It's used to tell you to remove the paper from the exit because it's too full.( Too many copies on the top)
Jun 27, 2008 | HP Color LaserJet 2600n Printer
Maybe your paper sensor flag is stuck or broken if you pull the tray out of the machine there should be a little black plastic sensor flag hanging from the top middle of the slot where you pulled the tray out from if its stuck up or broken the tray will always sense its full of paper.
Jun 20, 2008 | HP LaserJet 3800dtn Printer
it may be one of two problem, to start off with try using one of the other trays or the manual feed. to see if it's just that tray or the machine. you may need to cancel all jobs in the printer before starting and also keep the main tray open. let me know what heppens.
Thank You,
Mar 19, 2008 | Ricoh Aficio AP3800C Laser Printer
Error message for Ricoh C410DN
When that message is displayed, the printer thinks the output tray is full of paper and it won't print any more because there is no room left to spit pages out. If the output tray isn't full of paper, the sensor that detects paper there might just be dirty or dusty.
That sensor is a black sensor that should be located just at the point where the paper exits the machine, above where the paper comes out. Blow some compressed air on the sensor to try to clean it off and see if that clears your error message.
Oct 30, 2007 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio SP C811DN-DL Printer Logo
1,008 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
