Question about Kitchen Ranges
Baking element I have a stove model number PLEF398DCB serial - VF44050260 The baking element blew apart, I got a new one, put it in, now the new element does not heat up!! I took the back cover off the stove , don't see any burned wires, don't even get a code as to what is wrong. everything else works fine but the new baking element. HELP thank you KW I have close to the same problem. My elements are not blown apart, but all of the suddden my bake and broil elements do not work at all. Same model...PLEF398DCB
  • sladams May 11, 2010
    How do you change this clock if it is on 0?
  • 70 Answers
Hey there. make sure the clock in on manual and not automatic is should show a little hand and not a 0 :)
Posted on Sep 07, 2008
I have an Eaton Viking stove that has a broken baking element. Is there anyplace that can supply one for me.
Amazon or direct
Amazon.com: Bake Element for Viking Range, PJ010004: Appliances
https://www.amazon.com/Bake-Element-Viking-Range-PJ010004/dp/B00OJ5VL0U
Rating: 4.8 - ‎17 reviews
Buy Bake Element for Viking Range, PJ010004: Range Parts & Accessories - Amazon.com ? FREE DELIVERY possible on eligible purchases.
Viking Parts by Viking - Factory Parts for Viking Appliances
www.allvikingparts.com/ Need a part for a Viking Range, Stove, Oven, Grill, Refrigerator or Dishwasher? We stock thousands of Genuine Viking parts.
Locate Your Viking Model and Serial Number - Allvikingparts
https://www.allvikingparts.com/Articles.asp?ID=142 What do Viking Model Number and Serial Numbers Look Like? Viking ... For Viking Open Burner Ranges and Rangetops(You have an Open Burner Range or ... Eaton Viking stove Google Search
Mar 13, 2017 | Heating & Cooling
Stove about 4 years old started blowing fuse in house main box. Replaced fuses worked 24 hours now it blew again stove was not in use at the time. When it blew 2nd time the fuses were extremly hot.
This indicates that one of the heating elements or control has developed a problem. Can you provide the make and model for this range?? Replace the fuses if blown. Check to see if any element is hot - including those inside the stove. Note any that are. Shut off the stove and unplug it from the outlet. When cold, perform a careful visual inspection of the heating elements on the cooktop AND both the bake and broil elements inside the oven (especially any that were found to be hot earlier). Run your fingers along the blind side of the elements to detect any openings, blobs, etc. in the metal covering of the element. Replace any damaged elements with new. Start the process over again - especially the new element. If found hot - check the control - is it on? The control may need replacement, too. This may require more skills / tools than you have and need a pro. Good luck!
Apr 10, 2015 | Kitchen Ranges
Eaton viking imperial electric,stove oven door will not close completelty; circa 1996. are replacement hinges still availible?
To the owner of the Eaton Viking stove RS3028W-1, yes you CAN get replacement hinges!
I too, have this stove model (circa 1996) with exactly the same problem and I have spent the past 18 months looking for replacement oven hinges. I was very frustrated at the thought of having to throw out a stove that cooks and bakes wonderfully and has not needed any repairs till now and having to buy one of the new subpar ones that constantly need repairs. Plus you can't do canning on the new stoves and the few remaining coil models are extremely poorly made.
I have found 2 places that carry the hinges.
1. Reliable Parts, 1-800-663-6060. This company is located in Montrea (St. Leonard), Quebec.
2. Appliance Shark, 1-800-663-1176. This company is located in Barrie, Ontario.
The part number for the hinge is: 318-024-741
I hope this is helpful, and may you have many more years of happy cooking on this great stove.
Sep 17, 2014 | Eaton Computers & Internet
How do I find the serial number on Kenmore stove model number 7907050706073242343?
Usually on the back or on a label on the inside of grill or oven. If you purchased this it may be on your sales Invoice.
Aug 07, 2014 | Kenmore Stove / Oven / Range Bake Element...
Loud pop and light behind stove. Stove top works, oven does not.
Good Morning Stephanie - Typically you may locate the model and serial number in the storage drawer, on the right side. Based on the symptoms you are describing, you may either have a communication error from the main control board or a faulty bake and/or broiler element. If resetting the unit did not solved the issue, at this point I would personally contact a professional to accurately diagnose the range to determine the root cause to reduce the risk of unnecessary parts.
May 26, 2013 | Frigidaire FEF316 Electric Kitchen Range
The inside oven is not heating. The top burners are working fine.
If this is an electric oven, most likely the oven bake element has burnt out.
the model and serial number should be behind the bottom drawer,
most elements are held in with (2) 1/4 inch socket hex head screws.
Remember to unplug stove or shut off breaker before servicing.
The element can be slid out usually, then unplugged or remove
the back cover behind stove and unplug it from the wiring harness.
I hope this is useful
Aug 02, 2011 | Tappan Ovens
I need a baking element for the tappen oven model number 486847a. The stove serial number is VF41807648. Can you help
Go to www.ukwhitegoods.co.uk you will need the model number and serial number and place an enquiry. They will get back to you.
John
Jun 05, 2011 | Ovens
While baking my wife noticed sparks coming out of the baking element or coil. can we continue to use the stove top or should we leave it unplugged.also how much does it cost to replace the element
It sounds like the element shorted out and needs replacement. I would not continue to use the oven, although it should be ok to use the stove.
It's difficult to say what a new element plus installation will be, but you can call around and get estimates. Have the model number, type and serial number available if possible before you call.
Dec 12, 2009 | GE Spectra JBP78 Electric Kitchen Range
FRIGIDAIRE STOVE MODEL FEF316BSC I WAS BAKING
Don't worry! Your element probably blew out. It's no big deal. It happens. Call us for parts. 9728590929. It's really a simple repair, probably one of the easiest to do. Hope this helps!
Aug 24, 2009 | Ovens
Fridgedaire oven element replaced and still no cookies?
If the surface elements work your ERC is bad.(clock).
If the surface elements do not work check the circuit for 220 volts.
Mar 14, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Kitchen Ranges Logo
172 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
