Question about LG KF600 3MP InteractPad Triband Phone Silver w/1GB
LG K600 predictive text
When using predictive text how do you cycle thru the list of possible words without having to enter it as new word each time?
  • steph-bull Sep 07, 2008
    I can't scroll through the possiblities on predictive text and only get offered one choice. It is ridiculous. Can anyone help?
    ALSO
    when setting my own photo as a background, i select it, edit the size and position and then there is no way to tell the phone i am done, no save or ok button ... what am i supposed to do?!
  • james dickson Sep 13, 2008
    this is really annoying!!
To change to the word you want press the up and down arrow keys on the bottom half of the touch screen. hope this helps!
Posted on Sep 13, 2008
    when your already to set the image press the bottom left hand button of the touch screen the one with arrows pointing in all four corners, the phone should now say complete.
Text Mode show on display nokia1600 handset
You can enter text in two different ways: the traditional text
input indicated by , or predictive text input (built-in
dictionary) indicated by .
To use traditional text input, press the key marked with the
letter that you want repeatedly until the letter appears.
To turn on predictive text input when writing text, select
Options > Dictionary and the desired language; to turn it off,
select Options > Dictionary off.
To use predictive text input, do the following:
1. To enter the word you want, press each key once for a
single letter.
2. If the displayed word is the one you want, press 0, and
start writing the next word.
To change the word, press * repeatedly until the word you
want appears.
W r i t e t e x t
24
If ? is displayed after the word, the word is not in the
dictionary. To add the word to the dictionary, select Spell,
enter the word (using traditional text input), and select OK.
Tips for writing text with traditional and predictive text input:
• To add a space, press 0.
• To quickly change the text input method when writing
text, press # repeatedly and check the indicator at the top
of the display.
• To add a number, press and hold the desired number key.
• To get a list of special characters when using traditional
text input, press *; when using predictive text input, press
and hold *.
or check this link
http://nds1.nokia.com/phones/files/guides/Nokia_1600_UG_en.pdf
Nov 14, 2011 | Nokia 1600 Cellular Phone
Blackberry texting prediction problem
what exactly is the text problem...here are some general solution for text prediction
  1. options > auto text > edit > clear the with field ( this solution is used for instance if you keep type hr and it comes out as hour and you want to change that)
  2. options >auto text > new > enter word ( used to add a new word to auto text )
  3. options > SMS > disable auto text : YES ( used to disable auto text or test prediction )
Sep 11, 2010 | RIM BlackBerry Curve 8520 Smartphone
Samsung Genio touch: The predictive text often makes up words as the first choice. e.g. On't - not, ar - as, Rm - so, Ger - her. Is there any way to delete these words from the dictionary as it is very...
I don't think you can delete words. However, if you re-enter the word you most want to appear first in predictive text by the 'add word' facility (even if the word you want is already there further down on the scroll menu) it will then become the first suggestion. So if you're always getting 'Gs' instead of 'it' simply re-enter 'it' in 'add word' (watch the case) and you'll get 'it' first. Get it.
Aug 15, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
I have a motorola v545 and want to turn off the predictive text help!
Go to messages, new message, go to the menu(middle button) select entry options/method/settings, go to primary and select TAP English, go to Secondary and select None.
Text-Entry Methods:
iTAP - Lets you enter words using one key press per letter. The iTAP® method combines your key presses into common words and predicts each word as you enter it.
TAP - Lets you enter letters and numbers by pressing a key repeatedly to cycle through the letters and number on that particular key.
TAP Extended - Same as TAP, but cycles through additional special characters and symbols as you repeatedly press a key.
Text-Entry Modes:
Primary - You can set your Primary entry mode to any iTAP or TAP entry method.
Secondary – You can set your Secondary entry mode to any iTAP or Tap entry method, or you can set it to None if you do not want a Secondary entry mode.
Numeric - Enter numbers by pressing the number keys.
Symbol - Enter symbols by pressing a key; its symbols are displayed at the bottom of the screen. Scroll to the desired symbol and then press Select.
To set the text-entry mode or method:
  • From a text-entry screen, press Options.
  • Scroll to and select Entry Setup or Text Setup.
  • Select the desired text-entry mode or method.
Tip: From any text entry-screen, you can quickly change your text-entry mode without leaving that screen. Press the # key repeatedly to cycle through the text-entry modes: Primary, Secondary, Numeric, and Symbol. With each press of the # key, the mode indicator in the upper left of the text-entry screen changes.
Nov 15, 2009 | Motorola Mobility RAZR V3
There is massaging setting
switch off the predictions......:) while typing go to options-->writing options-->--->input method--->ABC(predictions off) or TABC(to again switch on the predictions)
thank u...pls rate it of usefull!!!!!!!!!!!!!!!!!!!!
Oct 13, 2009 | Samsung J700 Cellular Phone
Predictive text
I had this problem and it was very annoying. What you have to do is..... create a new text message, enter the text that is annoying (mine was is coming up as 47). When you type the word and it comes up with the annoying one, select the word that you wanted and enter a space, and do it again and again (you can do this in the same text message - it can take up to 20 goes and eventually, the dictionary recognises that you actually wanted "is".
Oct 04, 2008 | Samsung U900 Soul Cellular Phone
Predictive text problems with my samsung u900
when on predictive text if you want to change a word just click the "0" button (one with the Cross sign) this will cycle though the different words for you
rate me please thanks
Predictive Text
To get predictive text on or off on the LG Shine go to:
>Menu
>Messaging
>New Message
>Text
>Options
>T9 languages
>T9 on/off
Sep 01, 2008 | LG Shine KE970 Cellular Phone
LG KF600 3MP InteractPad Triband Phone Silver w/1GB Logo
689 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
