Question about Compaq Presario 700 470024-192 Notebook
Wireless assistant Hi My Compaq presario F500 wireless assistant 'HPQWA.msi has stopped working can you please help? Regards Mike
  • mikepre37 Sep 05, 2008
    Hi Kiran
    Thank you for the info.
    Regards
    Mike
  • bblewelsh Dec 31, 2008
    I have the same problem but when I downloaded as per your suggestion it said I alreaady had a newer version of the software on my computer. Why then is the wireless assistant not working if it shows it is loaded in the computer???
  • 94 Answers
Here is the link... download your Wireless assistant install it on your computer...
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-46858-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3360261
Posted on Sep 05, 2008
I can"t find wireless on my laptop Hp mini bealaudio
Posted on Dec 15, 2012
Hi there I have a compaq presairo F500 and the wireless internet switch at the front of the computer is not working, its not picking up any wireless connections. the light stays amber, its not picking up...
Some HP computers I've seen recently, and Compaq is owned by HP, had an issue where the wireless card was not soldered down correctly. Over time the general wear and tear laptop computers face caused this wireless card to slowly work its way out, disconnecting it from the computer.
I would contact Compaq, or Best buy (depending where you bought it) and check if your warranty is still good. If it is, they should fix this for you. Otherwise your next best option is to buy a USB wifi adapter from www.newegg.com, or www.amazon.com. It is unfortunately not possible for you to re-solder the wireless card in unless if you are very comfortable with working with delicate electronics.
Mar 01, 2011 | HP Compaq Presario F500 F700 and G6000...
Compaq presario F500. Wireless internet connection not working. Internet works when plugged into modem. D-Link wireless modem working perfectly. Constant red/orange light on next to wireless switch at...
Hi, Thanks for using fixya.
When you connect it to wireless make sure you go into control panel / network view your connection right click on local area network connection choose disable then connect to your wireless connection. Right click your wireless icon by your clock choose connect to wireless network or view available local wireless connection.
Terry
Feb 15, 2011 | HP Compaq Presario F500 F700 and G6000...
My wireless assistant has stopped working and the light stays orange
I had the exact same problem...and the wireless adapter was not visible under device manager. The light stayed orange with the switch in either the on or off position. I did all the whole driver update thing and eventually replaced the wireless adapter but no change. Finally I went into the BIOS (F10 on startup) and reset the bios configuration to the default settings EXIT>LOAD SETUP DEFAULTS). It has worked perfectly ever since.
Sep 03, 2010 | HP Compaq Presario F500 F700 and G6000...
HP F500, no wireless internet...
Uninstall the device from the device manager and in the device manager do this operation "Scan for hardware changes" , then u can find the wireless network adapter with no drivers installed. Then install the wireless device drivers , Ur Problem will be solved.
Oct 17, 2009 | HP Compaq Presario F500 F700 and G6000...
Wireless not working
Does it have any more letters, etc., in the model ?
http://h10025.www1.hp.com/ewfrf/wc/pfinder?lc=en&dlc=en&cc=us&tool=&query=Presario+F500
I tend to not use HP or anybodies Wireless Assistants. But you ought to be able to see in Device Manager and Networks wether Windows thinks that the wireless card is working or not. Windows uses Wireless Zero Configuration Service to control Wireless Cards. You might have to tell the HP gizmo to let windows manage the wireless.
You might also have to turn the computer over and find where the wireless card is - and check that it is still seated properly in it's slot. That's a pretty advanced thing - and should only be done with the Service Manual or Owners Manual at hand to tell you how.
Mainly the hardware should be showing up in the Device Manager as "working properly" - if not maybe somehow the device driver software got damaged or removed?
Jul 07, 2009 | Compaq Presario Notebook
Wireless Internet for compaq Presario
Check out the wireless setup manual for your laptop here:
http://h10032.www1.hp.com/ctg/Manual/c00065819.pdf
Hope this helps!
Mar 28, 2009 | Computers & Internet
How to enable wi fi on compaq presarion F500 using Vista
start-controlpannel open
network connections-wireless netwoking open
next
network name(ssid)-enter your router network group name
next
ok
Feb 24, 2009 | Compaq Presario 700 470024-192 Notebook
Hp wireless assistant 3.00 C2
Hi my hp wireless assistant 'HPQWA.msi has stopped working, can anyone help please?
Regards
Mike
Dec 03, 2007 | HP Compaq Presario V2000 Notebook
Compaq Presario 700 470024-192 Notebook Logo
585 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
