Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer will not spin
I have a Frigidaire front load washer model number CRTR9300ASO bought back in '02. Loved it up until about a week ago. It no longer spins, tries to, but only makes about a quarter of the way around. When it gets to the spin cycle, it does not spin so clothes are soaking wet. It does drain, though. Any help would be very much appreciated. I can't afford a new one and don't really want to rely on a service tech, it sounds like they may not know what the problem is. My husband is very handy (electrictian by trade) and could fix it if we had some idea what the solution is. Thanks.
  • Anonymous Feb 01, 2009
    My Frigidaire was bought in '02, but the model number is GLTF1040AS0. The machine will fill up with water then slightly attempts spinning then the cycle process quickly completes with all the water pumps out but th e cloths remain wet. could you help me figure out what to do or what might be causing the.. My wife washed a couple rugs in it and thats when the problems started.
I was told when it won't spin, then the drain is plugged.  i opened mine up and found a sock stuck in the drain hose.  removed it and seems to be working well.
Posted on Sep 07, 2008
Frigidaire CRTR9300ASO won't spin replaced door latch switch and still does not work
Hi bitemejohne - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. Since you have already replaced the door lock assembly then the washer may be experiencing other issues. It could possibly have a faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Mar 09, 2013 | Frigidaire GLTF2940ES Front Load Washer
My CRTR9300ASO Frigidaire Front Load Washer makes a loud thumping noise and moves slow spinning. Any ideas what might be wrong?
if you lucky, you have a broke shock absorber on the bottom. if your luck is not so good......well we will find out.
open the door on your washer. locate the big silver basket in the middle. put your hand in side and push up. now this will move but we are looking for it to feel very loose, not springy. if your luck is bad you will hear and feel it freely clunck around as if the inner basket is coming loose. if this is the case then you will be looking at a very expensive repair. like $350 and up
levi
Lebarchrigen Appliance Repair
www.lartoday.com
Dec 10, 2009 | Frigidaire GLTR1670A Front Load Washer
Frigidaire ftfb4000fs1 front load washer will not spin
hello **** theres a circuit board on the back or on the side called a module this controls the spin cycle there could be dry joints on the board or component may have fail good luck
shaun
Jan 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTR16704 Front Load Washer 417.39012891
Time for a new one.
Sound like you have done the main shaft bearing.
Nov 18, 2017 | Frigidaire GLTR1670A Front Load Washer
Loud noise during spin cycle
I bought the frigidaire affinity washer. It was quiet until it began the spin cycle, then it sounded like a jet taking off and began to bounce. Come to find out we set it up improperly. You must remove all shipping bolts on the back of the machine and make sure it is level. Ta Da!! it now runs perfectly quiet with little vibration.
May 05, 2008 | Frigidaire GLTF1670A Front Load Washer
Ftf530Es;Frigidaire front load washer
did you check the filter? If the filter is plugged in the least bit it won't allow machine to spin at high speeds
Mar 08, 2008 | Frigidaire GLTF1670A Front Load Washer
Same as many - Washer does not spin or agitate but everything else works fine
your brushes are gone you will have to wright down you model number and look on ebay there really cheap
Jan 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire dryer
Most appliance stores sell a brush tahts on a 3 foot handle to remove any excessive lint form the lint trap.
Sep 16, 2007 | Frigidaire GLEQ642A Electric Dryer
Frigidaire ATF6000ES Front Load Washer Logo
188 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
