Question about Sharp AR-5316 Advanced Digital Imager Copier
AR-151 I don't have a panel of number buttons on my machine or I wouldn't have asked how to do a 26 and a 39. Thanks for letting me know what the error is. I'll call a service person.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
OK, you probably have an increment button then, didn't know.
Good luck
Posted on Sep 08, 2008
  • Sharp Master
  • 2,794 Answers
Messing with the optics involves timing and calibration programs to happen by a service technician. If it isn't place correctly. It will cause copy quality problems to happen.
Posted on Sep 07, 2008
Whirlpool duet dryer control lock light is on. How do you reset it?
the control panel on the right side is a button that says hold for three seconds to lock. Look closely it's in small lettering. I don't know what model you have, so if you can't find the button please send the model number. If you need further assistance let me know
Oct 13, 2012 | Washing Machines
My keating fryer heats the oil fine to temp set on thermostat but will not re fire when oil temp drops unless I push the high limit button. Don't know if the problem is the themostat or high limit...
Sounds like the thermostat is working because it does heat to the right temperature, right? The high limit switch is to shut it down when it gets too hot, so why that helps the unit relight and heat up is strange? Is this gas or electric? Since hitting the reset or high limit button is what is working, I would start there, and replace that... I don't think either part is super expensive, so replacing both wouldn't be too expensive, especially since you have one of the best fryers ever made... Keating is number one in my book, and I know they are expensive to start with, but these two parts shouldn't be much....however I would start with the high limit switch or reset button... If you need a part, we can get you a price....I'm Susan with Restaurant Equipment Outlet, Cincinnati, Ohio, 888-542-5959, or you can ask for Paul too. Thanks, Susan REO
Sep 12, 2011 | Keating Instant Recovery 20AA (NG) Deep...
Sharp AR 151 E7-15 error
copy lamp disconnection trouble - copy lamp or cpy lamp drive circuit (inverter PWB) trouble copy lamp disconnection. If lamp does not light when you power up machine, the lamp is burned out or board is bad.
Aug 10, 2011 | Sharp AR-5316 Advanced Digital Imager...
On my brother super ace 2 computer sewing machine four of the keypad ar noy responding ie font/decorative stitch 0,1 and 2 what could be wrong
Had the same problem here. Took it apart and found that several tracks in the ribbon cable from the keypad to the circuit board on which the LCD display is mounted were broken hence keypad needs to be replaced. Its part number is XA4331002 and available online from Sewing World. Have just finished fitting the replacement and keypad and sewing machine are working A1 OK.
Jul 11, 2011 | Brother Sewing Machines
How do i reset the entire system back to default? Previously someone had put an admin lock on it so now i cant use it properly and i need to reset the menus.
Hi
· It is called the Cold reset
A cold reset resets the values of permanent storage variables back to factory default. Often this is
necessary for clearing the HP MFP Digital Sending Server IP address.
The following items are cleared during a cold reset:
● Embedded Jetdirect IP address
● SMTP IP address
● LDAP IP address
● Embedded Web server password
● All control-panel configurable items
The following items are NOT cleared during a cold reset:
● Local address book e-mail addresses
● Real-time clock (date and time)
● Page counts and maintenance counts
● Product serial number and formatter number
● Service ID
● Event log
To perform a cold reset
1. Turn off the digital sender.
2. Turn on the digital sender.
3. While the product is performing its memory count, hold down the #6 key. When the three status
LEDs are illuminated, release the #6 key.
4. Press the #3 key four times until the display shows COLD RESET.
5. Press the #6 key once to initiate the cold reset. The product will continue its boot-up sequence.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 02, 2010 | HP Digital Sender 9250c scanner Printer
Sharp AR-151
E7 15 copy lamp disconnection : Copy Lamp Drive Circuit
you need a tech to replace the circuit board for the scanning lamp
can not be reset
26 = 2 & 6
39 = 3 & 9
Sep 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-151
Try this sequence
Press: "Clear", "Exposure Select Key", "Clear", "Exposure Select Key", "26", "Start Key", "39", "Start Key"
there IS another subcode besides E7 try holding the stop or start or clear key you will probably see some different #'s
Sharp AR-151
E7-03 LSU problem (laser unit) E7-04 CCD white level problem E7-05 CCD black level problem E7-12 Shading problem
AR-150N series copy machine. Making loud clicking sound and has CH on display. Need manual for this machine also.
CH means door is open, flashing CH means problem with toner cartridge You may need to replace the toner cartridge, the op manual can be downloaded at: http://www.sharpusa.com/files/cop_man_AR-151.pdf
The 151 is the same to the 150
Hope this helps you...
Jun 06, 2008 | Sharp Office Equipment & Supplies
Sharp AR-5316 Advanced Digital Imager Copier Logo
52 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
