Question about Zebra Stripe S600 Thermal Label Printer
Zebra Strip prints blank labels
I have a Zebra Stripe S600 printer that prints good 'CANCEL' tests but only produces blank labels when it is communicating with to the computer. Any suggestions? Thanks for your time.
  • barcodez Oct 06, 2008
    I'm having the same problem as described. If I do a hold "CANCEL" button and power on the printer the configuration prints. If I send a ZPL or file to print the data lights flash and the label advances but nothing is printed on the label. I removed all old drivers and installed new drivers as suggested but still having the same problem. Any other ideas? Thanks
  • Anonymous Mar 19, 2014
    Changing the Belt
Please download a new driver from www.zebra.com (don't use your old windows driver) and then this will fix the problem.
Posted on Sep 17, 2008
Zebra s600 prints on label and feeds 3 blanks
it must be wrong label configuration or problem with gap sensor.
You can follow this step by step zebra designer ;
Zebra Designer Kurulumu ve Kullanm Teknik Barkod Etiket
Jul 02, 2014 | Zebra Stripe S600 Thermal Label Printer
Hi there, I am printing on Zebra S600 using Seagull Scientific Driver, The printer only prints every alternate label that is prints one label and prints a blank. Thank you for your help
Skipping labels is usually a printer driver issue. You should use Seagull Scientific printer driver only if you are using the corresponding Seagull Scientific label design software. It is important to have the printer driver and label design software be from the same manufacturer.
Jul 01, 2011 | Zebra Stripe S600 Thermal Label Printer
Stripe S600 Thermal Label Printer: how to load zebra stripe printer labels...
CLICK HERE to download the full user manual from Zebra. If the link doesn't work, go to Zebra.com, click Resource Library at the top of the screen, then click MANUAL. Choose your model number then follow the prompts.
May 18, 2010 | Zebra Stripe S600 Thermal Label Printer
Zebra s600 doesnt print correctly. left side of label has lines going through it
If the lines are blank, you can try to clean the print head with Mentholated spirits or Isopropyl Alcohol. If this doesn't fix it then the print head will need to be changed
Mar 11, 2010 | Zebra Stripe S600 Thermal Label Printer
I have installed (hardware + driver) a stripe s600 via COM1 on my desktop; how can i get a test page? i does not work from the test page @ printer properties.
You should be able to print a test page from Windows.
First make sure the device itself can print by holding down CANCEL while you power it up. Release the button when the CALIBRATE light goes off. This should print out a config label.
Here's the manual: http://tinyurl.com/yb2rpd4
I would check all the connections, download the latest drivers from the Zebra website (not the ones on the disc) and reinstall.
Hope this is helpful for you!
If so, please leave a rating!
Feb 28, 2010 | Zebra Stripe S600 Thermal Label Printer
I am having problems with our Zebra Stripe S600 if I ask it to print 500 labels it will only print 3 then I have to line the label and ribbon back up, any advise would be gratefull
Recalibrate the printer, it seems it might have lost it's calibration. Chekc and clean all sensors in the paperpath with Isopropyl Alcohol.
Jan 21, 2010 | Zebra Stripe S600 Thermal Label Printer
Zebra S600, Recieves data, but does not print
Go into the printer driver and select print a test page, does it print out?
If so then try printing from your label software, it should work, if not then it is your software that is at fault.
If the test page does not print out then check all the settings in the print driver, so they are the same as the physical label.
If non of this helps then go to www.lancerlabels.co.uk and do a live chat to Michael.
Feb 17, 2009 | Zebra Stripe S600 Thermal Label Printer
Not printing
this problem will address on label and ribbon issue. you must establish your printer set-up first, meaning see to it that the label and ribbon was correctly loaded, if still problem occur try using manual calibration you can see how to do at the manuals you have..
Jul 29, 2008 | Zebra Stripe S600 Thermal Label Printer
Zebra Stripe S600 Thermal Label Printer Logo
731 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
